    BCF is a FREE resource for the Little British Car community. I just did a little math and found that less than 1% of the registered members appreciate this forum enough to support us with an account upgrade. We do not "require" you to pay to play here, but if you find BCF helpful, appreciate no pop up ads, and want to ensure we stay online - Consider supporting us with an "optional" low-cost member upgrade. There are some benefits to upgrading!
My tach stopped working
tntriumph59
Member
Hey guys and gals,
I have 59 TR3a and I noticed a few days ago that the tach wasn't working. Where would you guys start in diagnosing this? It worked off and on before, but now it is just dead.
Thanks,
Andrew
Have you checked the cable. Unscrew the cable at the base of the distributor, then see if the end of the drive cable is intact, if so then check the end at the tach. You will be able to pull the drive cable out from the tach end. Check for lenght and if broken. Hopefully if will just be the cable.
Marv
if its not the cable, I would pack it up and send it off to one of the reputable gauge guys, I had a spare tach I purchased off ebay and took it apart to see what was wrong( Like I alway do) any totally messed it up, not that I needed it, the one in my TR6 always bounced around by 500 rpm, I sent it off to one company, and they did a great job fixing it and its steady as a rock
they did the spedo too and it works great too
Hondo
Merv's got one extra of everything!
Before sending the gauge out it is worth making sure the cable spins freely and, as mentioned, is tight. They will bind over time and cheaper to replace than a tach rebuild (especially if it isn't necessary).
Keep us posted.
I had my tach do the same thing last year. When I had the tooth break in the transmission Iwas going to send the tack off for repair. But I found the end of the cable had broken off just inside the tach drive. When I first looked at the cable it was turning and the end looked like there was enogh coming out of the cable housing to drive the tach. Take your tach out and stick something in the drive end that you can also chuck in a drill and operate the tach and this will tell that the tach is still working.
M Tach stopped working. Any opinions? Spridgets 6
B MGA Tach drive issue MG 1
S TR2/3/3A "Vintage" engine analyzer tach unstable? Triumph 14
Celtic 77 MGB Non working tach. MG 4
jackq Wanted Need a C Tach MG Classifieds 2
S Sticky Tach Spridgets 2
Joe Reed MGB Tach slow to wake up...why? MG 6
Lin Tach drive housing for BT7 Austin Healey 4
HealeyRick Tach Trouble Spridgets 2
W Tach wiring problems Jaguar 12
Marvin Gruber BJ7 tach cable location. Austin Healey 3
EWD TR6 ‘74 Tach Triumph 7
PAUL161 T-Series Lazy Tach MG 3
boxofparts MGB busy tach on 1979 MGB at 75 mph MG 3
J Speedometer Tach Correlation 1965 Austin Healey BJ8 Austin Healey 3
J 1965 BJ8 Tach Austin Healey 3
longbridgehealey Alternator conversion and tach Austin Healey 9
Healey Nut Mechanical tach drive Austin Healey 2
Healey Nut Mechanical tach drive assembly Austin Healey 4
S TR2/3/3A grounds the tach and speedo dash lights Triumph 1
S TR2/3/3A tach cable lubricant Triumph 4
D BT7 tach question Austin Healey 8
5 Tach Drive Generator for a Bugeye Spridgets 2
I Tach help Spridgets 3
Marvin Gruber BJ8 tach Austin Healey 9
Superwrench Tach not working Austin Healey 6
JimTR4 TR4/4A Capping off redundant tach cable connection Triumph 0
Zitch TR4/4A Tach and Speed inner gaskets Triumph 13
W Use of original Tach Spridgets 8
A Need help wiring my tach Spridgets 11
Patrick67BJ8 Tach Hookup Instructions from Nisonger Austin Healey 23
S TR5/TR250 tach problems Triumph 2
J Hunting tach and back fire TVR 8
B Longbridge 100-6 Tach Cable and Speedo Angle Drive Questions Austin Healey 7
M Tach generator gearbox Spridgets 6
M Strange Healey Tach Austin Healey 9
steveg Checking Healey Mechanical Tach at idle Austin Healey 3
busybrit Tach stops when flashers are turned on !! Jaguar 3
busybrit Electrical tach issue on Aston Martin DB5 Other British Cars 2
AngliaGT What Goes to the Left of the Tach? Spridgets 3
S TR2/3/3A speedo and tach until the weather gets better Triumph 3
J How can I tell if I have a negative ground tach? Austin Healey 5
E TR4/4A Speedo v Tach cable Triumph 2
rjc157 tach goes crazy Austin Healey 8
Sopwith_Camel tach-less Spridgets 11
B Lazy Tach Austin Healey 2
J Tach drive housing eccentric Austin Healey 14
G MGB Tach and speedo rebuild. MG 3
Schroeders T-Series TF Tach Calibration - DIY? MG 3
Darwin Spitfire Help wiring up a tach Triumph 9
