Hi Guest! If you enjoy and benefit from your participation at British Car Forum, please consider supporting our efforts with a subscription. There are some perks with a member upgrade!
I have a new Moss starter on a rebuilt 1275 . It works but is noisy and sometimes misses the ring gear. I'm told that there are no shims with this application, just bolt it on and it should work but I wonder. Anyone else had this issue.
You need to make sure that the starter is fully into the hole in the back plate before locking it in place- if the starter is angled and not straight it will cause the problems noted
BillM
