Red Light is off. Now a new roof.
mgbnew
Well all the suggestions were right on and thanks again to all that responded to my questions and concerns on that darn red light. New started being installed as we speak. /ubbthreads/images/graemlins/driving.gif I have a new question. Has anyone out there (I’m sure there are a ton) installed a new roof. I have the old frame which I am cleaning up and having it chromed. Is it a big deal? I was told it was fairly simple as long as you do it on a nice sunny day. What ever that means?? Any suggestions or tips?
Thanks, Al.: cheers:
Keoke
[ QUOTE ]
[/ QUOTE ]
Yep mgbnew; It means that the "Roof's" -{Hood's} material will become flexible enough in warm sunlight for you to work it easily.---Keoke
dklawson
Classic Motorsports did an article earlier this summer with tips & tricks for installing new tops. I didn't keep the magazine but you may be able to Google to find out which issue it was in and ask members here if anyone has a copy of it.
MGretired
I wouldn't have the frame chromed, it takes a beating in normal use, I don't think the chrome will last. Doesn't show anyway, a good paint job will suffice.
FWIW
mgbnew
mgbnew
Thanks for the info. Your right I will clean it and paint. /ubbthreads/images/graemlins/cheers.gif
Bawanadic
Be sure that you take care when mounting your new top to the front header. Both of mine had PO's mods to fix(?) the top from coming off.
One of them had marine glue holding it down along with the header seal (lovely snot green bead was a dead give away) and the other they used some generic rivets to hold it to the header and it newer went on the same way twice.
I also check the rivets that hold the frame together. If there is too much side to side play they don't operate well.
I think I bought a kit from Victoria British when I redid one of them but that was about 3 years ago.
I'm experimenting with a custom landau type top. ( Kind of like the Porshe 914 removable top. ) but the prototype is giving me fits. /ubbthreads/images/graemlins/pukeface.gif
mgbnew
mgbnew
Thanks for the heads up and advice.
J TR2/3/3A Red ignition light stays on Triumph 7
K TR2/3/3A Red ignition light stays on...car has alternator not generator. Triumph 17
K TR2/3/3A TR3 with alternator conversion... red light stays on and low voltage on the voltmeter gauge? Triumph 1
WJKB-TR6 TR6 '73 Ignition [IGN] Red Light questions. Triumph 6
S TR2/3/3A generator red light deal Triumph 6
K TR4/4A Green and Red Warning Light Removal from Dash? Triumph 5
K TR2/3/3A TR3 red-light on dash again Triumph 5
K TR2/3/3A TR3 Red dash light stays on? Triumph 4
K TR2/3/3A Red ignition light stays on...TR3? Triumph 6
J Red "brake" light always on Jaguar 5
M Red dash ignition light glowing very little Spridgets 16
K TR2/3/3A TR3..Red light On...Dynamo Connector Triumph 5
K TR2/3/3A Fired up the TR3...Red light on? Triumph 8
RickB Red idiot light on bright - ideas? Spridgets 33
S idiotic red light question Spridgets 7
zimmy progress.....red light OUT...next....oil pressure? Spridgets 9
B TR6 TR6 red brake light len- left side Triumph 9
zimmy red light on dash Spridgets 6
mgbnew RED LIGHT = LOW BATTERY CHARGE??? MG 13
mgbnew Regarding red light on dash MG 8
mgbnew Red light on dash board MG 13
jcatnite Red Light on Dash Spridgets 22
L Red Rubber Brake Grease Austin Healey 2
tr6nitjulius For Sale 4$ale: 3 Point Seat Belts Red Triumph Classifieds 0
dwpirkeyjr Red? Bue? Purple? Yellow? Poly Bushings Complete Set For 1979 MG midget 1500 Spridgets 6
C Spitfire Red painted engine number Triumph 3
AngliaGT Red MG Spotted 0
K TR2/3/3A Girling red grease that used to come with brake cylinder rebuild kits? Triumph 7
TR6Canuck TR6 Wire spoke rims to fit Michelin Red Line Tires on TR6 Triumph 12
B TR6 Source for Carmine Red Triumph 4
boxofparts TR2/3/3A TR3 Spotted Petoskey Michigan Red and Wedgewood or Powder Blue Triumph 1
J For Sale For Sale - 2x TR6 seats in red vinyl - Best Offer! Triumph Classifieds 1
Leatherman Wanted Red and black TR2 / 3 front emblem Triumph Classifieds 6
J For Sale Early 70s TR6 seats in new red vinyl, with new tracks, $500 OBO Triumph Classifieds 0
T 1993 xj v12 red hot catalytic converter Jaguar 6
C How best to restore red script on valve cover? Austin Healey 7
M TR2/3/3A Red or Blue Loctite Triumph 1
S TR2/3/3A installing a fuse in the red tail lights Triumph 4
T Radiator Shroud "Chinese Red" Match Needed Austin Healey 10
G For Sale TR6 Matador Red Interior and Boot Triumph Classifieds 0
Joe Schlosser Red Samples Spridgets 5
Alfred E. Neuman Red MGA MkII Spotted 1
RAC68 Clutch Still Slipping after replacing 30W-Non-Det. for Red Line Austin Healey 52
T Red TR3 on the Bachelor Spotted 1
HealeyRick "Cherry Red Austin Healey" Austin Healey 8
JPSmit Red Rubber Bumper Midget Spotted 0
H Red radiator guard reattachment question Austin Healey 10
C For Sale 1965 TR4 Red - Black Interior Triumph Classifieds 4
T Colorado Red Vinyl Interior Austin Healey 6
