Still running to rich
70herald
I finally got a chance to pull my carb apart since it was running way way to rich. Carb is a Stromberg CD150 no emissions stuff.
The float was way to low (gas level to high) I seem to have measured from the inside of the carb instead of from the flange, so that should have solved the problem but it is still to rich, no wheres near as bad as it was before, but still rich.
I also checked the weight of the float. All 3 floats that I have from different carbs had the identical weight - 12grams so I don't think that one of them is damaged.
So how much difference does it make that I don't have an exhaust system? would this make it run richer??
Can I further lower the float? I set it at 18 mm above the flange like the manual said, I could adjust it to 19 or even 20mm to further lower the level of the gas in the bowl.
Both the jet and needle are new from Canley Classics so they should be correct. The new Jet at least looks identical to the old one.
I don't know if you can with the model of stromberg you have but you may need to adjust the needle down yet to lean it out.
Also no exhaust will play some part on this as well. Not sure how much but it has to effect it.
bigbadbluetr6 TR6 TR-6 still not running right Triumph 31
C Key off, lights on engine still running??? Triumph 4
vping Still not running!! MG 48
Hamish Racing Historic Aintree GP track still in use Racing 0
Nelson Warranty still good Spridgets 3
B Does anyone still make or sell a quality condenser? Austin Healey 14
K TR2/3/3A Do Lucas distributor points still have the" Lucas logo" on them.... Triumph 4
sparkydave Odd discovery, but still ran OK Spridgets 1
PAUL161 T-Series Who's still building 5 speed conversions. MG 4
K TR2/3/3A What is the name of this bracket and is it still avaiable? Triumph 4
RAC68 Directionals, Still a Pain Austin Healey 25
RAC68 Clutch Still Slipping after replacing 30W-Non-Det. for Red Line Austin Healey 52
steveg Steering rebuild followup - still issues Austin Healey 29
T Pertronix Ignitor - old potential reliability issue is still there Austin Healey 12
T Pertronix Ignitor - old potential reliability issue is still there Spridgets 0
K For Sale TR3 grille....not perfect but still useable. Triumph Classifieds 2
C elusive amswersHi Mine is a 66 BJ8. I have 2 questions that up till now I still canno Austin Healey 2
R Still Another Healey Brake Bleeding Saga [unfinished] Austin Healey 9
GTP1960 General Tech Still in business? Triumph 3
KVH General Tech Still on the Body Work Triumph 6
Rob Glasgow Fender Beads still in wrapper Austin Healey 5
KVH General TR Still Losing Oil Triumph 5
KVH TR4/4A Wish I Could Give Up--My Carbs Still HS6 TR4A Triumph 27
CZ_Dave MGB I'm Still Around, just busy livin life on lifes terms MG 2
Steve1970 TR6 Carb air piston test, still results in stall even when adjusted rich Triumph 11
BJ8Healeys The scammers are still at it Austin Healey 3
I Quantum Mechanics Ltd still in business? Spridgets 7
CZ_Dave MGB I'm still around MG 2
J TR4/4A Cam Timing with Head Still On HELP! Triumph 8
KVH TR4/4A Still Learning: I'm Missing, But Only Slightly Triumph 4
M Backfiring through carbs still Austin Healey 17
wangdango This BN2 still around? Austin Healey 6
wkilleffer MGB Anyone still use HIF SU carbs? MG 12
R And Still Cooler in Florida Austin Healey 3
mgedit TR2/3/3A Still Overheating ... Triumph 22
Kleykamp TR2/3/3A Still fighting turn signal issues. Triumph 1
G MGB STILL working on clutch slave MG 37
B TR2/3/3A After a beating, the tunnel still lives Triumph 6
rjc157 I Donald were still alive Austin Healey 15
RAC68 Still being Surprised Austin Healey 7
A TR5/TR250 Who still rebuilds Rear Hub Assemblies? Triumph 15
Lukens TR2/3/3A Let's see if I'm still having the 'Britishcar forum not responding" problem Triumph 3
P T-Series Does my Mark II TD still exist? MG 3
mrv8q They're still out there..... Austin Healey 26
bighealeysource BN2 still missing, think it's carbs not ignition ? Austin Healey 8
KVH TR4/4A TR4A--still won't start Triumph 16
G MGB Still working on front suspesion MG 9
Jim_Gruber Spring is getting closer - What Spridget Winter projects do you still need to finish Spridgets 13
B Hello Gents....long time gone...but Im still at it..lol Triumph 1
dougie Still Time for Christmas Austin Healey 2
