New project, triple carbs, micropolished complete
Brosky
Today I bit the bullet, after deciding that I deserved a combination birthday, Christmas and second childhood gift to myself and ordered this setup from Paltech Micropolishing. It should be here in 5-6 weeks and in plenty of time for the summer fun runs. Not sure what the bride will think of this project, but what can I say now? /bcforum/images/%%GRAEMLIN_URL%%/blush.gif
Now if those darned bumpers would get finished at the platers....
You will NOT regret the investment.
Jeff is an artist when it comes to carbs.
Even the Crypt Car was unable to defeat
Jeff's carbs.
d
Paul,
Do yourself a favor and purchase Ratco's throttle linkage... LIGHTYEARS ahead of modding the stock linkage.
I've got Jeff's carbs too, he's a class act with a good product.
Re: New project, triple carbs, micropolished compl
Thanks Shannon! I'll look into that right now.
Although, I thought that these would bolt right in with no mods to the stock linkage, which I'm buying from Jeff, powder coated and all setup as shown in the picture. I assumed (oh-oh) that I would bolt this in and hook up the stock lever from the throttle shaft. I guess not, so what is/are the difference(s) to overcome?
Hey Paul. Glad you are going with the trips. They are fun.
The linkage that is modified to work with the trips is sloppy at best. You loose a ton of reaction time and maybe 10% of total throttle. Ratco's cable linkage is slick and simple. I ran mine up between the first and second carbs, took a lot of slack out of the setup (not so much slack as extra cable to deal with).
Bill or Shannon,
Could either of you guys, or both, snap a picture of your linkage and post it? I'll order a kit tomorrow.
In for a penny, in for a pound.........
See Dale, it really, really never ends.......
Thanks,
Paul,
Here's mine. Unlike Bill my linkage is installed in between the #2 and #3 carbs, but there's enough cable supplied to do it however you want to. You really can't see it from the pic, but from the bracket attached to the firewall there's a braided cable that loops down under the #3 carb to attach to the bracket in-between the two rear carbs. The setup is fully adjustable and as you can see I've got just a hair of "slop" adjusted into mine (on purpose).
When you install/trim the supplied cable you just need to make sure that it's long enough that it won't bind when it's used (ask me how I know this). Other than that, it's a pretty straight forward install.
It's gonna look real purty when it's done Paul. Real cold in the garage now though if that's where the wife gonna throw ya. Ya won't even be able to hide out at the golf course. I Guess go with Plan A by reminding her it's her car that's getting the improvement?
Harry, I did hide on the course this morning, but she overheard me ordering a bunch of stuff from TRF when she came home this afternoon. I explained it all as the yearly maintenance and upgrades necessary to keeping the car safe, reliable and to help hold it's value.
Sure is gonna be cold out there tonight.......and tomorrow night...
Really though, no complaints from her yet. My wife is very understanding.....and forgiving, thank God!
Shannon, I guess that I'm a little confused, having not actually seen Bill's, but it looks as though the choke cable on your rear carb goes down directly in front of the new bracket. OK, so where does the cable go from the lever to get to the linkage point between the carbs? Is it under the rear carb or down behind it? Sorry, but I just can't make it out clearly.
Ok, I made a quick diagram of how the linkage works. If you look at the real pic of the linkage above, the silver bracket on the far left is labeled: "RatCo Firewall Bracket" on my diagram, again in the pic above, the big silver bracket in-between the #2 and #3 carbs is labeled: "RatCo Carb Bracket" on my diagram. (Both of RatCo's brackets are shown in red)
The braided RatCo cable is hooked to the OEM throttle shaft lever and is routed under the carbs and secured to the "RatCo Carb Bracket". The braided cable end is then pressed onto to EOM "bulb".
When you depress the throttle the Throttle shaft lever moves towards the back of the car, thus pulling the cable and causing the carb throttle to open.
Hopefully this makes more sense.
Thanks Shannon. I just couldn't see where or how you got to the linkage between the two rear carbs, but now it's clear.
I assume (oh-oh, careful now) that because of the "pull back motion" the braided cable doesn't move, or if it does, there is no lost motion or affect on the linkage movement.
The braided cable is attached to both of the ratco brackets on each end so you are correct, only the small cable inside the braided cable moves.
The reason that Bill moved the Ratco carb bracket between the #1 and #2 carbs is that he had a potential binding problem with the braided cable and the rather sharp bend required when you mount it between the #2 and #3 carbs.
I used a little more length on the cable to prevent this.
Dang Shannon, what program did you draw that up in?
