Long time Spridget poster looking at BT7
Whitephrog
Been involved with Bugeye Sprites for may years. Age and size (6 foot 3; 235 lbs) have me looking at a big Healey. 1959 BT7 Primrose RHD. Last on the road in 1982. Car appears solid upon initial inspection.
Need advice from this group. Where are the gotchas? What should I be looking for?
HealeyRick
Rust, rust, rust. Check the frame very carefully for rust repair and basically everywhere along the bottom 1/3 of the car. Then check the shrouds for bondo. Engines are pretty solid, just losing oil pressure until they eventually give up. Remove the valve cover and see if it oil squirts up from the rockers, showing a bad rocker shaft. Transmission weakness is usually worn synchros or noisy gears. Give it a good test drive and be prepared for a very different experience from the bugeye. It's nowhere near as nimble.
Turn ignition to 'run' position; if car has good battery--probably not--you should hear the fuel pump clicking (rapidly if the tank is near/empty). If not, the points in the pump will need to be cleaned (at the least). Check coolant, if rusty in color reconsider this car. Every rubber component will need to be replaced (starting with tires).
Oh, and rust.
DerekJ
The biggest problem with all old Healeys is rust. However don't assume just because the wings and shrouds look reasonable that the rest of the car is probably OK. The key parts that must be good are the chassis, which can be inspected on a lift, the rear and front substructures which together with the chassis give the car its solidity (or lack thereof). The wings and shrouds just hang on the structures and do not really add structural strength. The centre body pieces (shrouds) front and back are aluminium so are generally Ok but look for electrolytic corrosion where they meat the wings. The inner sills may be rusted out as well. The aforementioned is where the major problems and costs are found. The mechanicals are generally robust, simple to work on and all parts are available.
Good luck.
The rear 'doglegs'--the bottom front of the rear wings--will either be rusty or will have been replaced at some time. Often, the dogleg is not correctly situated, causing a 'spur' to protrude and spoil the slight upward and inward curve along the bottom. You see this on a some otherwise nicely-restored cars.
Run your fingers along the edge of the fender wells; there is a rolled bead along the edge and if repairs have been made it might have been cut and damaged.
glemon
Make sure you fit, of course if you are used to Sprites it will feel relatively spacious. I fit in my 100 pretty well at 6' 0" 200 lbs, but it was very snug with the top up, of course I never drove it with the top up, and the sixes might have a little more leg and or head room.
Others gave good advice on rust, I bought a BMW 2002 a couple years ago, I know a different car, but the story relates, I knew it had rust, but the rockers and lower fenders were pretty good, so how bad could it be? Of course someone had done a superficial fix to the exterior, and the inner chassis was rotten to the core. Same can hold true for big healeys, or pretty much any car for that matter. If the engine turns over that would be a good sign, they are pretty robust.
regularman when is the next spridget gathering? Its been too long folks :D Spridgets 20
regularman The spridget long trip emergency tool kit Spridgets 21
B TR6 Crankshaft long seal surface Triumph 5
jfarris Message too long error FORUM Navigation Questions 8
L My 1951 Triumph long ago British Motorbikes 0
KVH General Tech Flywheel Bolts Too Long For Main Seal Triumph 13
W Generator and Starter Long Bolts Spridgets 0
Popeye TR4/4A Slave rod seems too long but is not Triumph 7
A Land Rover V8 3.9L long block core for sale Rover / Land Rover 1
Jayplum For Sale SU HS6 for sale along with a long intake Triumph Classifieds 3
Zitch Engine Oil Leak After Long Drive Austin Healey 19
K TR2/3/3A Clutch "Long Throw" Slave Cylinder? Triumph 4
G TR2/3/3A Finding a long lost TR3 Triumph 4
R The long road home Spridgets 1
Y MGB An odd (and probable long-shot) request... MG 5
roscoe Rear end crown and pinion gear swap. 4.11:1 to 3.54:1 [long read] Austin Healey 12
R TR2/3/3A Restoration of 1954 TR-2 Long Door Triumph 6
T BT7 throttle relay levers short and long Austin Healey 2
S For Sale 3000 BJ8 Laycock 4 speed with 22% OD trans & 2 6 cyln engines / long blocks / BUNDLE Austin Healey Classifieds 1
Michael Oritt Post- Open Roads 2002: Tahoe to MD the long way Austin Healey 19
R TR2/3/3A Restoring a 54 TR-2 Long Door Triumph 10
boxofparts TR2/3/3A My long term 30 yr project Triumph 5
K For Sale Long and short TR3 and 4A Intake manifolds Triumph Classifieds 0
Joe Schlosser Thoughts on a long traffic Light Spridgets 11
R TR2/3/3A Restoration of 1954 TR-2 Long Door Triumph 22
D Long Lost Midget Spridgets 0
E Long lost Sprite Spridgets 10
roscoe Leakdown test [long read] Austin Healey 11
aero3113 Healey Shop on Long Island Austin Healey 9
britlover Wanted TR4 Hood long bubble Triumph Classifieds 0
D MGB Painted rubber bumpers. How long will they hold up? MG 1
T C42 BJ8 generator long screw needed Austin Healey 2
PeterK General TR Time for a long ride Triumph 3
D After a long break.... Spridgets 6
Lotus Club SoCal Ballast Point Long Beach Social Lotus 2
Popeye TR4/4A Found this odd long bolt in my fuel tank... Does anyone know what it is? Triumph 17
GTP1960 Not the "best car ever made" by a long shot Other Cars 14
L TR6 need help on long dead TR6 Triumph 16
Sarastro Morris Minor in Long Beach, CA Spotted 1
D TR4/4A extra long oil filter attachment stud Triumph 9
D TR4/4A flywheel bolts maybe too long Triumph 15
Sarastro Red TR3 in Long Beach, CA Spotted 0
Jim_Gruber I woke up Bugsy this afternoon after about a month long nap and he was cranky Spridgets 7
TomMull Post-War Other Herald: Holy Moly! [Why it took me so long to make the accelerator bracket] Triumph 2
Marla TR4/4A Take the long way home Triumph 11
K TR2/3/3A How long should an SU damper top up last? Triumph 22
steveg Very interesting very long blog posting - racing oil and zinc Austin Healey 44
Got_All_4 TR2/3/3A Tr6 a type overdruve in my tr3 too long Triumph 10
TomMull TR2/3/3A Long Door anyone Triumph 16
