Steering box fun!
  • Thread starter Deleted member 8987
  • Start date
Deleted member 8987
I am getting a tad tired of 140wt dripping out of the sector shaft......I'd previously done the worm seal in place, so, pulled the Pittman arm, pulled the top cover, slid the sector out the top (2.4L RHD manual steering, and it JUST clears), then the stupid O-ring seal.....the bugger was rock hard, had to pick it out in pieces....got it, cleaned the groove, slid the new O-ring into place, lubed it and slid the shaft back in.
Buttoned it all up, filled with oil now tommorrow we'll see what's dripping.
Something else. :wink: :jester:
Just remember, when a Jaguar is not leaking it's out of oil.
I do believe that applies to all LBC's, eh?
I did a lot of looking at the service and parts manual, making sure I didn't need to deal with the recirculating ball setup, and that there was a chance I could do this in-situ`.
Was NOT up to pulling the box.
Almost 24 hours, laid my ballpoint on the ground at the RF wheel, moved the vehicle into the garage and went back to check across from the ballpoint....dry.
For now, success!
:laugh:
R TR2/3/3A Jammed Steering Box Triumph 10
R TR2/3/3A Steering Box Gaskets Triumph 4
JAV For Sale non adjustable steering box Austin Healey Classifieds 3
W BN1 Steering Box Removal Austin Healey 11
Martinld123 Steering Wheel Alignment [Lost centering on steering box 1956 Austin Healey, BN2] Austin Healey 14
W BN1 Steering Box Austin Healey 3
Martinld123 Steering Box Leak Austin Healey 27
TomMull TR2/3/3A Steering Box Cam or Worm Triumph 18
W BN4 Steering box bushing. Austin Healey 2
Gundog61 BN2 Steering Box Leak Austin Healey 2
bighealeysource Changing Steering Box Lube (BN2) Austin Healey 9
B TR2/3/3A TR3a steering box rebuild Triumph 19
T For Sale - 1961 TR3A Steering Box Triumph Classifieds 8
BoyRacer Replace BN1 steering box with later version? Austin Healey 0
TAS525 TR2/3/3A Steering Box Rebuild? Triumph 19
Walter74 Steering Box End Play Austin Healey 2
J Experience with High Ratio Steering Box? Austin Healey 15
Jayplum TR2/3/3A Steering Box end play Triumph 6
J Steering Box Adjusting Bolt Lock Nut Austin Healey 11
Michael Oritt Steering box lube Austin Healey 22
K TR2/3/3A The steering box again? Triumph 9
S Steering Peg in Steering Gearbox Austin Healey 13
I Ball Bearing cup for old style BN1 steering box Austin Healey 0
C 1962 Healey 3000 Mark II Steering Box Austin Healey 9
M TR2/3/3A Steering Box Rocker Shaft Bushing Reaming Triumph 4
T TR2/3/3A Steering box oils - grease ? Triumph 20
K TR2/3/3A Steering box install again...the collar with the pinch bolt? Triumph 9
T TR2/3/3A Question on torquing nut on steering box rocker shaft Triumph 8
K TR2/3/3A Steering box fluid again.... Triumph 2
T TR2/3/3A Requesting help on removing TR3A steering column and box Triumph 21
S Filling Steering Gearbox with Castrol Hypoy Process Austin Healey 10
R TR2/3/3A Oops...Steering Box Situation Triumph 7
Csarneson Early BN4 steering box pitting Austin Healey 16
D TR2/3/3A steering box question Triumph 1
doc50 58 Metropolitan Steering Box Leaks Other British Cars 0
AH67 Wanted Wanted steering Idler Box & Arm Austin Healey Classifieds 3
Bob_Spidell Steering Box Replacement Austin Healey 76
B Steering box BJ8 Austin Healey 5
doc50 Adjusting play on steering box? Other British Cars 5
T TR2/3/3A TR-3a Steering Box rebuild question Triumph 3
doc50 Nash metro steering box question Other British Cars 1
L Tight spot on steering box is way off Austin Healey 18
R TR2/3/3A Lube for steering box, transmission and rear end Triumph 6
K TR2/3/3A Penrite semi fluid steering box lube? Triumph 14
B Outer steering column connection to the steering box Austin Healey 6
simon1966 Steering box lubricant Austin Healey 17
S TR2/3/3A Suspension Rebuild & Steering Box Triumph 4
M BN1 "in-site" steering box overhaul ? Austin Healey 4
Got_All_4 TR2/3/3A Has anyone tried this new steering box top plate Triumph 14
K TR2/3/3A Steering Box Triumph 2
