    BCF is a FREE resource for the Little British Car community. I just did a little math and found that less than 1% of the registered members appreciate this forum enough to support us with an account upgrade. We do not "require" you to pay to play here, but if you find BCF helpful, appreciate no pop up ads, and want to ensure we stay online - Consider supporting us with an "optional" low-cost member upgrade. There are some benefits to upgrading!
Is this turkey done now?
T
Tinster
Thanks everyone for the tips and hints on how to adjust valves
on my '69TR6.
I used a little bit of everyone's advice. Kentvillehound
posted a link to Macy's garage that did the trick for me.
It made so much sense I used the single cylinder at a time
method of rocker arm adjustment. Macy's article make a lot
of sense.
I was quite a bit off on a few using the Bentley method.
Anyway- Amos started instantly on the very first push of
the remote started button. Settled into a steady 900 RPM
warm idle.
Here is a video clip of my latest rocker arms effort. Any
obvious bad sounds or bad visuals. I'd like to put the
valve cover back on and drive it. Timing set at 10* advance.
Rockers set at .010" (I feel just a slight resistance to pull)
Are we done here?
Best regards,
dale(tinster)
I'd put the cover on and head for the mountains.
Good job!!!
Turkey done! Tasty, too.
As all us NASCAR guys say "Fire that sucker up" and get on with the trip.
Wayne
I think the Turkey should get some rest and put the valve cover back on then take it for a nice long ride'
Enjoy Turkster'
That's not a good idea to introduce here just now, MD.
...let's hear the thing went for a good long romp without losing thrust bearings or had a frammis valve failure before suggestin' any over-tech options, mmmmkay?!?!
:devilgrin: :jester:
<span style="color: #660000">Brand new crank thrust bearings Doc,
less than 600 miles on them. Front end float is .007"
They are a non-worry for the worrywart!! :lol:
Roller rockers will never be fundable.
I happy my car runs.
best regards,
Dale(Tinster)</span>
That engine sounds great Dale, I think you've got it nailed! I'm hoping that it's all set now and you can really start to drive and enjoy it. You've stuck to it, put a lot of hard work into it and deserve to have a great time with it! Go out and have some fun! :banana:
Doc, as you well know the frammis valve CANNOT fail unless he forgot to install his T angle extender.
Or the crankshaft was installed upside down.
...after which you have to change the plug leads, since the engine will now run backwards.... :devilgrin:
Andy- you are pretty close. I DID change the dizzy cap lead
wires by rotating all of them 60* clockwise. The car runs
much better with this arrangement and is easier to start.
Thanks for the tip on the plug leads. I'm one step ahead of
you on this one!!
I recently replaced the crank thrust bearings at the front of
the engine so I know they are good. But WOW!! What a
difficult task! Moss Motors also shows crank bearings at the
rear of the engine. Should I check them out as well? My new
endfloat is .007"
Best regards,
dale(Tinster)
I thought that it was button down and drive time? With .007" float, I'd be driving that bad boy more and worrying about the thrusts less.
Having got Amos to this stage, I think that you should now move on to the advanced Triumph maintenance regime. "If it ain't broke, don't fix it!"
Michael Oritt VRG Turkey Bowl XXI now open for registration Racing 0
Elva164 2014 VRG Turkey Bowl Video/Picture Thread! Racing 4
Michael Oritt Saturday feature: VRG Turkey Bowl at Summit Point Racing 10
M TR2/3/3A fuel pumps from Turkey Triumph 5
jlaird Have a great Turkey day. Spridgets 4
aeronca65t Turkey Bowl-TVR TVR 12
aeronca65t More Turkey Bowl Photos Racing 7
aeronca65t LeMans Start [modified] at Turkey Bowl today Racing 7
Michael Oritt Turkey Bowl 2010 Racing 7
TR6oldtimer What I did on turkey day Triumph 11
G Turkey Bowl Spridgets 1
aeronca65t Turkey Bowl-2008 Racing 4
jhorton3 Turkey Dodge Spridgets 3
jlaird Happy TURKEY day Spridgets 6
Tinkerman Turkey In The USA Triumph 13
aeronca65t Turkey Bowl Pictures Racing 5
Michael Oritt VRG Turkey Bowl at Summit Point Racing 23
danmas Turkey day sale! Triumph 0
1 Pictures from the Turkey Rod Run in Daytona Beach Other British Cars 3
mctriumph General TR They are never DONE!! Triumph 5
PAUL161 NASCAR, I'm done. Racing 11
PatPink TR6 Hello, I am new to the site and want to post some photos of my 1973 TR 6. I have done all mods to this car except body and paint. Triumph 10
Rob Glasgow Restoration: What Would You Have Done Differently? Austin Healey 37
S TR2/3/3A carpet kit and the interior done Triumph 8
J Shroud Painting ["Finally done with these"] Austin Healey 3
dougie Fresh Nasty Boy - Well Done Austin Healey 3
Merlin63Tr4 TR4/4A Triple to dual exhaust valve spring conversion done wrong? Triumph 7
Jim_Gruber Bugsy IV - Painting, Cutting, Buffing is done Spridgets 20
Rut What have I done? Spridgets 11
R Valve lash - Is this how it is done? Lotus 4
L Tastefully done, no? Austin Healey 16
simon1966 All the prep is done, time for real paint! Austin Healey 6
CLEAH What crazy things have you done with [to] your Healey? Austin Healey 21
D Paintwork done. Austin Healey 8
K TR2/3/3A Cleaning the gas tank...what have I done now? Triumph 19
R Where did it go? A who-done-it mystery! Austin Healey 18
5 TR2/3/3A Macy's Garage restoration done and having fun Triumph 6
J MGB Project car done: idle variable MG 2
J MGB Project car done; front end clunk noise while braking MG 4
T TR4/4A Under the been there - done that school of learning: TR6 rear springs on a TR4a Triumph 12
PAUL161 T-Series The TF Is Done! MG 15
PKPoole TR2/3/3A Spring Cleaning Done Triumph 2
J Alternator Conversion - Gutting the RB340 Regulator What must be done? Austin Healey 16
cmacmillan TR6 now what have I done? choke on rebuilt carbs.... Triumph 6
M General TR Restoration done, Picture time Triumph 33
PKPoole TR2/3/3A Done! Triumph 21
D Dash Recovering - Almost done Spridgets 32
J TR2/3/3A Kitty is done! and legal on the road this time. Triumph 7
60TR3A TR2/3/3A I Had a Portrait Done of My Car Triumph 13
WillR MGB Turn signal ground issue DONE. MG 0
