TR6 Losing voltage at + side of coil
cmacmillan
Been dealing with a no-start situation. I think I've traced it to a bad electronic ignition unit so the points/condenser are back in circulation (glad I keep everything I take off!). Anyhow, my ignition wire seems fine...getting 12V at battery and + side of the coil. But when I connect the dist wire to the - side, my + side reading drops to 5V (no voltage on - side, so that's a better place than where I started). Anyone encounter this?
There is a ballast resistance built into the wiring harness on later TR6 (roughly 73 onwards), so it's normal for the voltage on the coil hot terminal to drop when the points (or virtual points in an electronic ignition) are closed. But normally it shouldn't drop that far. Sounds like your coil might be lower resistance than usual (perhaps an internal short), or the resistance wire is high.
+1 to Randall's comments.
Normally an inline ballast resistor would result in the coil (+) terminal having somewhere between 6V and 9V on it when the points/module are providing a path to ground.
It wasn't clear to me how you performed the test, but do not rely on the points being closed to create a ground for the coil when you check for voltage that is feeding the coil.
Use a jumper wire connected from the negative terminal of the coil to a known ground.
Then use your VOM meter in the normal fashion.
Update - tried a second coil, same thing. I'm getting 5.7V at the - coil terminal with the ignition on, points closed. Grounded to the block with a secondary wire, same reading. I'm finally getting spark at all 6 plugs but no-start....drained the battery trying, so charging it now. How worried should I be about the 5.7 V? Should I replace the dist to coil wire?
Don't you mean the positive terminal?
And you've checked that it goes back up with the engine turned so the points are open, right?
I doubt that the 5.7v is the problem, but for a test you could try running a temporary jumper from the coil positive terminal to the battery positive. That will deliver full battery voltage to the coil (which is supposed to happen while cranking anyway).
Don't leave it for a long time though. 10 minutes shouldn't hurt anything. And obviously, once started, the engine isn't going to shut off until you disconnect the jumper.
Oop - yes, you're absolutely right...5.7V at the + coil terminal. Didn't check with the points open...will give that a shot as well as the direct cable.
Ok - 12.2V with points open, back to 5.7 closed. Ran a jump direct to the coil and no difference. Sparks are all there but I'd say are white-yellow (is anyone getting blue spark?). Made sure fuel pump was sending fuel. Finally hit the carbs with quick start...annnnnd it worked. Worried it's the newly rebuilt cards, but it was running under it's own steam after the initial quick start.
Yes, I get a blue spark.
If you are not feeding the coil enough voltage going in, you are going to get a weaker spark coming out.
When I had a ballasted ignition the coil would get fed battery voltage when the starter was engaged.
Once the engine started and the starter relieved of it's duty, the coil was fed 9.7 volts thru the ballast resistor wire.
Does your engine block have a good ground connection to the battery ?
Hey all - sorry...hasn't really been "car working" weather in this part of Canada! Some follow-up - I did check engine ground which seemed fine. It's putting out decent spark - but still hard starting unless I hit it with some quick start, in which case it fires right up....I think it's a fuel/air mix issue...more on that in my next follow-up post. Thanks again for weighing in!
Just a thought, is the fuel fresh? If it sits for a long time, the more volatile components can evaporate, leaving something that looks and smells like gasoline, but acts more like kerosene. (Meaning really hard to start.)
It *should* be ok - when I started this process I drained the old stuff and added new gas...that said, it's now been 4-5 months. I did add some fuel stabilizer to the tank just before Christmas.
Sounds to me like you have a problem with the choke system, make sure the cables are fully actuating the chokes properly
KVH TR4/4A Closing the Soft Top Triumph 11
FlyingCat Spitfire Losing Coolant Triumph 12
pbraun Closing in on finishing the Bug I Spridgets 12
KVH General TR Still Losing Oil Triumph 5
M Losing Brake Fluid Austin Healey 8
K TR2/3/3A Gauges held in by "knurled Knobs"?...always losing them. Triumph 10
AH67 BJ8 losing power and enguine dies Austin Healey 9
Gerald_Gordon TR4/4A Hard door closing after replacing rubber seals Triumph 8
T Spitfire Spitfire losing power Triumph 8
D Wedge TR7 Carburetor losing dashpot oil Triumph 8
BN6_2197 Door opening/closing mechanism of BN6 Austin Healey 2
aeronca65t MGs [and Triumphs]-junkyard closing MG 2
T Healey's at the Olympics Closing Ceremony Austin Healey 4
TR4A_IRS Any TRs in the closing ceremonies? Triumph 3
Bob Claffie Closing down British Motor Corp 0
Perrymip TR2/3/3A TR3 Losing Its Cachet Triumph 42
chrpark university motors closing [john twist] Spridgets 3
Jer the "season" is closing in on me Spridgets 10
tomshobby MG shop closing. Spridgets 12
dklawson University Motors Closing Triumph 1
dklawson University Motors Closing Spridgets 12
roofman Forum closing? Spridgets 1
roofman Forum closing? Triumph 3
roofman Forum closing? Austin Healey 13
roofman Forum closing? MG 9
Number_6 Is British Car Forum Closing? Triumph 53
tony barnhill '85 XJ6 Losing Anti-Freeze Jaguar 21
Sopwith_Camel losing oil presser again Spridgets 8
RickB 1964 Midget on eBay -closing today, nearly 10K nfi Spridgets 10
danmas Advance Auto-Wire closing Triumph 18
danmas Advance Auto-Wire closing MG 21
Baz Losing my transmission. Spridgets 15
MadRiver Lound "clang" on closing driver's door Triumph 2
T Wedge TR8 motor rebuild budget - I'm losing it. Triumph 21
2wrench TR6 TR6 Burning/losing oil, what do you think? Triumph 7
T Losing Coolant Triumph 6
aeronca65t Road Atlanta-Closing? Racing 16
jollyroger Sprite Parts Vortex final closing deals. Spridgets 0
Ed_K Basil was considering closing the BCF ??? Austin Healey 13
jcatnite Forum Closing? Spridgets 17
sparkydave Losing oil pressure Spridgets 14
Alfasudcrazy TR6 TR6 contact breaker points - closing Triumph 3
Mickey Richaud Closing in on the Problem MG 21
Sarastro TR4/4A Exasperating experience with voltage regulators Triumph 3
wkilleffer MGB 1974 MGB SU fuel pump voltage issue MG 11
K TR2/3/3A TR3 with alternator conversion... red light stays on and low voltage on the voltmeter gauge? Triumph 1
Sopwith_Camel MGB voltage regulator MG 11
7 What voltage regulator? Other Cars 21
R TR6 No voltage at solenoid tap Triumph 7
L BUG EYE WHAT CAUSES A VOLTAGE REGULATOR TO STICK ON WHEN U TURN KEY OFF Spridgets 3
