Seat foam
Rhodyspit75
I am planning to buy new seat covers for my Spitfire. I can't bring myself to pay the price for new foams and I'm bored so making them myself would take my mind off the cold and snow. Has anyone made there own? There is enough left of my original foams to use as a model but I'm not sure what type of foam to use.
I've seen guys in an auto upholstery place use electric carving knives to shape the foam.
https://www.bigolbear.com/images/SPITFIRE SEATS.ppt#257,2,Slide 2
This link is pretty good reference to use in dismantling and recovering the seats.
I am doing EXACTLY the same thing.
I bought High Density foam remnants at a local JoAnnes fabric shop.
Looks like it'll be quite the project, but all the DIY websites I've seen have used a simple electric knife for shaping and a bandsaw for cutting.
I uncovered the driver's seat last night and the thicker foam in the seat backs disintegrated into powder. I'll use a 3" piece of foam to carve that section, then regular 1/2" HD to pad the rest.
Welcome to Rhody and TD!!
Rhody, I lived in Pawtucket for a long time and I'm now just over the border in MA.
Are you a member of CCBCC or NET or BMCNE?
I had Eddie at JT Leddy on Central Ave re-pad my original TR6 seats. He did a great job for less than the kit costs. He's now making customer seat trims in matching Chestnut, to fit the Miata seats that I bought for my TR6. That project is here: Miata Seat Conversion
Welcome guys! TD - never thought about the ban saw. Great solution. I have 2 foam sets and 2 seat cover sets to get to before spring. I asked my wife if she'd do them and she said Yes!
I need to prep the frames and locate the webbing and clips again... Anybody?
I am going to redo my seat this spring also. I had spare foam laying around a tried my hand at the shaping thing. Maybe it was my knife but it seemed it would drag alot.
Im in the process of rethinking the process and may do a layer of the memory foam to insure a prefect fit and comfort.
I will be watch and see how you make out.
Gave it a try last night...however no pics, and not a lot of progress a bit chilly in the garage. Apologies for a long post...
I found that in order for the "Turkey carver" to work well I had to approach the cut at a perpendicular angle, then turn into the carving once into the foam.
I took the old seat foam remains, laid them flat on the new foam, drew around it with a sharpie marker. I left everything approx. 3/8" bigger than the mark so it would fill the covers. Plus because the old foam had powdered I had to guess a little.
Began the cut square to the foam and worked around the rounded edge.
Very much like cutting wood, start from a square shape, then cut down corners to create filets. Used three inch HD foam for the bolsters, then layered on 1/2 foam across the face.
The only real problem I encountered was gluing the new bolsters to the old seat back because of the powder remnants. I had to literaly wire brush the old stuff off to get to solid material for the glue to adhere.
I used 3M spray adhesive. Sprayed the touching sides on both the old and new, and squeezed them together.
I have the drivers seat back glued up, complete with new burlap backing @ 2.99 a yard. It does not look like professionally built foam, but once in the upholstery, it should fill it out nicely.
As far as the webbing goes, so far the Spit's have been fine, but on my MGB I used tie down strap. 1 1/2" wide nylon strap like that used in cheap ratchet straps. Cut to length plus 3 inches. Once the end is wrapped through the wire hooks, I used a hot awl (16 penny nail) to melt two holes and used 2 rivets with washers, rather than sewing. Just as strong as a line of thread, and easier for me to accomplish in the garage. YMMV. I just cut the old webbing off the existing hooks and reused the hooks. But I imagine that they could be made as well, just think miniature coat hangers...
Show us some pics if possible. We love pictures mouth breathers that we are.
Same process is in my immediate future, and I was wondering....
Was in the local "can't sell it anywhere else" store the other day, and they had 1 inch thick sections of that "memory foam" that they use for mattresses.
HMM,
Wonder about putting a layer of that under the seat covers.
Thoughts?
It does not have the same ability to bounce back after constant compression that regular seat foam does. That's why the people who buy those mattresses are so P/O'd after 5 or 6 years.
