jehuie
Hi all,
I tried searching on here for this info first but couldn't find it. I'm working on the horn push on my Morris and having a hard time finding actual pictures, drawings or videos about how it all is supposed to work. Most of forum posts around the web were made many years ago and the links are all dead.
So here's the situation:
1) My car horn has been in a box that came with it ever since I've had it. I was waiting on a part for the engine so I thought I'd finally install it.
2) I tested the horn with alligator clips directly to the battery and it works fine.
3) i found the purple and purple/black wires laying in the engine compartment. They had been clipped off so I installed new bullet connectors and attached them to the horn.
4) I went into the car and pressed the horn push. Nothing happened.
5) I turned the key in the ignition and pushed it and then it suddenly went off but CONSTANTLY. Nothing would stop it, including turning off the ignition. So I went and unplugged one connector to kill the noise.
6) From then on, touching that wire to the connector would cause the horn to beep no matter what I did.
7) I took the horn push out entirely. The horn still beeps when I connect it.
8) I removed the steering wheel. The horn still beeps when connected.
9) I removed the turn-signal mechanism and finally the horn stopped when connected.
10) I put it back together and now no matter what I do, I can't get the horn to beep, other than direct connecting it.
Ideas?
I'll post a few pics in a bit.
Ideas?
