Rubber Gasket - What's it Fit?
It fits inside that wrapping. If it could be seen the real answer would be easier.
I thought that someone could tell me by the part number.The plastic
is sealed at both ends.
If I don't get a response,I guess I'll have to open it up.
Looks like it could be THIS header seal. A cross-section photo would confirm.
K TR2/3/3A TR3...Gas cap rubber gasket/seal in cap lid? Triumph 1
jvandyke rubber as a gasket Spridgets 8
Brooklands TR2/3/3A Spare Wheel Door rubber gasket - TR3 Triumph 3
D For Sale GT6 Rotoflex Axles: clean, beadblasted, coated with POR15, excellent rubber couplings. Triumph Classifieds 0
K TR2/3/3A Exhaust bracket rubber "top hat" bushings? Triumph 3
L Red Rubber Brake Grease Austin Healey 2
C MGB Rubber Bumper cover removal MG 5
ModifiedBJ7 BJ7 Windshield Surround Rubber Seal Austin Healey 2
D Top Door rubber and fuzzy seal Spridgets 5
algot1901 1950 Prefect E93A-946480 - door bottom rubber Other British Cars 14
algot1901 Weather stripping and rubber parts Other British Cars 1
LAW75 Rubber Tubes for Choke Cable Austin Healey 11
B TR4/4A Rubber wiper motor mounts Triumph 4
BoyRacer Rubber Fender Buffers Austin Healey 2
S TR2/3/3A Cutting the finish end on the windshield top rubber Triumph 4
T How do you secure your door rubber trim? Austin Healey 9
W Spitfire Hard Top rubber Triumph 5
T Windscreen wiper wheelbox rubber shaft seal Austin Healey 4
K TR2/3/3A Upper shock mounting rubber bushs ? Triumph 1
B TR2/3/3A Windshield Wiper mount rubber Triumph 3
M Quarter light rubber replacement Austin Healey 6
Rut Windshield rubber seal Spridgets 6
S TR2/3/3A little rubber plugs Triumph 3
S TR2/3/3A rubber seal go towards the inside of the trunk Triumph 3
I Best glue for rubber door panels? Spridgets 3
S TR2/3/3A vent lid rubber Triumph 11
BoyRacer windshield wiper motor rubber mounting grommets Austin Healey 9
AUSMHLY Rubber hoses; heater box and valve cover breather Austin Healey 2
warwick-steve Front suspension rubber trunnion bearing question Austin Healey 4
BoyRacer Fuel tank sealing rubber is too thick Austin Healey 3
C Spitfire Rubber bumpers Triumph 3
C Installing rubber grommets in firewall? Austin Healey 6
T TR2/3/3A Will cable ties hold rear axle rubber buffer securely? Triumph 7
S TR2/3/3A rubber O rings that go around the gauges Triumph 5
pa297pass TR4/4A TR4 wiper motor rubber mount installation. Triumph 7
Bob Claffie Rubber Bumpers Spridgets 3
Rob Glasgow Hard Top Rubber Seal Austin Healey 3
KVH TR4/4A Rubber Door Gaskets Triumph 8
D TR6 1976 TR6 - Can Rubber Guards be Removed from Bumpers? Triumph 9
Lin BT7 furflex/rubber door seals Austin Healey 17
R TR2/3/3A Replace Rubber bushings in front suspension Triumph 11
D MGB Painted rubber bumpers. How long will they hold up? MG 1
6 For Sale 1960 Bugeye Survivor for Sale with Original Rubber Mats Spridgets Classified 0
G Wanted Packing pieces on rebound rubber engine mount Austin Healey Classifieds 0
G Packing pieces on rebound rubber engine mount Austin Healey 5
Kleykamp Rubber bumper Midget value? Spridgets 5
JPSmit Rubber Bumper MGB Spotted 0
Tinkerman TR2/3/3A Wiindshield - top rubber seal. Triumph 3
Boggsy64 MGB Gauge face rubber MG 2
