TR2/3/3A Scuttle / front fender attachment
LionelJrudd
Could someone please describe for me the shape of the lower section of the scuttle which the rear of the front mudguard attaches to.
The section on both sides of my car are not complete due to rust and damage. In remaking this section, I made it as I thought it should be but now checking the top rear of the mudguard that attaches to it, I am not so sure.
The original right hand scuttle section. The section I am concerned with is the bottom left section in the photo below.
The section from the inside as I made it. I have not cut the vertical release to allow the mudguard bolt to slot into place at this point. The concern I have is the shape of the right hand side of this photo to match the left side in the above photo.
The rear top of the right hand mudguard. I thought there would be two bolts to go into slots but the guard only has one rear bolt.
That large round hole at the top right hand side is the access to fit the one rear mounting bolt. You need blue tack in the 7/16 socket to hold the bolt while you try to fit it without it dropping to the bottom of the fender, i believe most don't go to the trouble of fitting that bolt?
I always install that bolt...
Anyway, I am a little confused about which panel you are working on specifically, but here are a bunch of that area. Hopefully one or two will show what you need.
John, your first few photos above show what I am referring to. You welded in the patch on the right to recreate the right angled slot that takes the bolt which can be accessed via the hole in the interior kick panel.
What is the single slot on the left for as there is no corresponding bolt / nut on the mudguard?
Lionel, I have been reviewing all my pictures, and I cannot see any reason for that slot. It was factory, as it was included on both sides of the car in the same spot, but I do not remember any use for it. Possibly to give clearance for the wing rear, vertical mounting tab??
I think that must be it. Once the vertical door-jam metal is added, that angled slot is in a perfect position to provide a relief to the vertical tab on the rear of the wing. Here are a few more pics. The last one shows how the tab relates to the door jam, once the jam is installed.
Yes John the top of the A pillar fits in that slot. I think the sloted hole for the fixing bolt could have been to allow for the bolt to be fitted into the fender before it is lifted into position probably to make it easier on the assembly line?
Graham
It all makes sense now. Just got to remember to cut the hole in my new kick panels to allow access to the bolt before I weld them in place.
Thanks for all the input guys.
mctriumph For Sale Tr2/3 scuttle mechanism Triumph Classifieds 7
B For Sale BaulyCars - Scuttle Vent Cover Triumph Classifieds 0
71TR6 TR2/3/3A TR3A Scuttle Rim Question Triumph 4
F TR2/3/3A starting scuttle repair Triumph 27
J TR2/3/3A Wooden piece under scuttle with dash Triumph 6
C TR2/3/3A scuttle vent Triumph 6
steveg Steering column steady brace and scuttle shake? Austin Healey 2
D TR2/3/3A Scuttle uneven on one side Triumph 12
Darwin Spitfire scuttle vents Triumph 0
M Scuttle shake. Austin Healey 16
D Scuttle shake and tyre pressures Austin Healey 2
R More Shroud to Scuttle install Austin Healey 4
Jake For Sale Denis Welch aluminum works shroud scuttle vent scoop - $175 Austin Healey Classifieds 0
N TR2/3/3A TR3 Scuttle Vent Triumph 19
N TR3 scuttle vent FORUM Navigation Questions 1
C TR6 Scuttle lid spring? Triumph 6
P TR2/3/3A TR3A Scuttle/Windscreen Stanchion questions Triumph 12
D TR2/3/3A TR3 Scuttle Vent knob removal? Triumph 2
B Scuttle shake finally sorted Austin Healey 23
PAUL161 T-Series Scuttle Shake/Vibration MG 6
B How do wipers mount to scuttle top on a 100-6? Austin Healey 16
J Door/scuttle rubber seals Austin Healey 2
AHS TR2/3/3A Can someone please measure the scuttle vent door link length? Triumph 2
S Scuttle Liner/ Footwell Cards Austin Healey 10
S Scuttle Shake Austin Healey 95
H clear coat question on scuttle Austin Healey 7
PatGalvin Scuttle Vent Rubber placement Triumph 4
5 The scuttle shake mod- I can't decide Austin Healey 7
steveg Scuttle Seal installation article Austin Healey 2
O TR2/3/3A TR3 Windshield to Scuttle Mounting Triumph 1
M Sebring Scuttle Vent Austin Healey 3
D whats causing my SCUTTLE SHAKE !!!! Austin Healey 39
H Scuttle Seals Austin Healey 2
curtis BN2 scuttle seal Austin Healey 13
luke44 TR2/3/3A TR3 Scuttle Vent Assembly Triumph 4
richberman Scuttle Shake solutions, necessary? Austin Healey 24
tomshobby TR6 putting scuttle door on 76 TR6 Triumph 9
H TR2/3/3A TR3A-Scuttle Vent Ass,y - Parts Missing Triumph 3
luke44 TR2/3/3A TR3 Scuttle Vent Disassembly Problem Triumph 6
C scuttle vent linkage Triumph 4
H TR2/3/3A TR3 Scuttle Vent Questions Triumph 3
ekamm scuttle knob Triumph 6
M TR2/3/3A Tr3 scuttle mechanism Triumph 2
S TR6 76 TR6 Scuttle Vent Triumph 16
O TR2/3/3A TR3 Scuttle Panel Still Needed! Triumph 5
O TR2/3/3A TR3 Scuttle Panel Triumph 8
G Scuttle Vent Adjustment Triumph 1
Tinkerman TR2/3/3A Scuttle Vent Installation TR3A Triumph 4
mjobrien Chassis to Scuttle - Gasket - Filler - Foam? Austin Healey 13
TonyPanchot TR5/TR250 tr 4/ 250 scuttle vent gasket Triumph 7
