Iam trying isolate the cause of a niose that sounds like a loose panel or knock from under the rear driver side.I blocked up the rear tires and although I suspected the exhaust pipe the noise was less when I lossened the rear shock to spring plate bolt and held it while bouncing the car.The shock seems to work when bouncing the rear,full of clean fluid,no leaks mounting bolts tight.
So questions are-
Are these shocks known to knock?
Who would be good source to order rebuilt and then send in core after swap?
Thanks
Tom
So questions are-
Thanks
Tom
