TR6 Sputtering help
tr6web
tr6web
My 72 is sputtering under acceleration. Thought it was bad gas so filled with new. After about 3 minutes, all of a sudden car came to life and back to normal.
Today I take it out and it's back to sputtering. Tried adjusting carbs, moving distributor a bit, but nothing seems to work. Floats are full, seems fine when idle and reving pressing to on the carbs, but not when I step on the gas in gear. Any recommendations?
KVH
Maybe bad plug, or plug wire. Look for any evidence of plug "arcing" if near any steel parts. Not likely distributor cap, but check both that and the coil connection. After the experiences I have had, if I get nowhere quick with sputtering, I replace the condenser and even swap out the coil. Some people say sputtering is almost always fuel or spark, so be sure you don't have a sticking jet needle or other fuel issue, like a stuck choke or carb piston. Which carbs are on your car? I recently tried two new fuel pumps only to learn my issue was the coil, but that issue admittedly was starting not sputtering, so probably not relevant to your case.
tr6web
tr6web
Just checked my new RGK spark plugs and regapped to make sure they were all .25. Ends are totally black. Guess my air/fuel mixture is too rich? Would that cause constant missing?
bobhustead
A coat of soot on the plugs will certainly impair the spark. Change the plugs and lean the mixture. I do not know if you have a choke, but I assume so. Make sure they are opening fully after start. Somebody with knowledge of your carbs will happen along and might have other ideas.
NutmegCT
+1 on the "replace the condenser and coil" suggestion. Sputtering *on acceleration* is often an electrical problem, and a sign of bad coil and/or condenser.
If the plugs were black, was that after a series of short drives? If engine never fully warms up, plugs can get that black (carbon) coating. If plugs turn black even after long-term driving (an hour or so,), then mixture is probably too rich. Especially if missing is constant (not just under acceleration.
Tom M.
Gliderman8
Have you checked your fuel filter?
No go juice = sputtering
F TR6 Sputtering at low rpm Triumph 16
J Spitfire 1979 Spitfire Running rough [sputtering, exhaust poping] at start up Triumph 2
F TR6 Sputtering along Triumph 14
bugedd Sputtering Spridgets 15
PeterK TR4/4A Stalled project, now sputtering Triumph 3
S BJ8 Sputtering at High Engine Speed and in Overdrive Austin Healey 36
J MGB 69 MGB sputtering problem MG 5
nevets sputtering issue fixed...it was the timing Austin Healey 4
Bremer TR2/3/3A TR3A sputtering after 1 hour of driving Triumph 1
drooartz Sputtering in left hand turns Spridgets 17
nevets sputtering redux Austin Healey 3
nevets intermittant sputtering follow-up Austin Healey 13
nevets Intermittent sputtering Austin Healey 38
K TR2/3/3A TR3A: Occasional sputtering and hesitation? Triumph 4
K TR2/3/3A TR3 Coil + Heat = Misfiring and Sputtering? Triumph 6
TR4A_IRS Sput...Sput...Sputtering? Triumph 19
Shane Fully choked and sputtering Austin Healey 3
Mio Sputtering under load Spridgets 27
U sputtering at start Spridgets 3
Wana UPDATE: Engine Sputtering Austin Healey 2
Don Elliott TR4/4A Sputtering when hot TR3 & TR4 Triumph 29
Luke_Healey Ignition/Sputtering troubleshooting? Spridgets 16
Wana Engine sputtering... Austin Healey 22
H Rough Idle and Sputtering Austin Healey 22
mabbott TR6 73 TR6 Sputtering problem? Triumph 17
wkilleffer Sputtering/backfiring around left-hand turns MG 4
Gray_Cat Sputtering/warmish Running BN1 Austin Healey 2
K ran fine, now sputtering/backfiring at speed MG 8
T TR6 TR6 Sputtering Triumph 12
tr6web TR6 TR6 Manifold gasket help Triumph 0
D TR2/3/3A Please help w this tuneup Triumph 15
D Help with what 4 numbers on MGC VIN mean MG 10
B TR4/4A Some Help with Setting Distributor Triumph 47
N Wanted Help with car identification Other British Classifieds 2
I MGB Help! What is this part for? MG 13
P Please help identify this tourer Spotted 13
C MGB More Weber help needed MG 27
V 96 Chimera help needed TVR 1
V Help with identifying morris eight Other British Cars 12
J MGB help, turn signals do not work MG 3
J MGB HELP, my horn does not work! MG 8
I MGB Alternator help MG 0
Southwarks TR2/3/3A TR2 door help! Triumph 2
P General Tech Positive Earth?? Very confused. A little help? Triumph 19
Texas TR3 TR2/3/3A Convertible top webbing installation help? Triumph 5
apbos The next rabbit hole. Help ID the chassis. Racing 27
R Help With Spridget Speedometers Spridgets 4
apbos Help Identify this car chassis Racing 20
