Positive to Negative Conversion
PeterB
Do I flash the generator with the key on or off when I am doing a Pos to Neg ground conversion?
Thank you,
Pete
M BJ8 Positive-Negative Ground Conversion Austin Healey 7
memphis Positive to Negative Conversion Austin Healey 2
M Positive to Negative Conversion Spridgets 3
66healey Positive to negative ground conversion Austin Healey 2
jvandyke positive to negative ground conversion Spridgets 11
R Positive to Negative Ground Conversion BJ8 Austin Healey 3
S Positive Ground to Negative Ground Power Inverter Austin Healey 11
doc50 Nash Metro Positive to Negative Ground Other British Cars 2
M TR2/3/3A Positive or negative ground? Triumph 6
Jim_Gruber Am I set up as Positive or Negative Ground? Spridgets 12
M Question about positive vs negative ground Spridgets 13
M_Pied_Lourd TR2/3/3A Identifying positive or negative ground.... Triumph 14
T TR2/3/3A LED tail lights for TR3A and positive vs. negative ground Triumph 11
P TR4/4A Positive/Negative Earth Dilemma TR4A Triumph 11
C Positive or Negative Earth Triumph 15
E Positive ground or Negative ground. What have you? Austin Healey 12
S positive and negative ground Triumph 7
T TR4/4A TR4a positive earth to negative cut over? Triumph 9
I Bugeye-better to have negative or positive ground? Spridgets 17
T TR4/4A TR4a positive or negative earth? Triumph 17
newmexTR3 positive/negative ground coil question Triumph 14
Newkie Converting Positive ground to Negative ground MG 4
Magyar How to convert from positive to negative ground? Spridgets 10
athenssprite positive to negative ground Spridgets 4
mine Positive convert to negative ground? Triumph 15
S positive and negative ground MG 59
Michael Oritt Battery Jumping Negative/Positive ground cars Austin Healey 31
Ohiobugeye Positive Ground to Negative Ground? Spridgets 12
T ground negative, positive Spridgets 6
R Positive to Negative Ground Issue Austin Healey 6
Y Positive Vs Negative ground + Alternator Vs Generator Austin Healey 1
M positive to negative ground Austin Healey 3
Y MGB Positive Battery cable? MG 7
B Positive-Ground LED Light Strip Austin Healey 8
P General Tech Positive Earth?? Very confused. A little help? Triumph 19
V MGB Never occurred to me that my '66 would be positive ground. Does the presence of an alternator show that it's been converted? MG 22
red57 Positive Ground Radio Austin Healey 18
S Wanted Original Style Positive Ground Radio Austin Healey Classifieds 0
apbos Positive Ground Alternator wiring. Spridgets 9
6 Relay wiring positive ground Spridgets 4
M 66 ā€˜ BJ 8 Positive ground identification Austin Healey 4
R TR2/3/3A Positive-ground LED lights Triumph 13
Sopwith_Camel positive camber xj Jaguar 0
S TR2/3/3A Positive Ground Question Triumph 2
Marla TR4/4A Positive ground inverter Triumph 9
P Jump starting a positive ground BJ8 Austin Healey 4
K TR2/3/3A Converting to Positive Ground....... Triumph 1
B Smiths RVI Positive Ground Tachometer Bench Test ? Austin Healey 24
drambuie Converting a smiths clock to positive ground Austin Healey 12
DanLewis Correcting positive camber in a Bugeye Spridgets 21