I always said if it was good enough for the astronauts that was great. But they didn't sleep up there every night for years and years.
Interesting to hear this stuff, not sure if I am going to go this route, haven't taken the covers off yet, but new foam (even on sale now at TRF) seems awful expensive for some cut foam. Not saying it is a rip off, no idea what goes into setting up to make a batch of foam, but I I need some I will probably try my hand at shaping it myself as well, thanks for the info on it.
I think most of the cost of the seat foams is in the cutting and assembly, which is all by hand. I have brand new foams in my basement, don't ask me how much they cost, and how much I paid to get them here, but on hind sight, I think I would have bought one set, and used that as a correct pattern for the other one. A paint pot full of contact cement and away you go.
In regards to the carving knife - as a kid, I worked in a shop that built interiors for trucks, boats and campers. I worked as a vinyl laycutter. We used Wolf saws to cut the foam and I recall using spray silicone on the blades to help them glide through the piles of foam. You might want to try it.
charlie74 Wanted Passenger seat replacement foam [‘74] Triumph Classifieds 0
G TR4/4A Go to seat springs or foam? Triumph 14
S For Sale TR6 New Moss 73-76 Seat Foam Kit Triumph Classifieds 0
Popeye Contact adhesive for open cell foam - seat rebuild [TR4A] Restoration & Tools 8
T Question on seat foam Spridgets 3
R TR4/4A Best seat foam kits for TR4a? Triumph 3
Zitch TR4/4A Early tr4 Seat refinish - horse Hair for Foam? Triumph 7
Got_All_4 Wedge TR7 seat foam Triumph 3
Tinkerman TR2/3/3A TR3A seat back, foam thickness? Triumph 1
W Spitfire spitfire seat foam and skins Triumph 4
B car seat cushion foam replacement Austin Healey 4
R TR4/4A Seat foam tr4a Triumph 4
W Seat Foam Triumph 12
M TR2/3/3A TR3 seat rebuild Foam VS Springs Triumph 7
M Seat foam or cushions Spridgets 6
T Any strong feelings on Moss vs VB vs TRF seat foam Triumph 7
D Midget Seat back foam replacement Spridgets 7
B TR6 TR6 seat foam Triumph 7
jollyroger GT6 1970 GT6 seat kits and foam Triumph 9
D Midget seat foam replacement Spridgets 2
PATR8 Wedge TR8 Seat Foam replacement Triumph 20
PeterK TR2/3/3A TR3 seat rebuilding with foam. Triumph 4
DanNagy Seat Foam Triumph 16
M Seat Foam Spridgets 8
B T-Series Plastic disk switch encased in seat bottom foam?? MG 11
kc_doyle Spitfire seat foam for 71 Spit Triumph 6
71TR6 TR6 TR6 Seat Foam Kit Triumph 2
tahoe healey seat foam Austin Healey 2
Paul Slice VB Seat foam MG 1
W TR2/3/3A TR3 Seat Belts Triumph 3
C MGB Re strapping a MGB seat bottom MG 2
T TR4/4A TR4 seat buffer problem Triumph 5
Scotsman TR4/4A Moss seat covers for TR4A missing spring tensioner pocket Triumph 0
A MGB Seat Cover Installation MG 1
tr6nitjulius For Sale 4$ale: 3 Point Seat Belts Red Triumph Classifieds 0
D TR2/3/3A layout for lap type seat belt Triumph 5
R Vixen 2500 Seat Buckets TVR 3
TunaJ Will MGB Upper Seat Runners work with Midget seat rails? Spridgets 1
Celtic 77 MGB Seat webbing replacement. MG 1
B BJ8 Seat Sliders Austin Healey 4
D TR2/3/3A tr3a occasional seat padding Triumph 10
TomMull MGA Rumble seat MGA MG 3
T Three-Point Seat Belts Austin Healey 8
B Seat Inserts Austin Healey 6
Michael Oritt Best Seat Trim Adhesive Austin Healey 8
Celtic 77 MGB Seat Diaphragm replacement MG 0
D New seat covers Spridgets 11
