MGB-GT Next Project 1967 GT
Stewart
Been far too long since I've had a project. Thankfully this one should be fairly easy as the nasty hard dirty work was done. The car is very strait and not a bit of rust. Not sure when it was last on the road but judging by the cracking sounds the tires made as it was pushed down the driveway I'm sure Reagan or Carter was in office.
Mickey Richaud
Nice find, Stewart! The longer I have my GT, the better I like it!
Does look like you have an easy project. Have a color combination in mind yet?
:cheers:
Mickey
Platinum
That's great, Stew! There are times I wish we had a GT, the '67 is the last of the good ones, too, IMHO.
I'd put it together as close to box stock as possible. But I'm a traditionalist. :smirk:
Stewart
Stewart
Plans are to finish it off in red with a black leather with red piping seats. Not sure yet on what's going to happen with the engine but the trans will be swapped out for one with od. Wire wheels will be swapped out for 15" alloy knock offs but not the usual ones.
drooartz
That looks like a really nice, clean project.
I've been tempted by a GT on a number of occasions.
VTO's new alloy knock off should be available by later fall, and then there's always the bolt on wheel conversion using the same rear end housing, which is much less money than dealing with the splined hubs, and knock off wheels.
Stewart
Stewart
So far I've rebuilt the carbs, replaced the exhaust from the manifold back with a TT, refreshed the distributor, mounted the coil and fixed a miss wired ignition, flushed out the block, new t stat housing and stat, changed the oil filter to an inverted spin on, painted the radiator, installed a new fuel sender and a bunch of other little things. Still need to fix an air leak on the fuel pump and the tach doesn't seem to work.
Car was non op'd in 1986 and most likely hasn't been run judging by the state of the ignition.
<span style="color: rgb(51, 51, 51); font-family: Verdana, Helvetica, Arial, sans-serif; line-height: 20.46875px; background-color: rgb(221, 221, 221);">
Boggsy64
Hey Stewart, I watched you video above and when done there is a group of other Youtube videos that pops up. The one with the rear differential repair in particular caught my eye because I had watched it before. Did you do that video as well? If so I have a few questions for you.
Stewart
Stewart
The other video's are what ever youtube recommends and are not mine.
Yesterday I took it for a quick spin
[video=youtube;1t2MdZwVRGw]https://www.youtube.com/watch?feature=player_embedded&v=1t2MdZwVRGw[/video]
Stewart
Stewart
And now it's a non runner and in pieces.
Sent it on it's way to the body shop this morning and the work has begun.
drooartz
Funny how quickly a car can get to that point. Got to do something similar with my Bugeye's in the near future I think.
Going to keep the red or go with a different color?
Stewart
Stewart
It's going to be sprayed tartan red as it came from the factory that way. The red in the engine bay is pretty far off so it's going to be stripped and repainted.
Platinum
Looks too "orangey" on my screen. Had that '67 GT I mentioned earlier and it was Tartan Red. Black leather with red piping. Great car... up until one night when the engine grenaded on the Mass 'pike at 2200hrs.
Stewart
Stewart
I'm now committed to having the fender mouldings deleted and the shop found a bit of rust in the door.
AngliaGT
Stewart,
Looks good! I have a '67 GT also.Fun car to drive,
& seems to handle well.
I also have a TT exhaust on mine,but I feel that it's
a little on the loud side going down the highway.
When you're done,drive it up here.
- Doug
Stewart
Stewart
Body shop is moving right along. The dpo did a quick and dirty repair to the dog look but the rest of the car is looking good so far.
I took the head engine today and confirmed it's been rebuilt at least once in the past. The water jacket is pretty rusty and all of the ports to the head were blocked. I'm glad I didn't run it to long. The head looks pretty good and might just need a good cleaning however the intake on 4 looks like it's hit something at some point in its past. The engine has been bored out to 40 over and it looks like the job has some miles on it. Not much crosshatching visible and it looks like a bit of rust pitting has formed over the years.
Stewart
Stewart
Just about have the engine stripped down and just need to pull the front and rear main caps. Crank is 10/10 and most of the bearings looked great however #4 rod bearing was down to copper. More importantly the wheels finally came in :D
drooartz
Those the alloy Dunlop-style wheels? Love those wheels!
WillR
thanks for posting pictures of the engine as you go through. for me it take time after time of seeing things to familiarize myself with them and something like the intricacies of that motor may take a me watching a few people go through it before i feel comfortable. Looking god sir :eagerness:
D TR6 Researching potential next project car - Looking into TR6 Triumph 5
RickB Next project: Arkley conversion on a 73 Midget Spridgets 8
Stewart Next Project MG 13
vping T-Series Finally my next project - A 1952 TD MG 4
T OT - my next project Triumph 22
JPSmit My Next Project Other Cars 27
B MGB My next project MGB. 1969 MG 73
Glen_B just got the next project Spridgets 6
roscoe The next project Austin Healey 4
AUSMHLY The next project...the tune up Austin Healey 15
drooartz Next step in my dash project Spridgets 16
michalotti_tr Looking ahead to my next project ... Triumph 3
S Next Project 58 Sprite Spridgets 24
jaybird Got my next project MG 24
jaybird Next project MG 51
J Next project:: timing cover gasket and crank seal MG 2
J Next Thread? FORUM Navigation Questions 1
AngliaGT Anyone Plan on Attending the SCCA Runoffs at VIR Next Week? Racing 6
apbos The next rabbit hole. Help ID the chassis. Racing 27
drooartz MGB Front suspension rebuild is next MG 57
R General TR Emergency hot wire - because you never know whats next Triumph 2
S TR2/3/3A wood next to the door on a tr3 Triumph 4
F Three worn hubs and wire wheel centers - What to do next? 1960 BT7 Austin Healey 6
M Next job[s] on Otto - thoughts? Spridgets 35
H Anyone going to the Fall AACA Meet and Flea Market over the next several Days? Austin Healey 2
D TR2/3/3A The next stage of reassembly Triumph 9
PC next tool hunt Restoration & Tools 0
AH100M My 100 is being auctioned in Ft. Lauderdale next Saturday March 28th Austin Healey 44
J TR2/3/3A Body is on frame, what's next? Triumph 1
R TR4/4A Ok - Now I Tore the Dash Apart - What's Next? Triumph 11
aeronca65t NJ Historics -next weekend Racing 2
A TR4/4A My next restoration with a little help from "Fantom Works" Triumph 2
BlueMax Next Big Step Spridgets 15
regularman when is the next spridget gathering? Its been too long folks :D Spridgets 20
drambuie Pit crews of the 1938 Grand Prix's [Next time i will jump out and refuel myself] Austin Healey 1
Michael Oritt PVGP next two weekends Racing 17
JPSmit Next question - where's Billy Spridgets 1
JPSmit Make next year's Memorial Day truly memorable! Other Cars 7
aeronca65t Next two weekends Racing 1
RickB Going to Las Vegas next week, any car attractions? Spridgets 11
JPSmit Next question - Vimeo FORUM Navigation Questions 1
M Where would you buy your next fuel tank? Austin Healey 6
vette Next Question on Rear Springs Mounting Austin Healey 2
B Generator not working, took apart, what's next? Austin Healey 33
HealeyRick My Next Modified Austin Healey 17
Bob Claffie Wedge Next car TR8 ? Triumph 19
Got_All_4 Who's going to The Roadster Factory Party Next Wk? Triumph 10
drooartz Back in business, hopefully next week! MG 16
Tr3aguy TR2/3/3A Next step to try to start TR3 Triumph 3
K TR2/3/3A Next hottest plug from NGK BP6HS on a TR3? Triumph 4
