TR2/3/3A My long term 30 yr project
boxofparts
It has been in 4 different garages and I finally put some DTM primer on it this fall. Something else always seems to get priority.
Hello Boxofparts
Welcome to the forum.
Life has a way of holding up things up.
That looks great. The finish line is not too far off now. You will find the Triumph section is very active so you will be sure to get plenty of tips and help as you finish up the TR3.
What year is it?
Hope all the bits made all the moves over the years. I find it hard enough to keep up with parts over the weekend.
Keep the photos coming as you progress.
David
Body is 1960, front is a small mouth like my dad had back in the early 60s. 20 some years ago I welded the whole mess back together. I will need to go back thru my pre digital photos and post the mess I started with. I probably wont get back into it for another year as I am in the middle of building a garage on my retirement home in northern Michigan. I was really happy to put some DTM primer on it this fall so I could take it out of long term dry storage.
This is how it looked after many years of storage. This will be its 5th home but the garage comes first.
Looks like a nice solid car to work with.
Cheers
Tush
Great looking 3!
apbos New long term project. Sprite powered rear engined race car. Spridgets 9
R General TR Poly bushings long term results Triumph 4
R long term storage Austin Healey 2
Popeye Long-term engine storage w/o antifreeze Triumph 2
TR4nut Looking for long term car storage advice Triumph 10
Bret Short & Long term plans MG 12
B TR6 Crankshaft long seal surface Triumph 5
jfarris Message too long error FORUM Navigation Questions 8
L My 1951 Triumph long ago British Motorbikes 0
KVH General Tech Flywheel Bolts Too Long For Main Seal Triumph 13
W Generator and Starter Long Bolts Spridgets 0
Popeye TR4/4A Slave rod seems too long but is not Triumph 7
A Land Rover V8 3.9L long block core for sale Rover / Land Rover 1
Jayplum For Sale SU HS6 for sale along with a long intake Triumph Classifieds 3
Zitch Engine Oil Leak After Long Drive Austin Healey 19
K TR2/3/3A Clutch "Long Throw" Slave Cylinder? Triumph 4
G TR2/3/3A Finding a long lost TR3 Triumph 4
R The long road home Spridgets 1
Y MGB An odd (and probable long-shot) request... MG 5
roscoe Rear end crown and pinion gear swap. 4.11:1 to 3.54:1 [long read] Austin Healey 12
R TR2/3/3A Restoration of 1954 TR-2 Long Door Triumph 6
T BT7 throttle relay levers short and long Austin Healey 2
S For Sale 3000 BJ8 Laycock 4 speed with 22% OD trans & 2 6 cyln engines / long blocks / BUNDLE Austin Healey Classifieds 1
Michael Oritt Post- Open Roads 2002: Tahoe to MD the long way Austin Healey 19
R TR2/3/3A Restoring a 54 TR-2 Long Door Triumph 10
K For Sale Long and short TR3 and 4A Intake manifolds Triumph Classifieds 0
Joe Schlosser Thoughts on a long traffic Light Spridgets 11
R TR2/3/3A Restoration of 1954 TR-2 Long Door Triumph 22
D Long Lost Midget Spridgets 0
E Long lost Sprite Spridgets 10
roscoe Leakdown test [long read] Austin Healey 11
aero3113 Healey Shop on Long Island Austin Healey 9
britlover Wanted TR4 Hood long bubble Triumph Classifieds 0
D MGB Painted rubber bumpers. How long will they hold up? MG 1
T C42 BJ8 generator long screw needed Austin Healey 2
PeterK General TR Time for a long ride Triumph 3
D After a long break.... Spridgets 6
Lotus Club SoCal Ballast Point Long Beach Social Lotus 2
Popeye TR4/4A Found this odd long bolt in my fuel tank... Does anyone know what it is? Triumph 17
GTP1960 Not the "best car ever made" by a long shot Other Cars 14
L TR6 need help on long dead TR6 Triumph 16
Sarastro Morris Minor in Long Beach, CA Spotted 1
D TR4/4A extra long oil filter attachment stud Triumph 9
D TR4/4A flywheel bolts maybe too long Triumph 15
Sarastro Red TR3 in Long Beach, CA Spotted 0
Jim_Gruber I woke up Bugsy this afternoon after about a month long nap and he was cranky Spridgets 7
TomMull Post-War Other Herald: Holy Moly! [Why it took me so long to make the accelerator bracket] Triumph 2
Marla TR4/4A Take the long way home Triumph 11
K TR2/3/3A How long should an SU damper top up last? Triumph 22
steveg Very interesting very long blog posting - racing oil and zinc Austin Healey 44
