smith guage lights
Tyrone
Hi, I don't seem to be able to unscrew the original instrument bulbs. They're set deep into the socket and hard to get a grasp on.(surrounded by those fingers) I'd prefer not to destroy them. Does anybody have an idea as to their removal? Thanks, Tyrone BJ8
British_Recovery
Bronze
If the wire going into the back of the socket seems well-attached, pull it gently to compress the coil spring inside, relieving the pressure on the bulb.Bob
vette
Unfortunately my method entails destroying the bulb. But sometimes ya gotta do what ya gotta do. With the bulb broken and the power turned off, I have grabbed the edge of the brass base with needle nose pliers to rotate the threaded base. But also if the socket is this badly stuck, it may be necessary to just replace the socket.
G Smith's temp gauge repair Restoration & Tools 4
Retired2020 TR5/TR250 TR250 smith gauge Triumph 7
6 Smith heater rebuild Austin Healey 8
P For Sale O-rings for Smith and Jaeger gauges. Other British Classifieds 2
M BE Smith's Heater Info Plate Spridgets 3
BillyB62 TR2/3/3A Is this Smith heater junk? Triumph 4
apbos Tachometer ID Smith's Rn1412/00 Spridgets 5
D Smith's Heater Box - AH Spares Spridgets 9
Morris EDIS and Smith's RVC Tach Spridgets 4
doates Smith's PCV Triumph 1
HerronScott TR4/4A Smith's Instrument List for TR2-4A? Triumph 1
I Recommendation for Smith gauge repair? Triumph 25
Lin Cape international heater to replace Smith's Box Austin Healey 7
longbridgehealey smith oil/water gauge Austin Healey 7
longbridgehealey Nisonger in NY for Smith gauges Austin Healey 7
7 Smith's Heater Wiring Question MG 15
Z BN1 Smith heater Austin Healey 4
C Smith's Voltmeter from Moss MG 3
M U.S. source to repair or replace Smith's gauge Restoration & Tools 10
G Cool little Smith's Replica clock Triumph 9
B Loss of Everett Smith Austin Healey 2
T Removing the Smith's Heater Spridgets 6
M Smith Gauges MG 7
Lin Smith's Heater Water Valve Austin Healey 2
K TR2/3/3A Fuel Guage Sending Unit Triumph 5
F Removing oil and water guage from BT7 dash Austin Healey 17
D TR2/3/3A tr3 temp guage capillary tube thread size Triumph 3
G Installation Water/Oil guage Austin Healey 10
S TR4/4A Temp guage problem Triumph 5
S TR2/3/3A Temperature Guage Triumph 3
B TR2/3/3A Fuel Guage Triumph 5
B TR2/3/3A Guage bezel gaskets Triumph 13
G TR2/3/3A TR3A Electrical Quirks, Flasher, Wipers and Fuel Guage Triumph 4
bugedd Fuel guage not working Spridgets 7
Dave Richards Temperature Guage Austin Healey 11
W Fuel guage interchangeable between AH, MG, TR? Austin Healey 11
R TR5/TR250 Fuel Guage Problem Triumph 10
G Oil pressure guage shows no oil pressure! Austin Healey 5
S Temp and Fuel guage not working Triumph 4
J OIL PRESSURE GUAGE Jaguar 7
W Dual Guage restoration Spridgets 10
B Gas Guage Not Working--Voltage Stabilizer? Spridgets 17
M Fuel Guage Woes MG 2
1 Electrical/guage problem MG 8
JohnnyMead TR2/3/3A TR3 - Routing the Temp Guage Tube? Triumph 5
R smiths guage problem- need advice Austin Healey 4
pipercollins Running Temp, Guage, Sender Questions Triumph 11
mountainman TR 3 Temp Guage Capillary Tube Triumph 6
G Incorrect Temperature Guage: a fair assumption? Triumph 14
G Foggy guage glass Triumph 6
