Morris Minor disc brakes
PistolPete
Well, I'm going to give some rebuilt MGB disc brake calipers a chance on my Morris Minor which was oufitted with Morris Marina (whatever that is) rotors and calipers. The calipers are toast, and new Marina calipers were going to cost about $300 from the UK. The MGB calipers are $44 each at Autozone. Hard to beat that.
They do have a resemblance to the Marina calipers,so I'll let you know what happens. (Like anybody cares- right?)
Pistol Pete
aeronca65t
The MGB calipers are a popular racer upgrade to Sprite/Midgets, so this isn't surprising at all.
The only thing is that if you use the MGB calipers on a Spridget, you need to use the larger Spitfire rotors plus a fairly simple-to-make rotor adapter (and, of course, the MGB pads). You might be able to keep the smaller Spridget rotors, but that doesn't give you brakes that are any bigger (which is what racers want).
By the way, the MGB calipers at AutoZone here in New Jersey are over $80 each (without a core), so that's an excellent price.
Platinum
The Marina was a futile attempt by Leyland to intro a sedan/coupe to North America in about 1968 and forward. It was an anemic attempt to boost sales. Most of it was MGB running gear bolted to a chassis for four passengers, not very elegant.
Be aware that those Autozone (and other retail outlets') calipers are "reman" units... you may go thru a couple before you have reliable braking.
...Just an FYI...
Don't drive "deep" into a situation until/unless you've done some "unofficial" skid-pad trials. :wink:
racingenglishcars
The Marina mostly used the 1275 engine with a cast crank and a Spitfire gearbox.
Anemic, definitely.
The front suspension was very similar to the Minor and I think the upright could be installed on the Minor complete with the disks and calipers.
Otherwise the conversion normally used sprite disks and an adapter to mount the sprite caliper.
The Marina rotors were larger diameter than the Sprite and could possibly (don't know) be mounted on the Marina spindle.
If this is the case, B calipers would be an advantage just because of the availability.
:smile:
Roger
Bronze
The Marina, and its successor, the Ital, were possibly the most dreadful cars ever foisted on the public by that idiot management comprising Leyland and the British government.
One of its little-known but remarkable claims to fame is that the handling of the 1.8 litre version, when first subjected to Road Test, was so dangerous that the editors of Motor and Autocar, the 2 leading weekly motoring journals in the UK at that time, met the chairman of Leyland and told him what they both intended to publish unless something was done before the production version went on the market. Half-hearted modifications were made, but the cars still had dreadful understeer and the road tests were very unflattering!
The 1.8 TC engine though, is a good upgrade for an MGB.
racingenglishcars
john_j
"The Marina mostly used the 1275 engine with a cast crank.." Also used the B series 1800.
"The front suspension was very similar to the Minor and I think the upright could be installed on the Minor complete with the disks and calipers." Correct.
I beleive it was sold in the US as the Austin America.
JPSmit
Austin America and Marina were two different cars - was marketed in the USA as a Marina though Austin not Morris
john_j
Ah yes, you're right - America was the 1100/1300.
bcliff '61 Morris Minor Disc Brake Conversion Other British Cars 3
drooartz Spring service of the 4-door Sprite (Morris Minor) Spridgets 8
S For Sale 1955 Morris Minor touring car for sale. Other British Classifieds 5
NutmegCT Rear dampers, 1957 Morris Minor Other British Cars 4
NutmegCT Morris Minor brakes! Other British Cars 9
jehuie SOLVED: Fixing electrics on Morris Minor with 1275 swapped in Spridgets 13
jehuie Morris Minor horn mystery British Motor Corp 12
NutmegCT 1957 Morris Minor Traveller Other British Cars 20
Bob Claffie Morris Minor Other British Cars 0
S For Sale Morris Minor Factory Workshop Manual om CD/ROM - All Models 1959 - 1967 Other British Classifieds 0
Bayless Need soft top for Morris Minor Other British Cars 5
D Morris Minor in NSB Florida Spotted 8
AngliaGT Morris Minor Spotted 1
Griz Wanted Morris Minor Other British Classifieds 3
Sarastro Morris Minor in Long Beach, CA Spotted 1
Gerard ... for the Morris Minor enthusiasts here... Spridgets 18
M Rubber for Morris Minor Spring Clips Other British Cars 1
M Morris Minor Spring Clip Rubber Other British Cars 0
4tecdog Fleet of new Morris Minor Vans 1964 Other British Cars 4
drooartz Up-date on the 4-door Spridget [Morris Minor] Spridgets 12
catfood Timewarp Morris Minor Other British Cars 0
D Morris Minor motor mount? Other British Cars 3
S Morris Minor resources? Other British Cars 6
Gliderman8 '59 Morris Minor in Taupo, NZ Spotted 0
NutmegCT Morris Minor for sale Other British Cars 1
TulsaFred Morris Minor? Spridgets 7
dougie Morris Minor Panel Van Other British Cars 4
AngliaGT Morris Minor Convertible Other British Cars 0
K Reasonable price for a Morris Minor project car? Other British Cars 4
O Morris Minor Questions? Other British Cars 3
O Morris Minor on the horizon? Other British Cars 4
M Proper Brake Fluid For 1960 Morris Minor Pick Up Spridgets 8
S Very clean 1970 Morris Minor Woody on eBay Other British Cars 6
B Datsun engine & trans in a Morris Minor? Other British Cars 0
5 wheezy Morris Minor 1000 Other British Cars 2
AngliaGT Morris Minor on Front Page Other British Cars 3
L Need help restoring a 1950 Morris Minor FORUM Navigation Questions 0
L Need help restoring a 1950 Morris Minor Other British Cars 2
jackq Morris Minor woody wagon. Other British Cars 7
AngliaGT Morris Minor Convertible - $1424 Other British Cars 7
G Morris Minor under body resto Restoration & Tools 2
C Morris Minor & Mini's Auction Other British Cars 0
G Morris Minor Help Other British Cars 10
T Morris Minor Traveller For Sale? Other British Cars 1
YankeeTR $1900.00 Morris Minor? MG 15
S 1960 Morris Mini Minor British Motor Corp 2
bcliff Anyone want a '61 Morris Minor Traveller? Other British Cars 0
jackq 52 Morris Minor Other British Cars 3
jackq Morris Minor Other British Cars 0
Schroeders Any Fellow Morris Minor Pickup Heads Around? Other British Cars 7
