Jaguar XJ6 Door Locks
rupertle
Electric door locks do not work. Have replaced the door lock module which is getting power. Even stuck in a different CPU. Gas cap lid unlocks sometimes. I need some ideas about how to diagnose the problem. The wiring diagram is pretty simple but I don't see what other component that could cause the problem.
You'll really need to describe the car better, Series I, II, III, XJ40, X300?
Assuming an XJ40, remember all the lock buttons have to be either UP or Down (synchronized) in order for it to work. Do you have the S57 wiring diagram? More info please
Sorry, 1992 XJ40. I have tried synchronizing more than once. I have the wiring diagram from Haynes also I have the Jaguar CD Service Manual Vol 1 - 8. What is a valet switch?
Suggest removing each interior door panel and lubing the lock mechanism connections all through the linkage with WD-40 or Kroil. You can have enough friction from age adding up together to overcome the solenoid being able to move the linkages.
Valet switch is located on the dash. Forget what the symbol looks like. It should be described in you owners manual.
Searching shows you are far from alone in this issue. However, the causes seem to be many.
Stiff mechanisms, as stated earlier, grounds and ground contacts inside door handles, one of two power supply sources to module, valet switch, etc.
Granted, one or more door lock mechanisms might be stiff--but would that cause all of the door locks not to work? Also one would expect to hear mechanisms trying to work if solenoids are getting power.
I believe there is someone out there who knows how to diagnose this problem. Where is that person?
R For Sale For Sale 1990 Jaguar XJ6 Jaguar Classifieds 0
A For Sale 1986 jaguar xj6 Jaguar Classifieds 0
D Posi-Rear end in a series 3 Jaguar xj6 Jaguar 12
K 72 Jaguar XJ6 4.2 litre motor reliability? Jaguar 4
CZ_Dave A Redneck Jaguar XJ6 Spotted 9
CZ_Dave A Redneck Jaguar XJ6 Jaguar 2
W Removing windows in 74 Jaguar XJ6 Jaguar 1
M Won't Start-1995 Jaguar XJ6-Why Jaguar 8
brendanf Starting Problems Jaguar XJ6 1982 Sovereign Jaguar 10
T 1989 Jaguar xj6 key and headlights Jaguar 7
S Jaguar XJ6 3.2 T-Reg .....Erratic Idle!!!! Jaguar 3
tony barnhill My Recently Acquired 1985 Jaguar XJ6 Jaguar 59
S 86 Jaguar XJ6? Jaguar 7
C your view on the Jaguar xj6 89 Jaguar 4
G 1988 Jaguar XJ6 On State Auction Anyone want it? Jaguar 0
L For Sale JAGUAR E – TYPE: IRS REAR AXLE (EARLY), 2,88:1: Jaguar Classifieds 0
LarryK Wanted 1957 Jaguar MK1 sedan bumpers. Jaguar Classifieds 0
K For Sale 1993 Jaguar XJS Convertible Jaguar Classifieds 0
R For Sale Jaguar MK2 Heater Core (Matrix) Jaguar Classifieds 0
O Jaguar rear window trim repair Jaguar 1
J For Sale Bilstein Front Shocks for Jaguar E-Type 727-498-6493 Jaguar Classifieds 0
K Putting a Getrag 5 speed OD transmission in a Jaguar Mkll ? Jaguar 4
Bristol401 For Sale Jaguar Mk2 Jaguar Classifieds 2
M For Sale 2017 Jaguar F-TYPE Premium 2-Door Convertible for Sale mlbirk@aol.com Jaguar Classifieds 0
CJRams For Sale 1969 Jaguar XKE Jaguar Classifieds 0
T Motor Jaguar 4.2 Jaguar 14
D 1992 jaguar xjs abs Jaguar 1
L For Sale 1959 Jaguar Mark 1 Jaguar Classifieds 0
TireKicker847 Wanted 07 Jaguar XK trunk covers Jaguar Classifieds 0
AngliaGT Jaguar XK120 (?) on I581 Spotted 1
J For Sale Jaguar E Type and MK2 spares Jaguar Classifieds 0
Lin Jaguar Distributor Cap for Healey Austin Healey 8
J For Sale For Sale in Seattle, WA: 1989 Jaguar XJ-S Convertible_$11,200 Jaguar Classifieds 1
S SU carbs AUD9124 on a Jaguar ? Jaguar 2
Rut Jaguar 340 Jaguar 8
T For Sale Gear reduction starter fits jaguar 3.8 340 mark series 3.8l 3.4l - $100 Jaguar Classifieds 0
LarryK Jaguar MK1 restorations Jaguar 15
M Jaguar XK Special Equipment Generator Jaguar 1
T Wanted 1960 Jaguar MK2 front door wood trim, both right and left. Jaguar Classifieds 0
K For Sale Rare Book The Jaguar XK in Australia Jaguar Classifieds 0
Got_All_4 For Sale Triumph Austin Healy Jaguar 15"x5.5" Complete Wire Wheels Set & Hubs Triumph Classifieds 1
J Anybody driving a 2018 Jaguar XJ? Jaguar 3
69MGC Latest Jaguar Digital Illustration Jaguar 0
B For Sale 1969 Jaguar XKE 4.2L Series II Coupe - Indiana Jaguar Classifieds 0
M Planing a Jaguar cylinder head Jaguar 4
David Townsend Limited Edition Jaguar Puzzles Jaguar 0
T Wanted Jaguar MK2 fuel tank and Radiator Jaguar Classifieds 8
M Wanted Jaguar XK140 OTS Battery Door Jaguar Classifieds 0
M What is the finish Jaguar Uses on Veneered Trim Pieces? Jaguar 4
nevets Jaguar reissuing the D type. Austin Healey 9
