TR2/3/3A Spare Tire Size
frankfast
Presently have 165/80R15 on the car but that size won't fit in the spare tire compartment. Is there a popular size radial that is a bit thinner that I might use in a pinch as a spare that will fit? Thanks
More experienced voices will join in, but you could probably just slightly deflate the tire.
Then use a battery powered pump if you ever need to actually use the spare.
Tom M.
(frugal zealot)
FWIW, I found a "compact spare" tire in the junkyard that would fit on a stock TR3 rim (size T135D15). Much cheaper than a new tire, and fits with room to spare. I actually keep a cheap blanket rolled up and stuffed in beside it, so it can't slide around. (Blanket comes in handy to kneel on while changing a tire.) The compact spare tires are a different construction (not radial) that supposedly does not "age out" like modern steel radials do.
Of course, you should observe the conditions marked on the tire, which ISTR calls for 45 mph max and "Temporary" use only. But I've driven roughly 2 hours at 70+ mph on it and no noticeable problems.
I have a 165/80 R15 tire as a spare on a steel rim.. That fits in the compartment but is snug. Does not need to be strapped in. I will probable wrap a strap behind the tire to help get it out if I were to need it.
David
Post commission TS60k cars have a slightly larger spare tire compartment and will accept a 165/80-15. Pre TS60k cars can only get in a 155 size.
I carry a 165HR15 spare in my pre-TS60000 TR3A -- but it has to be deflated and even then it is such a snug fit I sprinkle baby powder on each side. A strap looped thru the rim makes it possible (not easy) to pull it out. Picture me on my butt with a foot on each bumperette pulling for all I'm worth.
Fortunately - I have never had a flat in all the years I have driven that car.
Frank,
My 1957 TR3 came with 60 spoke wire wheels, I fitted 165 Michelin radials from Coker. The spare was a 48 spoke and the Michelins didn't come in a 155 size, so I got a Firestone 155 radial from Coker as it would fit in the wheel well. When I sent the wires off to Hendrix to be trued and balanced, they said they were trash, so I bought new 48 spoke wires (MWS) and had the Michelins put on them. The Firestone fits nicely in the wheel well.
Just a side note: How well a 165 fits in the early well may depend on just how the trunk floor is bent. Back when I was using a 165 in a pre-60K car, I would sometimes have to use it as a lever to pop the trunk floor upwards before I could force the tire in.
My post TS60k won't accept a 165/80-15R without forcing it in. I had a heckuva time getting it out when I bought the car. I think it's best to find a 155 for a spare.
I have a pre-ts60k, and have a T125/70D15 (from Discount Tire) fitted to an original wheel. It is marked 60PSI max, and though much smaller than a stock tire, it holds the car up. I've never had to put it on the car while on the road, but have test fit/drove with it. The tiny wheel/tire leaves enough spare space in the boot for a scissor jack, spare water pump, spare belt, spare fuel pump, spare alternator, spare distributor with cap and wires, extra flash light, fuel filter elements, misc wiring, lug wrench, towel and handy-wipes. That way I have room in the trunk for a few tools and luggage. The boot is only opened in case of emergency. -not that I plan for one.
Look online at Lucas Tire.
They have a couple choices for 155 /15 Radials.
i have purchased tires from them with good luck.
Gil. NoCal
T TR2/3/3A TR3A Spare Tire Well & Tire Size Triumph 13
davidk What size modern tire will fit in spare tire well? Triumph 7
tmc Tire size for the spare Triumph 10
Aldwyn Tire Size > Spare Well? Triumph 7
JohnGone Wanted Q: Small Boot, Small Spare Tire? And, Jack needed. MG Classifieds 2
H Wanted Need Spare tire rod BJ8 Austin Healey Classifieds 1
F TR2/3/3A Spare tire cover Triumph 8
S TR2/3/3A spare tire compartment holes for modern license Triumph 8
F TR2/3/3A Spare tire cover Triumph 3
P Wanted E type spare tire bracket Jaguar Classifieds 2
P Wanted 62 E Type spare tire bracket Other British Classifieds 1
S TR2/3/3A tr3 spare tire fit Triumph 16
O TR2/3/3A Spare tire Triumph 4
D Vredstein 185X70 Spare Tire Fitment Austin Healey 5
K TR2/3/3A Volvo low profile space saver spare tire for TR3 ? Triumph 1
maxwedge5281 bn6 spare tire shelf Austin Healey 1
maxwedge5281 bn6 two seater spare tire shelf upholstery Austin Healey 4
Chuck9482912 Mini Spare Tire Austin Healey 9
S TR2/3/3A body work on the spare tire panel Triumph 7
V spare tire Spridgets 5
Scot1966 TR6 Screws in TR6 spare tire well Triumph 12
S TR2/3/3A trunk/spare tire Triumph 9
Gearhead_Garage Spare Tire Cover Tip Austin Healey 1
maxwedge5281 wanted: spare tire holddown and body attachments Austin Healey 9
I TR6 spare tire cover Triumph 5
I TR6 69 TR6 spare tire lid Triumph 4
Superwrench Spare tire rod Austin Healey 2
F Proper location of chrome loop for spare tire strap? Austin Healey 2
Kleykamp Hole pattern on spare tire lock covers??? Triumph 5
mgedit TR2/3/3A Spare Tire TR3 Triumph 11
B MGB 78 MGB Spare Tire trunk lockdown thingie MG 13
H TR4/4A Spare tire bracket 4A Triumph 4
Q TR2/3/3A TR3A Spare Tire Door Seal Triumph 3
mgbmedic TR2/3/3A TR3A Weatherstripping / Trunk - Spare Tire Cover Triumph 11
M TR2/3/3A TR-3A - spare tire Triumph 4
A TR2/3/3A TR-3A Spare tire lid rubber Triumph 1
HEALEYJAG spare tire Healey 100 Austin Healey 7
K TR2/3/3A Up-date on TR3 spare tire Triumph 6
bcbennett Spare Tire Cover Triumph 1
bcbennett TR6 TR6 Spare Tire Triumph 27
M_Pied_Lourd TR2/3/3A TR3A Rear Body Mount/Spare Tire Compartment Repair Triumph 42
luke44 TR2/3/3A TR3 Spare Tire Cover - Lock Triumph 5
tahoe healey Spare tire on boot Austin Healey 16
R TR6 TR6 Spare Tire Cover Needed Triumph 9
G TR2/3/3A TR3 Spare Tire Compartment, post-60,000 Triumph 5
CinneaghTR TR4/4A Spare Tire Won't Fit in TR4A Trunk Triumph 8
bigbadbluetr6 TR6 TR6 Spare Tire Triumph 1
1 BE spare tire [tyre] is slipping Spridgets 17
T Spare tire question Triumph 21
