Sealing the gear carrier to the rear axle case ?
Ed_K
I have just recently installed a new pinion seal which has completely stopped the leaking from around the pinion shaft. Now that the gusher has been stopped, I can see that I also have some leaking around the gear carrier / front case. I will check the twelve nuts to make certain they are all tight but if they are all tight, Is it possible to loosen them all up and split the front carrier /case away from the main case say about a 1/2 inch in order to clean the surface and then reseal it with a bead of form-a-gasket ? Or will the inards fall loose inside the rear axle ? ... Nothing worse than loose inards !
Any other suggestions how to seal it back up while it's in the car ?
Thanks,
Ed K.
Re: Sealing the gear carrier to the rear axle cas
Hi Ed,
You can't get the carrier out at all without removing the axles. With the axles pulled out a few inches the carrier is free to be removed. No loose parts to worry about. If you go this far, just as well remove the carrier completely, replace & seal the gasket. There is supposed to be a paper gasket in there, you know. I've had good luck with Hylomar on the gasket.
While you are in this far, just as well replace the outer wheel bearing seals, axle flange gaskets, & O rings.
OR
Just put up with the leak. You already know that there is no stopping point once you start messing with it.
Thanks Dave.
I guess if the twelve nuts are tight, I'll pull the axle shafts. I'll probably wait until I replace the leaf springs and mounting hardware if I need to pull the shafts.
Good plan. Pulling the axles & getting everything back together is a whole 'nother experience.
Ed,
Many years ago I had to stop the leak on a chevy rear end and this did the trick without taking the whole assemble apart. I loosened the bolts just like you are talking about, created a gap, wound kite string around the bolts in the opening, soaked it well with form-a-gasket and tightened the bolts. It did not leak a drop! This is, of course, just until you want to take it all apart and do the work you mentioned.
Charlie
Great idea !
If the case will crack open at all with the axles still
in.
Yep ED, it will crack just a might. Along with these interim suggestions you might carefully look at the lower bolt locations sometimes the leaks appear only around the bolts which can also be treated from the outside by just losening the nut, which staves off removing the entire assembly.--Fwiw--Keoke
P.S. That string trick is cute!!
Now that you mention it, I think it was only leaking around the bottom. I'll take a closer look. It would be nice if I could get away with loosening the nuts and sealing them instead of having to take the rear axle shafts out !
It was another sunny day today so I just had to drive it instead of work on it today !
/ubbthreads/images/graemlins/driving.gif
B Steering Column Wiring/Sealing Austin Healey 1
D TR2/3/3A sealing master cylinder pocket Triumph 8
dbenichou289 TR2/3/3A Carb Sealing Ring Triumph 6
T TR6 TR6 Carb Gasket Sealing Triumph 1
G TR4/4A Rear Oil Galley Plug Sealing Triumph 21
nichola TR6 Classic Technologies front sealing block Triumph 7
D TR2/3/3A Hints on sealing the sump gasket. Triumph 28
BoyRacer Fuel tank sealing rubber is too thick Austin Healey 3
BN6_2197 Sealing my legroom Austin Healey 11
G TR2/3/3A sealing body seams? Triumph 12
B General Tech Wire wheel sealing bands? MG 4
T TR4/4A Replacing in situ oils sealing gearbox and rear axle Triumph 18
M TR6 Front sealing block Triumph 11
KVH General Tech Sealing Fuel Line at the Pump: TR4 Triumph 12
D TR2/3/3A Sealing Fo8's and Wet Liners Triumph 6
NutmegCT Gasoline resistant sealing tape? Restoration & Tools 3
T TR2/3/3A TR-4 Sealing Block Triumph 2
Tinkerman TR2/3/3A Sealing fender to body 1960 TR3A Triumph 15
S TR2/3/3A Wire Wheels Sealing Triumph 17
N Spitfire Spitfire sheetmetal prep and sealing suggestions wanted Triumph 2
PatGalvin TR2/3/3A TR3 Engine Front Sealing Block, Oil Pan Screw Size and Thread Pitch? Triumph 11
R removing black seam sealing Austin Healey 3
C Sealing Healey clutch fitting on brake reservoiur Austin Healey 13
TRMark Being my own DPO, stripped front sealing block Triumph 6
Nelson Sealing exhaust pipe junction Spridgets 14
KVH TR4/4A TR4 Front Sealing Block Triumph 2
I Sealing new outer panels on BN1 Austin Healey 10
T sealing oil leaks in a horizontal joint Spridgets 6
O TR2/3/3A TR3 Winshield Sealing Triumph 9
hondo402000 TR6 TR6 Gas tank Sealing Triumph 5
A Sealing exhaust leak - help! Triumph 20
S sealing shim pack Triumph 2
Brosky Sealing blocks are available again Triumph 5
LastDeadLast Brosky - Front sealing block info? Triumph 15
I Bugeye gas tank sealing ring help Spridgets 2
MTribe special bolt for copper washer on sealing block? Triumph 2
Brosky Sealing of Saddle Block in front of engine Triumph 7
steveg Rear Engine Plate sealing question Austin Healey 8
B Sealing block and good thrust washers Triumph 5
J What kind of compound to use as wing2body sealing Triumph 6
A Vent window & waist moulding sealing correct BJ8? Austin Healey 6
PATR8 Windshield sealing Triumph 2
Nunyas Sealing a vented oil fill cap MG 6
G Sealing Block Triumph 6
cdsmith "sealing" gas tank sending unit Spridgets 8
Hegg Engine Rebuild Advice: Painting, Sealing, Assembly Triumph 7
tr6web Sealing, lubes, etc. Triumph 8
BierRunner TR6 Gear Shift Knob Challenges Triumph 4
L T-Series Gear box servicing cap. MG 5
