Rear end is cocked
eskimo yo-yo
Hey guys, I was working on my rear suspension this weekend and when I got everything back together I noticed that the drivers wheel is closer to the front of the car than the passenger wheel? There are posts that go up to connect to the axle so I'm not sure how this can be. Figured I'd see if anyone had run into this before.
It sounds like you have the wrong leaf spring on one side. Or, is it possible that one side is installed backwards? I can't remember if that's possible, and I don't recall having to worry about this when installing my rear axle.
One other possibility; is the one side just closer to the fender or is actually closer to the front wheel? If the former, it might be some bad bodywork by the DPO.
Thanks Keith,
I removed a spring from each side and was surprised to see that the one pulled from the passenger side had about 1" less spring height in it. I also put together some lowering blocks. I'm going to check the length of the springs on each side of the axle right now.
You didn't say what car your have, but in my experience the rear springs for all big healeys do not have a front or a back section. So, you cannot install them incorrectly. However, there is a pin that goes into a hole in the springs and protrudes upwards about 1/4" that is used to locate the spring into the spring plate on the diff housing. If this pin is missing you cannot get the differential housing properly located. This could be causing your problem.
100/6
Found that the panhard bar wasn't allowing it to be properly located. I loosened it up and locked the rear end down, I'll be driving it later today to see how it goes!
S Rear End Noises Spridgets 28
roscoe Rear end crown and pinion gear swap. 4.11:1 to 3.54:1 [long read] Austin Healey 12
A TR2/3/3A Rear end locked up Triumph 6
John_Mc TR6 Twitchy rear end Triumph 18
maxwedge5281 Removing Complete Rear End From BN6 Austin Healey 5
Rut TR4/4A Rear end questions Triumph 8
H For Sale Rear end bearing and seal set Austin Healey Classifieds 0
R TR2/3/3A Lube for steering box, transmission and rear end Triumph 6
E For Sale Tr3 rear axle, rear end Triumph Classifieds 6
Rut MGB Rear end service MG 7
D TR2/3/3A TR3 Engine dumping Coolant out its rear end - HELP Triumph 5
Rut TR4/4A Which rear end ratio? Triumph 1
Jim_Gruber Bugsy IV - Rear End now Reinstalled - Yeah Spridgets 0
Jim_Gruber Decopnstruction of Rear End over, Reconstruction Begins Spridgets 4
Jim_Gruber Rear End almost out Spridgets 5
Scotsman TR4/4A How to fix sagging rear end. Triumph 8
PatGalvin TR2/3/3A Rear End Problem Triumph 22
SilentUnicorn 3.7 rear end Spridgets 6
Jeepster Wallowing rear end? Austin Healey 27
Got_All_4 TR4/4A TR4 Detroit Locker Positraction Rear End Triumph 6
bugedd Rear end noise [insert joke] Spridgets 11
tr7andtvr Wedge Tr7/8 rear end ID RKC0100 Triumph 4
tinman58 TR5/TR250 Very stiff rear end Triumph 27
D Posi-Rear end in a series 3 Jaguar xj6 Jaguar 12
Boggsy64 MGB Rear end washers easy MG 1
mt10flyer TR2/3/3A Rear End Klunky Triumph 7
R transmission and rear end oil Austin Healey 2
Jim_Gruber Reinstalling Rear End in a BE - Quick Steps Spridgets 8
J Possibly stupid question about drivetrain / rear end Spridgets 11
1 Jensen Healey Rear end / Rear Axle wanted -Texas or surounding preferably Other British Cars 6
bugedd Need some rear end education Spridgets 15
bugedd Limited Slip advice, scrapping idea of RX7 rear end Spridgets 34
Jim_Gruber Pics of how Rear End bolts into a BE Spridgets 21
J Last Step, Rear end: What is this one? Austin Healey 8
5 Uppity Rear End Austin Healey 6
M Replaced rear end, can't reconnect propshaft Spridgets 2
jsfbond My rear end Triumph 2
doughairfield Painting my rear end. Triumph 7
M looking for rear end gears for bj8 Austin Healey 25
6 HELP! something broke in the rear end... Triumph 71
A Rear end weight? Austin Healey 7
R TR4/4A tr4a irs clunking rear end on fast acceleration Triumph 7
Jeepster Dodgy rear end Austin Healey 16
jsfbond rear end alignment Triumph 11
G Looking for tranny & rear end help Triumph 3
G TR4/4A tr4 rear end in a tr3a Triumph 10
MgKid1974 Rear End Vibration... MG 3
M RX 7 Rear end option Spridgets 33
J TR 2 rear end axle seals. Triumph 8
T BE Phantom Rear Axle End Play Spridgets 0
