TR2/3/3A Mustang II rack and pinion conversion to TR3
bluemiata90
Has anyone tried or heard of anyone converting a standard TR3 steering to a Mustang II rack and pinion steering. I don't know the mechanics of the Mustang II, but due to it's smaller size, I was wondering or hoping that a conversion might be possible. If not, please tell me why. /ubbthreads/images/graemlins/confused.gif
Alan_Myers
Hi,
It probably could be done, with some serious, careful work. I've not seen it done.
Another possible candidate would be a '71-'72 Pinto R&P unit. It's also pretty common and used in a wide variety of custom installations.
The biggest problem would be getting all the geometry just right. The length, movement and orientation of the tie rods needs to be pretty exact, or all sorts of strange things can happen. "Bump steer", for example. Steering problems can be downright dangerous.
But, I've not specifically heard of either of the Ford units being installed in any TR.
I've also never seen or heard of the later TR4 or TR4A/250/6 R&P units being retrofitted to TR3, either. I think the problem is both of these are too wide and will not work with the narrower track of the TR3.
The available TR3 R&P conversion kits are based on TR7 R&P unit. There are two varieties. One bolts right in (TR Bitz), easier to install and easier to return the car to original should that become important. The other needs to be welded in (Revington TR), a stronger setup but more of a job to install or remove.
Notice too that Triumph converted to 3 degrees of castor shortly after switching to R&P in the TR4. TR2/3 and very early TR4s have 0 castor, which is less than ideal for use with R&P, might make for pretty light and "squirrely" steering.
However, it would be a pretty easy job to swap later 3 degree upper/lower control arms and trunnion into a TR3 that's being converted to R&P. A bit of added work and expense, though. (If I were doing it, I'd try to make it an adjustable setup: TR4A or later, using shims on the lower control arms, or some sort of custom setup that adjusts the upper fulcrum mounting point).
Have you considered some of the "improved" TR3 steering boxes? I know there are several offered, less of a chore to install and a lot cheaper than the R&P conversion kits. British Frame & Engine sells one of the "improvements", I'm not sure of the details. Ken works closely with the British TR vendors who offer such things (Revington, Recestorations, TriumphTune) and might have some other suggestions. (britishframeandengine.com)
Cheers!
Alan
sammyb
Mustang II and Pinto share the same r/p system, as I understand.
Geo Hahn
[ QUOTE ]
...Have you considered some of the "improved" TR3 steering boxes? I know there are several offered...
[/ QUOTE ]
Anyone with experience with these?
I love the R&P on my TR4, seems to suit the car perfectly (as do roll-up windows and a water tight interior)... but I also love the steering on the TR3. That heavy elbows-out technique that calls for leverage and strength in low speed turns is for me part of the essential character of the car.
I do have the spring-loaded adjuster pin on the steering box which can compensate for a moderately worn peg & cam.
Alan_Myers
Hi again,
I wasn't aware the Mustang II and Pinto R&P were identical. I knew they were similar. That should just about double the junkyard candidates.
I guess it just makes sense that Ford would use the same unit in both cars when possible.
Cheers!
Alan
p.s. I guess it shows... I worked at a Chevy dealership back in the Mustang II/Pinto days!
waltesefalcon Mustang Mach E Spotted 10
JPSmit Mustang wagon! for sale Other Cars 0
AngliaGT Mustang II Cobra Spotted 4
GTP1960 '65 Mustang......The icon Other Cars 0
PC Mustang II Spotted 8
AUSMHLY Any 1964 1/2 mustang fans here? Austin Healey 4
AngliaGT Australian Mustang Fanatics Spotted 1
aeronca65t Mustang Calif. Special Spotted 5
aeronca65t Paper Mustang Other Cars 2
B very excited! Just ordered my Ford Mustang 2013 GT Other Cars 1
AngliaGT P51 Mustang,Vespas,Suzuki RM 400 Spotted 1
jackq 94 Mustang GT Other Cars 4
T OT - More P-51 Mustang restoration pictures Triumph 10
BabaKahawa 67 Mustang Saga Other Cars 21
philman old mustang wiring connectors Other Cars 0
S TR6 TR6 Mustang Triumph 0
Brosky Can anyone spot the Mustang in this picture [ebay] Triumph 9
jackq 68 Mustang Coupe Other Cars 2
jackq rattle in the Mustang Other Cars 1
aeronca65t RHD Mustang Other Cars 11
jackq 94 Mustang GT Other Cars 0
jackq Mustang GT vert trip Other Cars 7
jackq ANOTHER...94 Mustang GT Other Cars 9
jackq 94 Mustang GT Other Cars 10
jackq 65 Mustang Other Cars 22
V Mustang convertible top replacement Other Cars 3
philman '68 mustang ww/289 rebuilding Other Cars 3
Bret What do ya think about the new Mustang? Other Cars 40
tr6nitjulius For Sale SOLD 3/7/24: 4$ale Hi-ratio quick steering rack Triumph Classifieds 0
roscoe Low-Budget Luggage Rack Austin Healey 27
PAUL161 T-Series TF Steering Rack MG 0
E TR6 Strange Steering Rack Cap Triumph 3
71TR6 TR6 Replaced steering rack in my TR6- very twitchy now Triumph 15
Scotsman Rack and Pinion Conversion for 3000 Austin Healey 7
Simmo TR2/3/3A Steering with Escort rack Triumph 5
M Need help removing the pinion assembly from a late 1275 steering rack Spridgets 7
Prof. T Wanted Luggage Rack Triumph Classifieds 13
M MGA RHD rack and pinion wanted MG 19
T TR2/3/3A TR3A rack & pinion conversion question - solution for horn & directional lever Triumph 2
C TR2/3/3A Rack and Pinion Conversion for Tr's Triumph 0
M TR5/TR250 Steering Rack Fitment/Geometry Theory Assistance Required. Triumph 1
M TR6 Power Steering Rack & Pinion. Triumph 3
M TR6 Electric Powered Rack & Pinion. Triumph 4
C Steering Rack Spridgets 17
M TR6 Replacement Steering Rack ? Triumph 7
steveg TR6 Dealing with Rack Boot Triumph 3
Lin Hardtop Wall Storage Rack Austin Healey 11
S TR6 1976 TR6 Steering Rack Boots [gaters] Triumph 19
