Options, Looking for opinions....
Will_Ringrose
As the title sates I am looking for the opinion of a well more experienced LBC owner *cough* you old guys *cough* HAHAHA
Well with the Spun Rod bearing it marred up the crank and elongated the rod end. So I am left with 2 options.
I have the original motor that needs a complete rebuild. Or do I rebuild the motor that is in there now?
The motor that is in there now has a Lucas Distro from a TR6 on it. So the advance curve may not be what the 2L motor likes.
The Old Motor is a bone stock 73 Motor from the end of the production time frame.
Just sizing up my options.
Thanks Everyone!
Cheapest and fastest would be to turn the crank in the damaged motor .010 or .020, have all the rods re-sized and go from there. Second step would be to get the original motor rebuilt at your leisure. Distributor not usually a big deal one way or the other. Bob
jfarris Looking for service options for a 2016 Lexus NX300h in Tyson's Corner VA Other Cars 0
Jim_Gruber Bonnet Latches - Looking for Options Spridgets 13
V TR6 Looking for TR6 repower options. Triumph 10
RCarr Windscreen Glass Options Austin Healey 2
Frameman 1949 Tire Options Austin Healey 16
K Carburetor options for a 66 Austin 1100 ? British Motor Corp 3
boxofparts 100-4 Engine Options Austin Healey 12
AUSMHLY BJ8 Laygear Replacement Options Austin Healey 0
R General TR Spring collar flange thickness options Triumph 2
P BJ8 Frame Rust Options? Austin Healey 14
Csarneson Fuel pump options Austin Healey 10
glemon General TR TR250 Steering Wheel Options Triumph 6
55modified Need photoshop help for side vent options on my BN1 Austin Healey 6
M Muffler Options with Exhaust Header Spridgets 1
B Leaf Spring Re-build Options? Other British Cars 2
Michael Oritt 100 Oil Pump--options and resources Austin Healey 12
Rut TR4/4A Restoration options Triumph 12
steveg Piston options for Healey Austin Healey 12
R TR2/3/3A front hub seal options Triumph 9
M TR2/3/3A Clutch options Triumph 9
N Wedge '80 TR7 Alternator Options Triumph 2
cmacmillan TR6 TR6 grille repair - thoughts? Options? Triumph 6
K TR4/4A Fuel tank options Triumph 4
maxwedge5281 gas filler and cap options Austin Healey 9
M TR4/4A Dash support covering.....options? Triumph 5
K TR2/3/3A Dash panel light bulb colour options? Triumph 5
D TR6 Rear Shock Refurb Options 76TR6 Triumph 15
C AH 100 Best Options for front and rear suspension? Austin Healey 9
RedTR3 TR2/3/3A TR3 Crankshaft Options Triumph 10
H TR6 TR6 camshaft options Triumph 9
RJS TR4/4A Brake Master Cylinder Cap Options Triumph 11
I TR2/3/3A TR3 tire options Triumph 9
CanberraBJ8 Stripped thread on clutch slave cylinder mount. Options? Austin Healey 9
CanberraBJ8 fuel tank options? Austin Healey 12
jhorton3 Brake Pressure Sensor Options Spridgets 3
Lbp TR2/3/3A Options for TR3 Wiring Harness? Triumph 7
B Spitfire 79 Spitfire Bumper options Triumph 2
DerekJ Lightened flywheel options Austin Healey 62
cologero_100 BN1 Heater Assembly Options? Austin Healey 2
TR3sharon Cooling fan options Triumph 24
6 front hub options... Triumph 4
M Healey 100-4 Piston Options Austin Healey 1
Mychael Opinions wanted on carb options. Spridgets 15
W GT6 GT6 / TR6 Rotor Options Triumph 2
H TR2/3/3A TR3 heater options Triumph 9
T TR2/3/3A TR3B bolted wheel options Triumph 5
S TR6 71 tr6 exhaust manifold options Triumph 7
Boink Battery cut-off switch options... or??? Spridgets 10
R Overdrive/5 speed options for 1500 Midget? Spridgets 21
I Bugeye transmission options? Spridgets 11
