Morris Minor brakes!
NutmegCT
I wondered why my '57 Morris Minor Traveller is so tough to roll by hand, and needs so much power just to move a few feet. Raised the rear and discovered both rear wheels are frozen tight. Parking brake is off.
Front wheels turn freely. Rear wheels won't budge. Hasn't driven more than a few 100 feet since I got it back in February.
I removed a rear wheel, but since I can't turn the drum, I can't use the adjustment screw inside the drum to loosen the shoes.
I'm reluctant to use blasting caps or a small nuclear device ... can someone talk me through what I need to do to free up those brakes?
Thanks.
Tom M.
The adjustment is not thru the backing plate? I would first try a BFH (brass or lead) around the outer edge of the drums and try to work them off with a couple screw drivers. The try heat on the drums?
Success! Some modest thwacks with a hammer around the drum, followed by levering the studs with a 3 foot long 2x2 did the trick. I could slowly turn the drum using the 2x2, centered the adjustment hole over the adjuster bolt, loosened one click - and all is well. Now just a sliding sound as the drum turns.
Had to do this on both sides.
Some of the later model MMs had the adjuster on the back of the plate. Mine is a '57 - has two on each front brake, one on each rear brake, accessible through the hole in the drum.
Thank you for the advice!
Tom M.
always great when a plan comes together.
Now you'll need to remember to set the parking brake.
Tom, as a precaution, check that the e-brake & shoe return spring(s) are working correctly.
Personally, I'd be going for a complete going-through of the braking system on the thing.
Well done, Tom. Out comes the big hammer!
P Morris Minor disc brakes Other British Cars 8
J For Sale 1959 Morris Minor Convertible Other British Classifieds 5
drooartz Spring service of the 4-door Sprite (Morris Minor) Spridgets 8
S For Sale 1955 Morris Minor touring car for sale. Other British Classifieds 5
NutmegCT Rear dampers, 1957 Morris Minor Other British Cars 4
jehuie SOLVED: Fixing electrics on Morris Minor with 1275 swapped in Spridgets 13
jehuie Morris Minor horn mystery British Motor Corp 12
NutmegCT 1957 Morris Minor Traveller Other British Cars 20
Bob Claffie Morris Minor Other British Cars 0
S For Sale Morris Minor Factory Workshop Manual om CD/ROM - All Models 1959 - 1967 Other British Classifieds 0
Bayless Need soft top for Morris Minor Other British Cars 5
D Morris Minor in NSB Florida Spotted 8
AngliaGT Morris Minor Spotted 1
Griz Wanted Morris Minor Other British Classifieds 3
Sarastro Morris Minor in Long Beach, CA Spotted 1
Gerard ... for the Morris Minor enthusiasts here... Spridgets 18
M Rubber for Morris Minor Spring Clips Other British Cars 1
M Morris Minor Spring Clip Rubber Other British Cars 0
4tecdog Fleet of new Morris Minor Vans 1964 Other British Cars 4
drooartz Up-date on the 4-door Spridget [Morris Minor] Spridgets 12
catfood Timewarp Morris Minor Other British Cars 0
D Morris Minor motor mount? Other British Cars 3
S Morris Minor resources? Other British Cars 6
Gliderman8 '59 Morris Minor in Taupo, NZ Spotted 0
NutmegCT Morris Minor for sale Other British Cars 1
TulsaFred Morris Minor? Spridgets 7
dougie Morris Minor Panel Van Other British Cars 4
AngliaGT Morris Minor Convertible Other British Cars 0
K Reasonable price for a Morris Minor project car? Other British Cars 4
O Morris Minor Questions? Other British Cars 3
O Morris Minor on the horizon? Other British Cars 4
M Proper Brake Fluid For 1960 Morris Minor Pick Up Spridgets 8
S Very clean 1970 Morris Minor Woody on eBay Other British Cars 6
B Datsun engine & trans in a Morris Minor? Other British Cars 0
5 wheezy Morris Minor 1000 Other British Cars 2
AngliaGT Morris Minor on Front Page Other British Cars 3
L Need help restoring a 1950 Morris Minor FORUM Navigation Questions 0
L Need help restoring a 1950 Morris Minor Other British Cars 2
jackq Morris Minor woody wagon. Other British Cars 7
AngliaGT Morris Minor Convertible - $1424 Other British Cars 7
G Morris Minor under body resto Restoration & Tools 2
C Morris Minor & Mini's Auction Other British Cars 0
G Morris Minor Help Other British Cars 10
T Morris Minor Traveller For Sale? Other British Cars 1
YankeeTR $1900.00 Morris Minor? MG 15
S 1960 Morris Mini Minor British Motor Corp 2
bcliff Anyone want a '61 Morris Minor Traveller? Other British Cars 0
jackq 52 Morris Minor Other British Cars 3
jackq Morris Minor Other British Cars 0
Schroeders Any Fellow Morris Minor Pickup Heads Around? Other British Cars 7
