starter solenoid problem
Lin
Hi folks,
Well I have made it to Oregon from Rehoboth Beach, Delaware without a problem. Now I have a pesky one. It seems that the starter solenoid post is loose and I am only sporadically making contact to start the car. I have had to push start it a few times which while not a big problem is a bit of a pain.
Question:
I have a gear reduction starter and I seem to recall that you can bypass the original solenoid with these starters, but I have no directions. Can I just hook the cable from the battery directly to the positive post on the starter? If so, anything else I need to do? How about that little jumper wire? I assume that if one does this, then just turning the ignition key will turn the starter. Does the gear reduction starter have a solenoid built in to it to engage the starter to the flywheel?
Thanks for your help. I am hoping that I can do this until I can get a new solenoid along the way as I have another two weeks until I am back in Virginia.
Lin
Hi Lin I do not know about that starter. However it must have two terminals to work like you suggest. One connects Battery Hot to the starter and a second small one which connects to the R/W from the solenoid. However, Bill Bolten is there in ORE as well as Big Wilson Look em up they can help .--Fwiw-Keoke
:savewave:
Hey Lin!! you can replace that solenoid with any old ford type from a local auto parts store. :yesnod:
"I have a gear reduction starter and I seem to recall that you can bypass the original solenoid with these starters, but I have no directions. Can I just hook the cable from the battery directly to the positive post on the starter? If so, anything else I need to do? How about that little jumper wire? I assume that if one does this, then just turning the ignition key will turn the starter. Does the gear reduction starter have a solenoid built in to it to engage the starter to the flywheel?
Lin--
Yes, you can hook the battery directly to the starter or even easier simply use one stud of the solenoid to make the connction with the existing cables. Then if you hook the "little jumper wire" to the wire that energizes the original solenoid you will take it (the original defective solenoid) out of the circuit and you will be using the solenoid which is built into the gear starter. Actually you were always using it, but you energized IT through the original solenoid.
I have reductions starters and have discarded the original solenoid on all my cars--having both in tandem is kind of a "belt and suspender" situation where you need both to hold your pants up.
Lin--
Go here: https://ferraris.server273.com/solenoid.html
This is the page at the "British Starters" that tells how to to utilize the original solenoid with a reduction starter.
This is no doubt how you are currently set up and in order to get your Healey solenoid out of the equation you will need to disconnect the ring terminal end of the small wire from the big terminal on the reduction starter and hook it up via butt connectors and perhaps an additional length of light wire to the wire that runs to your original solenoid from the starter switch. Again, connect the battery cable and the starter cable together at either post of the original solenoid.
R TR6 Starter Solenoid Conection Triumph 11
S Starter Solenoid Nut Size for BJ8 Austin Healey 1
S TR2/3/3A Starter or Solenoid Triumph 13
ckeithjordan TR2/3/3A Starter Solenoid Triumph 3
K TR2/3/3A Starter,Solenoid, Ignition Switch Issue? Triumph 5
NutmegCT Failing starter solenoid? Restoration & Tools 15
S Wedge TR8 starter solenoid details? Triumph 3
Crankshaft TR2/3/3A Starter Solenoid Question Triumph 13
Perrymip TR2/3/3A Starter Solenoid Push Button Triumph 11
P Bugeye starter solenoid??? Spridgets 2
A TR6 Starter solenoid Triumph 3
H Starter Solenoid Positon Triumph 3
S TR6 TR6 Starter/solenoid Clicking Triumph 1
Mychael Location for pull starter solenoid. Spridgets 11
The_architect Bugeye battery / solenoid / starter cable lengths Spridgets 7
B Solenoid to starter cable on my 57 Triumph 6
Stinger TR4/4A TR4A Starter Solenoid Connector Triumph 2
doates Spitfire Spitfire Starter Solenoid Triumph 2
M Replacing the starter solenoid Triumph 16
Tr4dude TR6 Tr6 starter solenoid Triumph 4
S TR2/3/3A tr3 solenoid to the starter Triumph 6
RJS Starter Solenoid Issues Triumph 3
KVH More Battery/Starter/Solenoid Woes Triumph 14
KVH TR4/4A TR4 Starter and Solenoid Issue Triumph 19
K TR2/3/3A TR3 Starter Solenoid Test...Out of vehicle?? Triumph 3
bigbadbluetr6 TR6 TR6 Starter Solenoid Triumph 3
Dudly Spitfire setting up starter solenoid 79 Spit Triumph 11
Dadandson Starter Solenoid Alternative Spridgets 3
mjobrien Wiring Question on Starter Solenoid. Austin Healey 2
J BJ8, PH I Starter Solenoid, I Think? Austin Healey 12
T Smoke from Starter Solenoid Spridgets 9
G Blue and black wire near starter solenoid Triumph 2
Jim_Gruber Starting Question / Solenoid / Wiring / Starter Spridgets 1
W Aftermarket starter solenoid? Triumph 9
A Wiring connections for starter solenoid Spridgets 1
J starter-solenoid issues? Triumph 12
A Starter Solenoid Question - Push vs. Non-Push Austin Healey 4
Frank C. Starter Solenoid Austin Healey 3
Hegg Starter Solenoid Buzzes when trying to start Triumph 2
M MGB 1967 MGB starter conversion MG 9
CJ Burton MGB-GT Bolts for INERTIA STARTER on 1966 MGB GT MG 8
R TR6 Lucas Starter 2M100 - Extra Part? Triumph 2
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Frameman 1949 Engine Misfiring & Starter Cranks Slowly When Hot Austin Healey 8
N TR5/TR250 Starter Box Assembly Leak Triumph 14
P TR2/3/3A British High Torque starter Triumph 6
W General Tech 2500S starter motor and fuse box questions Triumph 3
EWD For Sale ‘74 TR6 original starter Triumph Classifieds 0
M High-Torque Starter Austin Healey 10
