It only took me four years!
Platinum
To get around to resetting the float levels in the Alfa's Webers. Hey, it ran passably... and as a friend says: "A wrench will drive a car with things going on, quirky things that no NORMAL person would put up with." So true.
Now it idles a bit smoother and transition from idle to GO is a lot less "sloppy"... shoulda dropped 'em down to 10mm long ago. PFFT!! It ran well... well, it RAN, durnit. /ubbthreads/images/graemlins/hammer.gif
& cobblers' kids have no shoes
& carpenters' wives need things around the house repaired
& plumbers' wives have sinks that leak
...now about this *unseen* secondary hard drive in this client's machine... ggrrrrrrr....
[ QUOTE ]
[/ QUOTE ]
No kidding... I could go for days on that one...
manual trans Celica that the DPO had replaced vacuum lines with wood screws... never would idle... drove it for 2 years with all 3 feet.
Dodge dart that the tranny shifter linkage would pop out - just crawl under the car and pop it back in... never took the 10 minutes to find a cotter pin and fix it because it never happened when I was home.
Buick Le Sabre that had a short in the steering column and would die when you turned the wheel all the way to the left. (watched the guy who bought it from me spend 10 minutes trying to pull it out of the parking space - I tried to tell him what was up but my spanish is limited to ordering beer and finding a place to whiz)
Grand Prix with a broken driver-side door handle link on the outside only - just crawled across the passenger side for about a year. Came out some day and someone had broken out the little side window on the driver side... apparently they couldn't get the door open and left.... Next night they busted out the passenger window and stole the car.
Used a screwdriver for a shifter for a few months... until the MoT inspector declared it unsafe (spoilsport) and it had to be properly fixed or else.... /ubbthreads/images/graemlins/frown.gif
Didn't buy my argument that it was a removable security enhancement.... /ubbthreads/images/graemlins/confused.gif /ubbthreads/images/graemlins/yesnod.gif
Me Ol' Fella bought a Capri, one'a the 1600's, without consulting me... I was in S.E.A., so kinda "incommunicado" at th' time.... I "borrowed" it a few years later when the Elan came up lame. Went to th' "local" one eve, and on departure as I gingerly slipped it into reverse the shifter snapped off at th' nub! Bloody THING. I drove it around for a week with a great-giant set of ViseGrip pliers from outta th' trunk as a shifter. "QuikShift Kit"!!!
I ~did~ replace th' shifter before returnin' it...
And I've been driving a '72 Midget for about 4 years with the alternator light on dimly. Hey, it starts every time, runs ok, and charges. Who cares about an idiot light?
Jeff
My first car (’67 Mustang) had a bad door latch on the driver’s side. When I made a right turn, the door would fly open. Took a piece of rope and tied the door handle to the passenger side door handle. Thought of it as a secondary lap belt. /ubbthreads/images/graemlins/wink.gif
"Improvise. Adapt. Overcome!"
This Spider I drive as a commuter has a "softly" glowing charge light at low RPM... I shoved a voltmeter into an empty hole inna console, it has a 14V charge while under way. Starts every time, lights are bright when necessary so "huckit" as me Ol' Fella used to say. When it kacks I'll fix it. Otherwise I have more important stuff to do, like hangin 'out here inna BCF an' suchlike /ubbthreads/images/graemlins/wink.gif
[ QUOTE ]
[/ QUOTE ]
Surely its signalling for a classic DPO "fix". /ubbthreads/images/graemlins/yesnod.gif
Disconnect it. /ubbthreads/images/graemlins/crazyeyes.gif
How could you possibly resist? /ubbthreads/images/graemlins/devilgrin.gif /ubbthreads/images/graemlins/jester.gif
[ QUOTE ]
Jeff
[/ QUOTE ]
My 74 MGB's alternator light glows a bit when the headlights are on at night. It pulses with the turn signals. It's a rebuild from one of the major chain auto parts stores and has a lifetime warranty. Replacing it might take some planning to make sure the store gets one, but that doesn't matter. Every time I clean the wiring connectors, the glow gets dimmer.
ok= 56 Merc has hairline crack at radiator neck & leaks oil...59 T-bird has a driver door that resists remaining closed.....54 Chevy-no powersteering and checking brake fluid is under floor mats on drivers side(came that way)3 0n tree and second has been known to stick......miget -no turn signals,but I have arms/come to think of it the 54 Chevy's don't work either.....71 Couger convert has exhaust leak.....64 mustang convert has short in dash lights..... it goes on & on & on......I've learned to adjust -but I check everything
Regarding the persistent warning light problem, I prefer Click 'n Clack's solution - black electrical tape!
