Setting up HD8 carburetors
Ralph F.
I have had both HD8 carburetors off my '67 BJ8 3000 for rebuilding, and now cannot get the car to run. Can someone point me to a monograph on how to set up the pair of HD8 carbs, starting from a not-running situation ?
Hi Raplh,
It could be a dozen different problems, from not getting enough fuel (float valve or level) to incorrect jet adjustment, to the air pistons sticking. Go here & see if you can get any ideas. It covers nearly everything.
https://www.hazelden.ca/austinhealey/index.html
[ QUOTE ]
[/ QUOTE ]
When I set mine up following the guide in the SU book everything was fine EXCEPT the balancing, and it was an absolute pain having to remove the air filters and listen with a pipe for 'the same hiss' and any alteration would be negated by any small difference in the filter charateristics when replaced. As the height of the dashpot is a measure of the relative balance of the carb I did a bit of head scratching.
My solution was very effective and very simple. Remove the oil damper cap fron each carb, cut two exactly equal (hence weigh the same) bits of 1.6mm brazing wire, crinkle one end so it is a friction fit in the oil damper bore and bend a 90 degree so the two bits of wire point at each other horizontally. Adjust with engine stopped so the pointers exactly face each other. Start the engine, and open the throttle. As the pot rises and falls they should exactly track each other if the balance is correct.
... dead simple and cheap and the filters stay put !
AWEM
Hello Ralph,
if I have any S.U. problems the first thing I do is to remove the dashpots and pistons, once done I can see where the jet top(s) is. It should be about 1\8" or fractionally less, now with the ignition on (or crank a car with a mechanical fuel pump) I can check for fuel level which should be visible near the top of the jet. If it overflows the float level is too high or the needle valve is passing. Conversely too low or a fuel supply problem\blockage.
After that I check that the needle is correctly fitted in the piston, (shoulder flush with the bottom) and the piston is free in the dashpot. Reassemble and lift the piston which should then fall with a click. If not, then the jet requires centering.
If that is all pretty much OK, look to your ignition. The car will run with quite coarse settings, which then lets you fine tune afterwards.
Reasonable fuel level, jet down in the holder, needle flushish and piston free and it should run.
Alec
HI Andrew, /ubbthreads/images/graemlins/iagree.gif thats a good way to balance the carbs. A tool that matches your description is readiy available from most stockist herein the US. I bet Holden sells one too.---Keoke
I've had a set like you discribe for nearly 35 years. It works well and can be used on tricarbs. It came with a centering tool and the metal tube can ge used to adjust the floats. You can also lift the damper piston and visably see how much when it is raised to check the mixture. I paid 12 bucks for it then. I still like the Unison glass tube thing too.
HI TH, Yeah those SU tools have been around for a good while. The Unisync is great too, but you have to pull those stinkin air filters off to use it and then retune the carbs when you put the filters back on.---Keoke /ubbthreads/images/graemlins/devilgrin.gif
B TR4/4A Some Help with Setting Distributor Triumph 47
K TR2/3/3A Setting the SU carb jet again....... Triumph 2
DocDup1 TR4/4A DR3A Wiper Motor Park Setting Triumph 4
C MGA Setting a 123 distributor MG 0
BarryO TR2/3/3A setting up a TR3 clutch slave Triumph 5
B Front Wheel Camber Setting Austin Healey 8
Michael Oritt Initial mixture setting for H6 carbs Austin Healey 3
A Setting Camber Really Off Austin Healey 13
M BN1 with H6 carbs : what setting ? Austin Healey 56
P BJ7 HS6 Carb Baseline Setting Austin Healey 10
HealeyRick Why Setting an Auction Reserve is Important Spridgets 2
S Fan blade bolts - torque setting and thread-locker? Austin Healey 4
HighAltitudeTR3 TR2/3/3A Choke setting tips? Triumph 7
steveg Carb float setting tool Austin Healey 11
Michael Oritt Torque Setting needed Austin Healey 10
M Replacing front shocks, torque setting? Spridgets 2
J BJ8 Vacuum Advance - disconnected -RIGHT - when setting total advance?? Austin Healey 6
S Torque setting for U-Bolt nuts Austin Healey 12
K TR2/3/3A More on setting the timing... Triumph 12
petnatcar How to find the perfect ignition setting? Austin Healey 6
bugedd Setting Timing Spridgets 6
F Problem setting timing on my BT7 - maximum distributor rotation reached Austin Healey 14
mgedit TR2/3/3A Setting Valve Lash Triumph 14
GTP1960 TR2/3/3A the value of experience when setting timing on a modified engine Triumph 33
C TR2/3/3A Dwell setting Triumph 11
K TR2/3/3A Setting ignition timing to 4 degrees BTDC? Triumph 1
Jim_Stevens TR2/3/3A OD low pressure vs Operating valve shaft setting Triumph 9
S Procedure for setting and tuning HD8s? Austin Healey 10
RJS TR4/4A Setting up Self Adjusting Slave Cylinder Triumph 6
K TR2/3/3A Setting ignition timing at 8 degrees BTDC instead of 4? Triumph 9
S Idle Speed Setting versus Generator Output Spridgets 3
Scotsman TR2/3/3A Setting valve clearance on tr3 Triumph 10
R Question on establishing a baseline timing setting Triumph 3
T Torque setting on brake rotor Triumph 4
B Setting door glass Austin Healey 3
T TR2/3/3A TR2/TR3 spark plug gap setting?? Triumph 8
Gliderman8 TR6 Setting TR6 valve clearances Triumph 19
R TR4/4A Tr4a, Stromberg float setting Triumph 6
M Carburetor tuning - setting mixture Triumph 6
C Setting bonnet height at front? Austin Healey 8
T Setting up the diff carrier's gears questions?? Triumph 3
pkmh Setting Timing Mark For BJ8 Austin Healey 9
B TR4/4A TR4 ZS carb air/fuel initial setting procedures Triumph 9
rlich8 TR4/4A A baseline setting on TR4A carbs? Triumph 2
J Setting Timing with a Petronix System Triumph 4
S TR2/3/3A Using a timing light for setting TR3 Timing Triumph 4
M TR2/3/3A Setting the timing on TR3 Triumph 48
B TR2/3/3A 57 TR3 TS19009 setting the body to the frame Triumph 3
G Setting mixture on HS4 carbs MG 30
T HS6 idle setting Triumph 3
