TR2/3/3A Just a Curious TR2 Question...
M_Pied_Lourd
Looking at this car on eBay...I know that it's been advertised many times before...
https://www.ebay.com/itm/Triumph-Ot...ad5be5a7:g:aHcAAOSw5VFWJ8ZO&item=221951813031
I'm curious about the rear bumper overriders...have a look. Did they not bolt up to the frame through the rear apron as the later cars do?
The other thing that bugs me is the installation of the steering shaft boot in the engine bay...why would you not fix that? :smile:
Cheers
Tush
The commission plate tucked under the bulkhead panel and the conversion to short doors makes me a little suspicious, but it still looks nice. Also, to be fair it could be a good fun driving car. I'm just too picky anyway.
Dan
The rear bumpers did originally have the tubes to the frame; someone has just filled the holes with Bondo and not discovered until later what they were for.
Same with the column boot, just sloppy work IMO. Ditto the steering wheel, chrome hinges, sheet metal screws on the commission plate, battery box, stray wires around the wiper motor, wing beading, and so on.
Funny...the overriders are installed upside down too...and the brackets backwards! The commission plate is re-stamped by hand and screwed on...makes you wonder about the short doors? I don't think it was converted to short doors, but rather a lower number put on a later car.
The plate discrepancy might be why it has been relisted several times. At least grounds for a deep discount.
D TR2/3/3A curious tachometer take-off Triumph 5
D TR4/4A now I'm curious Triumph 7
glemon Curious Part II Spridgets 0
N Curious?? Spridgets 13
matmire Curious if these photos tell you anything about my car. Spridgets 24
J TR4/4A TR4A Just Curious Triumph 15
M Just curious Triumph 20
B Curious question..Engine Coolant container MG 10
5 Curious BN4 engine pic Austin Healey 3
M Curious Spridgets 42
M Just curious Oil Question Spridgets 5
Jim_Newman A Curious Hole Austin Healey 5
K Curious about 1966 Jaguar S-Type Saloon Jaguar 5
T Just curious - 1971 Jag XKE 6 cyl value Jaguar 13
SkinnedKnuckles Just Curious - Where are the Old Pro's Triumph 28
G Just curious while waiting on parts!! MG 30
B I'm just curious- what do these fit? Spridgets 4
wkilleffer Curious about compression check results MG 5
JPSmit Tonights curious solution Spridgets 3
AUSMHLY Curious, what is the most view topic Austin Healey 3
G Curious.... Triumph 30
JPSmit Curious ad Other British Cars 11
ronzet Curious glowing on my Tail lamps MG 28
G Just curious Rover / Land Rover 1
T Curious holes? Triumph 1
D BJ8 Interior Panels - Just Curious Austin Healey 3
G Curious.... MG 24
Gray_Cat Curious Carb "Accessory" 55 BN 1 Austin Healey 5
S TR2/3/3A I found an Original tr2 grill and Apron Triumph 6
Hamish Racing TR2/3/3A Interesting period picture TR2/3 aircraft transport Triumph 1
T TR2/3/3A Early TR2 Grille surround moulding wanted. Triumph 14
T SOLD!! TR2 through TR3B Bonnet Hinges Triumph Classifieds 0
J SOLD!! Triumph TR2 TR3 rocker panels, right and left Triumph Classifieds 0
J SOLD!! Triumph TR2 TR3 Channel - Drip - Rear Edge Triumph Classifieds 1
J SOLD!! TR2 TR3 Tie Member Triumph Classifieds 6
Nanhook TR2/3/3A TR2 shoes Triumph 2
CJD TR2/3/3A TR2 Annual Triumph 6
S TR2/3/3A WTB a tr2 original grill Triumph 0
P TR2/3/3A TR2 Horn Mounts Triumph 7
mctriumph For Sale Tr2/3 scuttle mechanism Triumph Classifieds 7
S Wanted tr2 original grill Triumph Classifieds 10
J TR2/3/3A TR2 Fitting/mounting rear wing Triumph 11
A TR2 Transmission overhaul Restoration & Tools 0
D TR2/3/3A TR2 Flying Mile question Triumph 11
S TR2/3/3A tr2 muffler clamp Triumph 10
Southwarks TR2/3/3A TR2 door help! Triumph 2