Did you draw the carbs or where they in the directions for the linkage. I'm way impressed. I don't have Paint so just yesterday I downloaded Paint.net . Suppose to be a better program.
I drew them.. Not very complicated really. The top is a circle cut in half and then I just added three different sized rectangles to complete the carb. Copied and pasted it three times... voila! Triple carbs!
I've always drawn stuff like this growing up. I wanted to be an architect at one time, but somehow ended up in computer science.
Is the Ratco cable conversion available for dual carbs? If so, from what vendor(s)?
Thanks, David K.
Paul:
FWIW- the linkage on my carbs was in really
bad shape. When the carbs came back from Jeff
it looked like new linkage.
Other than minor adjustemts, Jeffs carbs were
bolt on and drive............
Unless your dizzy and two coils blow up like
Crypt Car!
d
Mickey Richaud For Sale 1958 MGA Coupe Project MG Classifieds 0
mctriumph SOLD!! Project car 61 Tr3a Triumph Classifieds 0
pbraun For Sale Triumph TR 250 Project Triumph Classifieds 0
C For Sale MG A Project MG Classifieds 2
HealeyPassion AH Project: Cool Air to Engine Austin Healey 5
UltimateQuestion For Sale 1972 GT6Mk3 Project Car and lots of parts -Package Deal Triumph Classifieds 1
J For Sale BN1 project car (price reduction) Austin Healey Classifieds 0
UltimateQuestion For Sale Price Reduced! 1972 GT6Mk3 Project Cars and lots of parts Triumph Classifieds 0
UltimateQuestion For Sale 1972 GT6Mk3 Project Car and loads of parts Triumph Classifieds 7
C For Sale 1974 TR-6 Project car for sale whole Triumph Classifieds 0
SteveTheBrewer Spitfire Project Tanker Mid-Summer Update Triumph 0
LarryK BJ8 Parts or Project Car For Sale in St. Louis Austin Healey 3
L For Sale TR6 1976 (restorable project) and TR4 1966 for parts Triumph Classifieds 4
SteveTheBrewer Spitfire Project Tanker Update! Triumph 0
78Z Project Austin A40 Somerset ‘Special’ Other British Cars 10
S 1964 BJ8 Project Valuation Austin Healey 21
T For Sale 1970 TR6 project car Triumph Classifieds 0
Rut TR4/4A Return to 4a project Triumph 6
B For Sale 57TR3 Small Mouth with OD Project. 12 yeqrs running. I'm not going to finish Triumph Classifieds 14
CJD General TR New Project...? Triumph 24
S 1972 MG Midget Mk III Project Car for sale Spridgets 5
HealeyPassion AH Sebring/Ruddspeed EFI project car Austin Healey 6
equiprx Left over parts from my 1994 XJS coupe project Jaguar Classifieds 0
HAN5L778 MGB 1974 1/2 MGB Project car MG 0
Vikingo Tropical A40 Devon Countryman project Other British Cars 42
Healey Nut Tri-Carb Project Austin Healey 217
M TR6 '72 Engine Project, Some Day Triumph 6
Lukens For Sale Check out this tr3 project for sale... A real treasure trove Triumph Classifieds 0
oldbagpipe For Sale Early 1969 TR6 'Stalled Project' $4500 Triumph Classifieds 0
JPSmit Interesting project - and a twist on the hardtop. Restoration & Tools 12
C TR6 A lot has happened. Update on my project Triumph 7
oldbagpipe For Sale Early 1969 TR6 Project for sale Triumph Classifieds 10
boxofparts TR2/3/3A My long term 30 yr project Triumph 5
B MGB 1972 MGB Project Blue First attempt and fixing no spark and other checks MG 67
D For Sale Custom 1972 Triumph Spitfire [Restoration Project] Triumph Classifieds 0
W Potential New Project Spridgets 3
Bayless New Model A project Other Cars 36
A For Sale 60 Bugeye project for sale Austin Healey Classifieds 0
JimLaney Whole project must go Spridgets 12
TRMark TR4/4A Cruciform Housing Project Triumph 5
TomMull Post-War Other HERALD Simple Task turns into another project. Triumph 11
D For Sale For Sale: 1972 Triumph Spitfire [Restoration Project] Triumph Classifieds 0
TomMull Numbers re Chassis project Lotus 4
vette T-Series New Project, '52 TD MG 70
bugedd Winter Suspension Project Spridgets 7
mailbox For Sale 76 TR 7 project car [non running] Triumph Classifieds 0
Marvin Gruber Nasty boy project Austin Healey 20
H Typical Easy Project takes me 2 hours. Spridgets 5
Lin Ten Year Renewal Project Austin Healey 2
