I am installing new carpeting in my '62 AH BT7. The old carpet was cut so as to slide in around the seat slides and could be removed without removing the seat slides. The new carpet kit from Moss is installed under the seat slides similarly to the MGB. I confirmed this with one of the Moss tech specialists.
The seat slides had been installed with a steel strip under the wooden packing pieces against the floor panel. This strip is not listed in the Moss catalogue and the Moss tech was not familiar with it. A picture is attached. The steel has been drilled to match the packing piece holes for the T-bolts used on the AH. I have 2 questions:
1. Has anyone else seen or used these steel strips under the packing pieces and would they go below or above the carpet; and
2. The wooden packing pieces are longer than the seat sliders. Should they be trimmed to the same length as the sliders?
Doug Cavil
Gabriola lsland, BC
Doug Cavil
Gabriola lsland, BC
