Speedometer Drive Pinion Bolt
angelfj1
Replaced the speedometer cable on the TR250 today and noticed that the drive pinion peg bolt is missing.
It must have vibrated loose (or I forgot to replace it last time :blush: ). At any rate, neither Moss nor Roadster Factory list this bolt. I can make one on my lathe if someone could please provide the dimensions.
BTW, is that a copper crush washer under the bolt head?
Thanks, Frank
You guys and your lathe work give me heart burn
Jealous,jealous,jealous
Aw c'mon, Frank. If you can run a lathe, surely you can figure out how to measure for that peg!
However, I make out dimension A ~= .550", B ~= .780", C~= .220". Overall is 1.570". Spigot diameter is .232", shank is .308", threads appear to be 5/16NC.
I'm reasonably certain the shank is not important in this case, likely any 1.5" bolt would work if you turned (or even filed) down the tip.
The TRF diagram for TR6 shows both a flat washer (not copper) and lock washer, but my TR3 SPC shows only the lock washer (and that's all I found on the TR3 gearbox I just robbed it from). Bolt has the same part number though, so it should be the same for your TR250 as well.
BTW, most machinists seem to hate the Smithy "all in 1" machines. I wouldn't know though, as mine is a slightly earlier version of this:
ZPA2APk" type="application/x-shockwave-flash" wmode="transparent" width="425" height="350"> </embed></object>
And no, it is NOT for sale! :laugh:
I think that is CRS
Or did you forget?
Shouldn't leave a chuck key in the chuck like that...it's an accident waiting to happen.
Good point, but I assume the shot was staged to show what was included.
M TR2/3/3A HVDA Speedometer Drive Triumph 10
DocDup1 MGB SpeedBox Speedometer Drive MG 0
BritBite Speedometer Right Angle Drive Austin Healey 5
RJS TR4/4A Speedometer and Angle Drive Triumph 6
S Speedometer Angle Drive Austin Healey 2
Michael Oritt Speedometer drive issue Austin Healey 4
K Speedometer Drive Gear Issue w/ Smitty/Delaney Tx Conversion Austin Healey 16
T TR4/4A O-ring size on a A-type angle drive speedometer gear Triumph 10
TimK Lubricating Speedometer drive Austin Healey 11
S Transmission Speedometer Drive Triumph 4
Rob Glasgow Speedometer Angle drive Austin Healey 8
J Speedometer angle drive keeps breaking Austin Healey 10
T speedometer angle drive Austin Healey 3
F TR2/3/3A TR3A OD speedometer drive Triumph 4
Paulus Speedometer drive housing question. Triumph 0
A Speedometer Angle Drive -Two Gone this month! Help Austin Healey 9
N Speedometer angle drive "DRVING ME NUTS" Austin Healey 9
GeorgetheTR3 TR2/3/3A Speedometer Triumph 4
jfarris For Sale TR3 Speedometer SOLD Triumph Classifieds 3
roscoe GPS Speedometer Austin Healey 6
J 1985 TVR 280i Speedometer Cable TVR 4
F TR4/4A Speedometer cable replacement access Triumph 0
R TR2/3/3A Speedometer Reset Triumph 26
roscoe GPS Speedometer Austin Healey 10
PAUL161 T-Series TD/TF speedometer gears. MG 3
AUSMHLY Speedometer Fluctuation Austin Healey 21
Magyar Rebuild Speedometer & Tachometer - mechanical or electronic? Spridgets 17
M TR6 Speedometer Triumph 2
S For Sale Early Sprite & Midget Speedometer/Tachometer/Generator etc. Spridgets Classified 2
P TR6 Jumpy Speedometer cable Triumph 4
PAUL161 T-Series Interesting Speedometer Scenario MG 5
John Turney Getting Speedometer out of the Case Austin Healey 6
K TR2/3/3A Speedometer needle bounce? Triumph 1
P Speedometer confusion Spridgets 1
J TR2/3/3A Speedometer Bounce with Odometer Gear Movement - Benchtop Calibration Triumph 3
T Speedometer Repair Problem Austin Healey 5
J TR2/3/3A Speedometer Works Removal Triumph 10
R TR2/3/3A Speedometer Routing Triumph 15
KVH General Tech Speedometer Not Working Triumph 5
AUSMHLY 1962 3000 Mk II BT7 speedometer Austin Healey 2
K TR2/3/3A Speedometer Error Again Triumph 8
G Spitfire gps speedometer Triumph 6
J Speedometer Tach Correlation 1965 Austin Healey BJ8 Austin Healey 3
B For Sale MGA JAeger Fuel Gauge, Dual Safety Gauge, Speedometer and Tachometer MG Classifieds 0
B For Sale Austin Healey 100 Smiths Fuel Gauge, Dual Safety Gauge, Speedometer and Tachometer Austin Healey Classifieds 0
B For Sale Triumph Tr3 Fuel gauge Temp gauge Oil pressure gauge, speedometer tachometer Triumph Classifieds 0
T Wanted WTB 100 / 4 Speedometer Austin Healey Classifieds 0
B Differences between BN2 and BN4 speedometer gears?? Austin Healey 7
F How does overdrive Annulus effect speedometer Austin Healey 10
M TR4/4A Speedometer Cable Routing Triumph 7