Mickey
I actually prefer the light, Mickey. It gives the dash such a colorful, festive, look. /ubbthreads/images/graemlins/grin.gif
Jeff
[ QUOTE ]
Jeff
[/ QUOTE ]
Well, of course, there is that. Too bad they don't come in purple, green and gold for Mardi Gras /ubbthreads/images/graemlins/jester.gif. But then, it IS Lent, so we're supposed to get rid of all the festivity!
By the way, the jester icon kinda looks Mardi Gras-ish.
/ubbthreads/images/graemlins/laugh.gif Mickey
[ QUOTE ]
[/ QUOTE ]
Friday I was going to a Saint Patty's day Guinness drinking contest at an Irish pub & had some complainers along for the ride. Seems they were being overly critical about the condition of my Toyota.
The pads are down to the screech tabs
Front shocks are dead
Tires are so cupped it sounds like a helicopter around turns
The shift cable needs adjustment
And the E-brake doesn't work
If you neglect to perform routine maintenance on your daily driver.
You can almost get that wonderful out of control/racing feeling from a simple commute.
Ah-HAH!! So that's why we're grinnin' like fools onna way to work. Absolutely outta control. Silly me...
jlaird MGB Took my weekly trip MG 2
I Took the car for a spin today...! Austin Healey 4
Marvin Gruber Took the E for a spin today Jaguar 1
TomMull Post-War Other Herald: Holy Moly! [Why it took me so long to make the accelerator bracket] Triumph 2
drooartz Took Penny for a drive tonight! Spridgets 11
B getting closer...only took about 8 years! Spridgets 4
D OK..took the plunge!!!!!!!!!! Sunbeam (Rootes) 7
B Generator not working, took apart, what's next? Austin Healey 33
drooartz Brief respite from the rain, took the B out MG 3
M Took my car out for a spin [video] Triumph 3
justin_mercier Wedge Took the wedge out for a little spin. Yay! Triumph 14
PeterK TR2/3/3A Took the 3A out today Triumph 5
T Took a drive today!!!! MG 9
T Took a little drive today... MG 9
RickB Beautiful Fall day in NW took the dog for a ride! Spridgets 17
T Well, took a while but I got her running. Spridgets 11
Trevor Jessie I took my two little girls to the autoparts store Spridgets 22
regularman Took a nice cruise today. Spridgets 21
Dadandson My 1974 Midget took Second!! Spridgets 6
regularman Took a nice drive in the Midget today Spridgets 15
regularman Took midget for a spin yesterday. Spridgets 26
jlaird Took a nice drive today Spridgets 6
Musicman Took a drive today... Triumph 21
SwamperCa TR6 Up-date on 70 TR6 I took a look at Triumph 6
regularman Took another look at the paint Spridgets 23
jlaird I took your advise Spridgets 4
J took a chance on ebay and I think it worked out Triumph 5
T Had the camera...took some pics Spridgets 4
T Wedge took the TR8 plunge yesterday. Triumph 21
Brosky Well, it was only 16 degrees, but I took her out Triumph 29
T Took the TR8 race car out today Racing 1
Got_All_4 YIPS Took out 4&1/2 gal oil & gas from crank case Triumph 18
Trevor Jessie OK, I took the plunge Spridgets 17
zimmy took my mom for a ride ; ] Spridgets 5
B Took Mom For A Ride. Spridgets 0
T TR6 Took my TR6 to the drag strip Triumph 5
MadRiver TR5/TR250 Took our TR-250 for a short spin! Triumph 0
kbash Took Liz for her first LBC Experince MG 1
H Took the 850 for a spin Other Cars 7
Mickey Richaud Wedge Took the TR8 Out Tonight Triumph 7
H Took TVR to H.S. reunion this weekend Other British Cars 3
J took the car out for the first ride of the season. Austin Healey 3
S TR2/3/3A Took the TR3 out for Winter exercise Triumph 7
I Warm weather today! Took the XJ out of storage! Jaguar 1
CARSINC For Sale Four Octagonal Knockoffs Spridgets Classified 0
F For Sale Four Steel Wheels Triumph TR3 or TR4 Triumph Classifieds 5
maxwedge5281 bn6 two seater trunk versus bt7 four seater trunk Austin Healey 27
JPSmit Question four - headlight trim ring Spridgets 9
T Morgan Plus Four Presssure Plate Other British Cars 1
J Can A BJ7 Two Light Schroud Be Coverted To A Four Light BJ8 Style? Austin Healey 6
