Right Oil for BN1 axle and gear box
LuckyLuke
What oil is best for the axle and gear box? My owners manual says W140 for axle, some say W90
Keoke, or Dave Russell, I got some LucasOil for the steering box, can that be used in the rear end of a BJ8?
Yes if you obtained the 80/140 Plus--Heavy Duty Gear Oil.---Keoke
You might be OK to add the 90W to the Hypoid?
If your BN1 has the later hypoid gear axle (after C#221536 with 2.25" wide rear drums) any gear oil SAE rated GL-5 in 80W-90 should work in the axle. The sulfur found in GL-5 oils is a pressure resistant additive which helps protect the hypoid ring & pinion gears which are under a lot of sliding pressure. GL-4 rated oils do not have this high sulfur content. If your axle is the older spiral bevel type, it does not have as high sliding pressures & GL-4 oils should be OK.
For the transmission the factory originally recommended SAE-30 engine oil. Many folks run SAE 20W-50 engine oil in the transmission. A few prefer Red Line MT-90 in the transmission. These are NOT GL-5 rated high sulfur oils. GL-5 oils with high sulfur content are thought to degrade the brass/bronze components found in the transmission/OD's.
Because engine oil & gear oil are viscosity rated at different temperatures, 20w-50 engine oil & 80w-90 gear oil are actually fairly close to the same viscosities.
In reality, if you aren't putting a lot of hard miles on the car, any oils in any location would probably "get by".
J MGB Oil Pressure Gauge Gives Constant Reading -- Doesn't Seem Right MG 15
G Right-Side Shock Weeping Oil Austin Healey 1
C TR2/3/3A Right oil Triumph 8
jdubois TR2/3/3A Should be oil in a TR3A steering rack, right? Triumph 16
B Wanted Early BN1 Right Hand Sidescreen Austin Healey Classifieds 0
J For Sale Triumph TR2 TR3 rocker panels, right and left Triumph Classifieds 0
K TR2/3/3A Update on the head gasket repair......something is not right/ Triumph 8
B MGB while driving engine cuts out if I let off or push more throttle it comes right back on MG 5
C MGB Which Weber DGV is the right one. MG 14
P Jag XJ8 starts but then dies right away. Jaguar 4
Popeye General Tech O/D right angle drive choices Triumph 10
L Wanted right front turn signal 1975 TR6 Triumph Classifieds 2
BritBite Speedometer Right Angle Drive Austin Healey 5
drooartz General MG Surprisingly enough, I was right! MG 7
A SOLD!! TR3A Girling Type A brake caliper for right front Triumph Classifieds 0
5 Wanted Wanted Parts to convert BN2 from left hand drive to right hand drive Austin Healey Classifieds 0
71TR6 TR2/3/3A Right Front Suspension Damage Repair? Triumph 50
TRclassic3 TR2/3/3A Body leans to right side Triumph 10
red57 Steering not right Austin Healey 66
B For Sale Brand New Black Tonneau Cover for BN4 and BT7 - for Right Hand Drive Car Austin Healey Classifieds 0
dougie Big Healey Six - Used the Right Way Austin Healey 5
John Turney The Panhard Rod is Supposed to be Straight, Right? Austin Healey 7
Bayless What are symptoms of steering rack not shimmed right? Spridgets 14
T For Sale GT6 Mark II Right Front Fender - NOS Triumph Classifieds 0
S Wanted Source for 100 6 right hand remote control door regulator Austin Healey Classifieds 1
C Left to right hand drive Austin Healey 2
T Wanted 1960 Jaguar MK2 front door wood trim, both right and left. Jaguar Classifieds 0
T TR6 grinding right rear wheel Triumph 22
5 Wanted Wanted Parts to convert BN2 from left hand drive to right hand drive Austin Healey Classifieds 1
Rut TR4/4A Nice project for the right person Triumph 0
JPSmit Fuek Tank Sender - does this seem right to you? Spridgets 3
D BJ8 pulls right on hard braking? Austin Healey 4
Simmo TR6 Right Hand Drive Conversion Help Triumph 3
Jim_Gruber 13" Tires - What's out there right now Spridgets 21
Popeye TR4/4A Seats - left/right Triumph 8
TomMull Post-War Other Herald 13/60: I didn't get the battery tray quite right Triumph 4
J BJ8 Vacuum Advance - disconnected -RIGHT - when setting total advance?? Austin Healey 6
Simmo TR6 Right Hand Drive conversion Triumph 5
T TR4/4A This head gasket doesn't look right to me - cooling passanges partially blocked? Triumph 18
Zimmycobra TR4/4A Who's right - float height on ZS 175CD? Triumph 5
M TR2/3/3A Engine does not shut off right away. Why? Triumph 8
spartan0199 BT7 Right Front Brake Drag Austin Healey 30
S TR2/3/3A right to the wheel well Triumph 10
T TR4/4A Making Miata seats in a TR4a look more "right" Triumph 4
Got_All_4 TR2/3/3A 2 questions; raising the body and taking out that lean to the right Triumph 12
Jim_Gruber NOS 10 Post BE Windscreen on E-Bay right now - NFI Spridgets 3
S TR4/4A water pump doesn't feel right Triumph 2
W TR2/3/3A '56 TR3 St 15000+ should have disc brakes... Right? Triumph 33
P T-Series TD Door Hinges: just what is the difference between right and left? MG 10
RickB MGB HS6 or HIF4 bolt right on in place of Stromberg? MG 6
