Shock absorber conversion
twas_brillig
We had the Putzke Fahrpass shocks and polyurethane bushings installed along with trunnion bearings and adjustable camber plates. Alignment now has slight negative camber.
The shop that did the work commented that it was the best handling, best riding, Healey that they'd ever had; an acquaintance who is rebuilding his BJ8 made the same comment.
Cons? None. My recollection is that the shock kit is completely reversible, so don't throw out your lever arms. The camber plates are welded, but also pretty inert and invisible. Doug
G Squeaking Armstrong Shock Absorber Austin Healey 7
BN6_2197 Removing connecting link between shock absorber and rear axle Austin Healey 4
O Shock Absorber maintenance Spridgets 4
R Shock Absorber Austin Healey 0
maxwedge5281 front shock absorber mounting Austin Healey 3
T TR2/3/3A Before and after lever shock absorber pictures Triumph 12
DornTRoriginal Miata 1997 MX-5 Shock Absorber repalcement assistance Other Cars 2
D Rear Shock Absorber Links Austin Healey 7
R Shock Absorber test Triumph 8
mountainman TR2/3/3A TR3 Rear Shock Absorber Fluild Triumph 3
tahoe healey rear shock absorber Austin Healey 9
1 Yeah! Finally bit the shock absorber bullet.... Spridgets 6
roscoe Shock Absorber . Anyone ever done this? Austin Healey 6
D Shock absorber question: Austin Healey 2
roscoe Shock absorber disassembly Austin Healey 13
C Shock absorber mounting bolts - Lock-tite? Austin Healey 16
G Checking & filling shock absorber fluid Spridgets 9
T TR4/4A Early TR4 - Lever Shock Absorber Fluid Triumph 2
MgKid1974 Shock Absorber Inquiry MG 19
Wana Shock Absorber Oil Level [was "Oh No!"] Austin Healey 12
sultanoswing Shock Absorber Questions MG 8
sparkydave Shock absorber question Spridgets 8
R Front shock absorber arm seal replacement.... MG 1
G Right-Side Shock Weeping Oil Austin Healey 1
Celtic 77 General MG Lever shock oil refiller MG 0
M Left shock Spridgets 4
Gliderman8 TR6 Lever shock noise Triumph 18
RJS General TR Lever Shock - HD Shock Valve Triumph 2
T Kilmartin Adjustable Front Shock Mount Plates - Installation Instructions Austin Healey 0
newmexTR3 TR2/3/3A TR3 Shock tower spring collar Triumph 7
jfarris TR2/3/3A Rear Shock and link remove and replace Triumph 1
J TR4/4A Getting electrical shock from horn button when using the horn. Triumph 9
35 Siddeley MGB MGB Armstrong shock dimensions wanted MG 0
Boink Ugly Shock Failure Spridgets 3
M TR4/4A Dedicated front coil over shock absorbers. Triumph 5
C MGA Shock fluid MG 14
AH67AH Broken Shock Mounts Austin Healey 23
H Rear Shock Removal Austin Healey 5
BN6_2197 BN6: Shock absorbers do not fit after renewing the link arms Austin Healey 20
K TR2/3/3A Upper shock mounting rubber bushs ? Triumph 1
Got_All_4 TR6 Armstrong Shock Colors Triumph 3
aero3113 For Sale Big Healey Tube Shock Conversion Austin Healey Classifieds 2
J Thread Locker on Shock Bolts? Austin Healey 19
AUSMHLY Lever Shock Oil Level Austin Healey 41
M e-type siries 1.5 shock abosorbers Jaguar 3
F Wanted TR6 Shock Turret Sheet Metal Triumph Classifieds 1
trotti Shock mount problems Austin Healey 9
S TR2/3/3A rear shock arms and links Triumph 4
Raymond General Tech Shock oil MG 4
