Smitty Toyota Conversion
Jim Frakes
I have converted the tranny on my BN4 with a JULE frame. It is currently in the body shop and has just been painted and wating panel re-assembly. Question is? The toyota motor mount used with the Smitty adapter for mounting the rear of tranny is rather flimsy. A Big Healey with an OD tranny has a mounting bracket that keeps the engine from moving forward. With the flimsy toyota mount, I am wondering if any other converters fabricated a mount to keep the assembly (motor included) from moving forward (or backward????
Have you spoken with the Smitty people? Perhaps, they have tested it and in spite of its' flimsy appearance it is more than up to the job.
How many pounds does the car loose from the tranny conversion? 50? 100?
Hi Jim, haven't heard from you for awhile. Actually since Gateway hosted Conclave in 1999.
Anyway, the tranny mount your referring to is the one that bolts to the X frame on the top, one on each side, correct?
I always thought the bottom set that goes back to the X frame and is buffered in on the bottom of the tranny actually keeps the unit from going forward when stopping.
Hi J.L.!
You are correct, the tie rod is to keep the engine from moving forward into the radiator and it can also keep it from moving back into the firewall. That tie rod is not present on the Smitty conversion. Smitty makes an adapter plate that nestles into the x frame and holds the original Toyota motor mount, a v-block arrangement. The toyoya v-block rubber mounts are much softer than the Healey (even new ones). The engine is very close to the firewall and I am more concerned about shifting backwards than forwards. We are probably going to fab a tie rod, maybe by drilling a hole in the bracket and re-using the standard tie rod arrangment.
I know most people are against the Toyota idea, but those who have it and love it are those who are driving a lot of miles each year. I know I will miss the electric OD also but I still will have the BJ8 with OD. The purists will probably really go crazy when I ask about changing my Muncie four speed in the Nasty Boy to a slush box. (This winters project).
Jim
I have a 65 BJ8 with a smitty conversation. Have put about 2,000 miles on the car since the installation without any problem.
Hi Lou (and Marilyn)
I have a personal email from a gent who agrees there is a problem and has a solution. He is going to email me the "fix" he used. Stay Tuned.
His comment is the same as mine, the rubber in the toyota mounts are much softer and with a bit of oil (where from?) they wil soften up even more.
Jim
Jim
Hi Jim,
I have my Smitty conversion kit and just picked up a Tacoma tranny. I am getting close to installation time. By the way, I also have Martin's frame. Did you find out anything that was helpful in alleviating your engine movement concern? Thanks.
Lin
<font color="black"> </font> <font color="black"> </font>
R Smitty Toyota Conversion Angle Drive Austin Healey 16
Michael Oritt Pilot Bearing Adapter for Smitty's 5-Speed Kit Austin Healey 3
Michael Oritt Smitty's Five-Speed Manual Austin Healey 1
HealeyBN7 Smitty Austin Healey 4
G Smitty’s transmission parts Austin Healey 11
K Speedometer Drive Gear Issue w/ Smitty/Delaney Tx Conversion Austin Healey 16
S Smitty trans Master cylinder Austin Healey 21
J "Smitty" 5 Speed Clutch Issue Austin Healey 17
J Smitty clutch disc Austin Healey 13
R Smitty Speedometer Cable Fix Austin Healey 1
richberman Smitty Conversion Austin Healey 19
T Pete Delaney/Smitty's 5 Speed - Cost & Description Austin Healey 0
Lin Smitty Conversion -Throw Out Bearing and Pivot Arm Austin Healey 3
CharlieCarpenter Smitty's Healey 5-Speed info??? Austin Healey 13
bighly Smitty Conversion Photos now posted Austin Healey 5
B Looking to buy Toyota Avensis T25, any thoughts and advice? Other Cars 1
G Toyota Wiper Blade Inserts - Cheaper Option Other Cars 3
Michael Oritt Difficult-Shifting Toyota Five-Speed Austin Healey 17
D 1.8 2007 Toyota Avensis Clutch & Flywheel Torque Settings? Other Cars 0
Cappy Toyota 5-Speed Austin Healey 3
Cappy Toyota 5 Speed transmission Austin Healey 4
steveg Toyota W58 Trans Hard Getting Into Gear Austin Healey 8
HealeyRick Toyota 5 Speed - Truck or Supra? Austin Healey 16
Michael Oritt Toyota 5-speed shifter bushing Austin Healey 7
Lin Toyota 5-speed bell housing drain hole Austin Healey 14
T Toyota 6 cylinder eng & trans in a BJ7 Austin Healey 0
B TR2/3/3A Mounting Toyota Brake Calipers on my TR3 Triumph 5
Michael Oritt Toyota 5-speed Problem Austin Healey 28
J TR6 Toyota Transmission conversion Triumph 8
Patrick67BJ8 Toyota 5-Speed - Followup of problems. Austin Healey 5
T HP Impact of a Toyota transmission, or a header/2" exhaust ??? Austin Healey 16
S '81 Toyota Celica Other Cars 8
B Propshaft length - Toyota 5 speed conversion Austin Healey 2
aeronca65t One less Toyota 2000 GT Other Cars 5
B Clutch release arm / fork gaiter ; Toyota 5 speed conversion Austin Healey 2
DanLewis Toyota T50 5-speed conversion ?? Spridgets 5
glemon TR6 Toyota Caliper Conversion Triumph 28
2wrench TR6 Do the HVDA [Toyota overdrive conversion] or repair my existing J Overdrive? Triumph 29
aeronca65t Toyota 2000 GT Spotted 9
steveg Front Toyota disc conversion now complete - photo essay Austin Healey 0
steveg First drive - Toyota 4-piston Disc Brake conversion Austin Healey 6
tinman58 TR2/3/3A Toyota brakes on a TR3? Triumph 8
Patrick67BJ8 Toyota 5-Speed slides out of 5th gear Austin Healey 19
T Question I should know - which rotor for Toyota Triumph 9
Sherlock The ultimate Toyota Land Cruiser? Plus a Jeep too Other Cars 3
T BN1 Toyota Gearbox Austin Healey 4
G TR6 TR6 caliper question [Toyota 4 piston?] Triumph 2
H TR6 Toyota Truck calipers on a TR6 WOW Triumph 31
T TR2/3/3A Toyota calipers on a TR3 Triumph 11
T TR2/3/3A TR3 [Toyota] trans question Triumph 5
