Making Progress
M_Pied_Lourd
Hi all,
Had a great day in the garage today and made some good progress on the 3A.
Thought I would post some pics.
Emergency Brake and then on to the front suspension......
Cheers,
M. Pied Lourd
Nice job!!! That really is the optimium way to do this kind of work. Keep the pictures coming.
Looks Great! Nice to be working on clean parts isn't it. It is also really great to have a fun day in the shop!
Good going, Tinkerman
Very nice! - is that an Addco setup in the back, or something different?
Randy
Hi Randy,
Yes, it is the Addco setup. I have an oversized bar in the front as well.
Cheers,
M. Pied Lourd
He does good work Randy, eh?
He doesn't know it yet but I'm about to ship him a TR4a which will be so sloppy he won't be able to help himself but to restore it to this quality... Shhhh...
I love the work you are doing, looks great. Could you show some picts of the rear sway bar? I have the same one but I am not sure on the exact installation. The instructions are fair at best.
Sure Dan,
I will take some pics of it and post them later today.
Cheers,
M. Pied Lourd
Very nice work! My shipping address is................... :bow:
Paul
That's looking very nice. It should handle like a go-cart when its finished!
Had fun taking apart and putting the handbrake back together.
Anyone interested in some pics? Looks a little more daunting but is probably less tricky than a TR6 one IMO.
Cheers,
M. Pied Lourd
Here ya go Dan, some pics of the rear sway bar.
Cheers,
M.Pied Lourd
Never seen an Addco bar that attaches with links like that. Must be a new design for the 3. How is the rear bracket attached to the legs of the frame?
The rear Addco on my 4A solid axle is also different in that the bar goes forward of the axle instead of behind. The IRS version goes behind, same as the 6.
This is bordering on porn I tell ya!!! LOL
Hi Peter,
If you are talking about where the bushings and brackets mount to the frame they are secured through the frame with lag type screws. I also have an option of adding a couple of welded plates to the base of the frame to reinforce the area if required. It seems pretty sturdy now, but I will keep an eye on it in the future once I get some driving in.
Cheers,
M. Pied Lourd
M_Pied_Lourd said:
Hi Peter,
Cheers,
M. Pied Lourd
Eeek - lag screws, really? Like this ? https://ecx.images-amazon.com/image..._PIcountsize-600,TopRight,0,0_AA110_SH20_.jpg
Lag screws are for joining wood and most certainly rip out of your frame taking bits of frame with it.
My advice would be to install reinforment plates on top of the frame and drill all the way through the frame channel from top to bottom and then use a grade 5 or better hex bolt and lock nut, either nylocs or metal. The bottom won't need reinforcement since it already has the Addco mounting plate there. It's already a weak point in the frame back there so the more solid attachment, the better.
tdskip said:
Peter - any pictures of how yours on the 4A mounts?
The 4A solid axle has a unique mount. I have the Addco install sheet and it shows a front of the axle mounting. Mine is hanging by nylon straps as I haven't finished up back there but I will try to get a photo for you. Last week it was up on the lift but since the snow is here, my Audi is "up", the 4A is "down" and the 3A is in the new addition.
The end links are normal Addco style - a thick metal plate that bolts to one leg of the u-bolt the spring plate, then poly bushings and a bolt between the bar ends. From addco.net https://02bbfb5.netsolhost.com/images/solution.jpg
mctriumph 61 Morgan making progress Other British Cars 3
drooartz Making [tiny] progress Spridgets 14
7 Post-War Other Back to making progress Triumph 5
drooartz MGB Making some progress with the doors MG 5
Aggudabbu Making some progress Spridgets 5
Stewart Making progress finaly MG 7
George Zeck Making good progress ..... Spridgets 11
7 Making progress finally Triumph 1
KLUTZ MGB-GT Making progress on the GT MG 14
PAUL161 Still Making Progress !! *DELETED* *DELETED* MG 4
PAUL161 Making Progress, I think ?? MG 14
Mark_Gibson Still Making Progress on the TR-2 Triumph 2
Mark_Gibson Making Progress, Having Fun! [TR-2 Dismantling] Triumph 10
A Why is my car making this noise? Other Cars 5
KVH General Tech Making the Triumph Engine Dolly Triumph 4
A Making an A-series engine stand adaptor fitting Spridgets 2
K TR2/3/3A Making your own steering wheel stator tube? Triumph 16
PAUL161 Making your own tools [Sometimes] Restoration & Tools 4
H Making a '73 Midget into a '63 Midget Spridgets 2
matmire gonna try making some wind wings. Spridgets 13
Jim_Gruber Generator and Polarity - Making sure Generator is Polarized Correctly Spridgets 13
D 69 E-Type sputters when making left hand turn Jaguar 6
Got_All_4 TR2/3/3A I'm making my own door panels and .... Triumph 11
T TR4/4A Making Miata seats in a TR4a look more "right" Triumph 4
tomshobby General TR making it easy to lube door hinges Triumph 0
Lukens TR2/3/3A Water pump bearings making noise... time to replace Triumph 9
J TR4/4A Making a '65 TR4 Run Awesome. Misfire, Ignition Tune Up, Carb Rebuilds. Help? Triumph 70
M Making a manifold/carb heat shield - any suggestions? Spridgets 14
T TR4/4A Making an OD pressure gauge - any tips? Triumph 7
glemon Restoration Vs. Making it Go Restoration & Tools 14
J Rear wheel cylinders over extending ??WHY?? Making a mess fluid everywhere!!! Austin Healey 54
G How do I know I am making the right decision? Jaguar 7
AN5Sprite Making room Spridgets 0
J Making Room Triumph 2
RickB Who can guess what I'm making? Spridgets 37
G Oil Change after Storage - Part 1 - making a mess Austin Healey 0
Darrell_Walker Making a wire wheel tubeless? Triumph 45
glemon Making Strombergs Richer Triumph 22
F Are the russians making a hybryde .... Other Cars 0
hondo402000 Making your Avatar Pic Triumph 14
Sarastro Tool for making bubble flares on brake lines Restoration & Tools 14
Jim_Gruber Vroom Vroom Bugsy is making good sounds once again Spridgets 6
G Making a faux roll bar into a real roll bar Triumph 2
RickB OT: talk about making a Spridget Hybrid? Spridgets 0
D Spitfire Need help making my Spit 1500 a little more fun... Triumph 24
drooartz Making more calls today Spridgets 6
T Making a steering wheel Austin Healey 41
DNK My 6 is Making Me Frustrated Triumph 10
T Making straight cuts & smooth edges for patches Triumph 5
G Still making the covers after 30+ years Triumph 0
