lighter socket
floyd
good afternoon all, could someone tell me where the lighter socket is powered from on a 75 tr6. I have looked at the wiring diagram and can not find it. It looks like it shoots over to the passenger side dash then goes up from there. Right now I have no power to it and all 3 fuses on the front left inner fender fuse block are good. Thanks for any info and Happy 4th....
The reason you can not find it in the schematics is that the factory never put a cigarette lighter in the TR6. Yours just like everyone else's was added at some point by a PO. You will physically have to trace the wire from the socket to where ever it was connected. For mine I installed an in line fuse and connected it right to the battery so it is always live.
B Cigarette lighter socket Austin Healey 15
BJ8Healeys Cigar lighter for '73 MG Midget MG Classifieds 4
HealeyRick Cigar Lighter Austin Healey 18
B TR2/3/3A Cigarette Lighter Install Triumph 7
aero3113 Lighter Add Austin Healey 0
D Cigar/cigarette lighter Spridgets 4
D Spridget Cigar Lighter? Spridgets 4
B MGB 78 MGB cigarette lighter..anyone have one? MG 5
DerekJ Original Cigarette Lighter Austin Healey 10
T XKE S2 - Cigar Lighter Mounting Jaguar 3
T Mounting a cigarette lighter - where? how? Austin Healey 20
TimK cigarette lighter - accessory plug Austin Healey 12
6 Fiberglass Lighter than Steel? Austin Healey 7
DNK Lighter flywheel inf Triumph 4
tahoe healey healey cigarette lighter Austin Healey 0
DanNagy Cigarette Lighter Triumph 15
Camshaft MGB MGB Cigarette Lighter MG 10
I TR6 TR6 cigarette lighter placement? Triumph 4
beaulieu what to use for lighter trailer ramps + mounting Racing 3
A cigar lighter Austin Healey 18
NutmegCT cigarette lighter wiring MG 13
A BJ8 - Cigar lighter location Austin Healey 3
Sherlock On a lighter note... Our favourite art cars Other Cars 0
Basil Socket Organization Restoration & Tools 9
D Socket for TR3 Gear box drain plug Restoration & Tools 6
K TR4/4A TR4 Fuel Gauge'"light bulb socket" type? Triumph 11
S TR2/3/3A the 9/16 & ½ tube socket for the tool kit Triumph 13
B TR6 WTB: Side marker socket 1971 TR6 Triumph 2
BoyRacer Top bows - plastic sleeve for socket Austin Healey 0
B Looking for rear marker light for 73 midget...just need the socket part or whole,also Spridgets 0
Scotsman Square Drain Plug Socket Restoration & Tools 7
PC power bit to square drive socket adapters Restoration & Tools 3
B Socket down in the front brace box section Austin Healey 20
K Side curtain dzus screws and "Socket"? Triumph 4
hondo402000 TR6 NEEDED rear light socket TR6 for reverse lamp Triumph 10
G Size of socket to turn over 1500 engine by hand Spridgets 9
G Socket size to turn over 1500 engine by hand Triumph 4
W 8 point axle nut socket Austin Healey 5
Jim_Gruber Need Light Bulb Socket / Turn Signal / Behind Dash Spridgets 1
L Crank pulley socket? Triumph 10
C MGB 1979 MGB steering wheel socket? MG 1
R 2 3/16" axle nut socket Austin Healey 61
V New Grade 12.9 Socket Head Bolts Triumph 2
tomshobby Looking for spark plug socket. Restoration & Tools 15
H Tonneau socket question MG 17
S TR2/3/3A Tr3 gas pedal shaft socket Triumph 7
trrdster2000 Light socket repair Triumph 7
Obtong Rear Axel Socket Size? MG 3
