Left shock
MGGuy
Member
Hi all.
I removed both front shocks to paint the area. Right went back in no problem but when I went to put in the left it was extended down and won't go in. I tried applying some force to extend it back up but did t want to apply too much without asking advice. I was going to out it in a jig and use leverage. Any advice?
I think something is wrong - you should be able to adjust the lever by hand. You shouldn't need a jig. Obvious question but you haven't put them backwards and trying to bend it backwards? They might also need rebuilding - in which case World Wide Auto parts (Peter) is your guy
Ok, thanks, I'll contact Peter
I finally replaced all of mine - amazing the difference it made, like an old mattress you don't realize how bad it is until you get a new one.
John Turney Left Rear Shock Mount Austin Healey 5
L Oil under left front shock Austin Healey 7
Shinsen774 My Left Front Lever Shock is Leaking MG 11
B MGB Brakes scrapping sound from rear brakes on hard left or right turn. New wheel cyl, drums shoes ? MG 2
K TR2/3/3A A TR3 plug check left to right 1234...do I lean out front carb a couple of flats?...turn down correct? Triumph 3
DornTRoriginal Wanted TR3B Left rear fender Triumph Classifieds 7
J SOLD!! Triumph TR2 TR3 rocker panels, right and left Triumph Classifieds 0
tr6nitjulius General TR Plenty thread left on my old OEM 185 Redlines Triumph 5
J For Sale Triumph TR3 door, left, for sale Triumph Classifieds 0
bighealeysource Burning Smell from Left Rear Wheel Austin Healey 14
S For Sale Triumph TR 2-3 Front Left Fender Triumph Classifieds 2
C Spitfire Mystery wires - Spit, left near distributor Triumph 2
equiprx Left over parts from my 1994 XJS coupe project Jaguar Classifieds 0
P TR6 What make and size tire was on the TR6 when it left the factory? Triumph 7
Martinld123 My left rear wheel is locking up Austin Healey 16
B TR2/3/3A TR3 sag to the left [port sag] Triumph 10
M TR2/3/3A Brake Line Removal From the Left Frame Rail Triumph 14
M Wanted Bj8 left front wing Austin Healey Classifieds 3
Y For Sale MK V DHC interior wood for Left Hand Drive Jaguar Classifieds 2
5 Wanted Wanted Parts to convert BN2 from left hand drive to right hand drive Austin Healey Classifieds 0
J BJ8 Phase 1 left turn signal [driver side] Austin Healey 16
K TR2/3/3A Isit possible to buy a single left hand thread tie rod end? Triumph 5
Rut I’ve lost my mind, or what’s left of it! Spridgets 12
Tosh TR6 Engine dies slow left turn. Triumph 26
K Left my key on for 5 hours and wont start, UGG!!!!!! Austin Healey 48
F BN7's left Austin Healey 9
Gliderman8 TR6 Removing Left Rear brake line... help! Triumph 9
PeterK General TR Timely memory of a time capsule left in my 3A Triumph 19
C Left to right hand drive Austin Healey 2
Lotus Club SoCal Left Coast Octoberfest Lotus 0
T Wanted TR6 Left Taillight Housing Triumph Classifieds 0
T Wanted 1960 Jaguar MK2 front door wood trim, both right and left. Jaguar Classifieds 0
Boink Left-hand Drive E-type at Windsor Jaguar 5
5 Wanted Wanted Parts to convert BN2 from left hand drive to right hand drive Austin Healey Classifieds 1
S TR2/3/3A Oil Leak Dripping from Front and Rear of Left Side Oil Pan---Only While Running Triumph 14
Michael Oritt Wanted Wanted: Left side axle tube tip Spridgets Classified 0
C BN1 sitting lower at left rear - I'm told that's normal - really? Austin Healey 13
B TR2/3/3A Tr3a brakes pull to left on hard braking Triumph 9
Popeye TR4/4A Seats - left/right Triumph 8
C TR4/4A left brake lamp not lighting TR4A Triumph 4
Jim_Gruber Bugsy II - Left for a new home this morning Spridgets 4
P TR6 Left direction signal no work Triumph 15
D 69 E-Type sputters when making left hand turn Jaguar 6
D TR2/3/3A 1957 Girling adjuster on left rear drum frozen Triumph 8
GTP1960 TR2/3/3A New left front wing body panel from TRF? Triumph 11
M TR4/4A Left lower dash crash pad. Triumph 5
C Brakes pull to left - especially when cold. Where to start??? Austin Healey 11
P T-Series TD Door Hinges: just what is the difference between right and left? MG 10
K TR2/3/3A Pullsl to the left when accelerating? Triumph 9
AngliaGT What Goes to the Left of the Tach? Spridgets 3
