Is there a low profile tire for 73
ike_cloe58
Curious if there is a low profile tire that will fit a 73 MGB wire wheel? I've read all the previous messages I found but most were going higher? Also curious on the opinions of a low profile on a MG instead of closer to stock.
G
Sorry but the answer is NO. Due to the width of the wheel being 4.5" you can't get a low profile tire to work with the rim width. I know 185/70 tires work on a MGB wire wheel and possibly a 185/65 tire.
[ 08-30-2003: Message edited by: David Kiehna ]</p>
aeronca65t
Sumitomo makes a 185/60 HR-14
Availbale from tire rack for $35.
adam90009
if you had a low profile tire on stock wheels your wheel wells would look pretty empty if you were to have a low profile tire you could use a 16 inch or maybe even a 17 inch wheel but from what i've heard it could be no wider that 6 inches
[ 08-31-2003: Message edited by: adam90009 ]</p>
Administrator
Boss
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by adam90009:
if you had a low profile tire on stock wheels your wheel wells would look pretty empty <snip>
<hr></blockquote>
Ah, but this is Albuquerque we live in! Small wheels on cars is all the rage (why, I have no idea). The other day I saw a Cadellac Escallante (sp), the big, expensive SUV they make sporting wheels the size of a Mini! (Well, mayby a bit bigger, but not much).
Ike, trust me on this - stic with stock sized tires, or maybe a bit oversized if you must deviate. To do otherwise would ruin the look of your B in my humble opinion.
PS: Welcome to the forum! We're neighbors - I live just a few miles away in Edgewood.
[ 08-31-2003: Message edited by: Basil ]</p>
I
ike_cloe58
Thanks for the welcome. Doesn't seem to be too many MGs in Albuquerque. I am starting to find more and more of them though.
I have decided to go with the stock tire size or at least the one that comes the closest to the original.
tony barnhill
Great Pumpkin - R.I.P
205x60x14 will fit under wheelwells!
K TR2/3/3A Volvo low profile space saver spare tire for TR3 ? Triumph 1
Patrick67BJ8 Low-Profile Electric Puller Fans Austin Healey 51
X spring ride height/ low profile tires/minilites MG 2
roscoe Low-Budget Luggage Rack Austin Healey 27
Donald1107 TR2/3/3A low cylinder compression Triumph 12
D Lucas Low-Tension Leads Austin Healey 1
CJRams For Sale 1974 Rolls Royce Silver Shadow - low mileage, all original Other British Classifieds 0
rgfrey 1959 Low Beam Headlights Not Working Austin Healey 5
K TR2/3/3A TR3 with alternator conversion... red light stays on and low voltage on the voltmeter gauge? Triumph 1
S TR2/3/3A Exhaust system - It hangs too low no matter what I do Triumph 15
G TR4/4A "Engine seized after engaging overdrive at low speed. Triumph 26
Hamish Racing TR2/3/3A Low oil pressure warning Triumph 0
F TR6 Sputtering at low rpm Triumph 16
TAS525 TR2/3/3A Brand New Generator Low Voltage Triumph 25
Joe Schlosser Spedo reading low Spridgets 8
T TR6 Low Oil Pressure Light Triumph 3
F TR6 Squeal When Turning Sharply at Low Speed Triumph 6
F TR6 Carburetor issues at low rpms webers Triumph 23
RAC68 Heavy Tapping low in the Engine Austin Healey 58
T Even but low compression on 3.8 - timing slightly off? Jaguar 7
Geo Hahn TR6 Low Miles TR6 on eBay Triumph 4
TomMull Volvo Low Rider spotted in Vassalboro Me Other Cars 1
RickPA Water temp gauge reads low Austin Healey 6
HighAltitudeTR3 TR2/3/3A Oil Pressure low all of a sudden Triumph 10
JFS Wedge Low Coolant Light Triumph 7
O Low manifold pressure! Jaguar 8
warwick-steve How low is too low? [spring question] Austin Healey 19
2billydavies TR2/3/3A very low oil pressure when TR3a is warmed up Triumph 12
S Low entry cost into AH ownership? Austin Healey 18
C 100-4 At Mecum Kissimmee Auction-low price? Austin Healey 22
charleyf TR6 low speed stall Triumph 51
CJD General TR New Low for Ebay Triumph 21
Jim_Gruber BE Hi Low Beam Footswitch and Relays Spridgets 6
doc50 TR2/3/3A Speedo reads way too low Triumph 13
R Low Brake Pedal Austin Healey 9
Jim_Stevens TR2/3/3A OD low pressure vs Operating valve shaft setting Triumph 9
F TR6 Starter Relay = Low Engine Power Question Triumph 13
M TR2/3/3A Low charge with Alternator Triumph 5
B No Low Beams Austin Healey 1
CJD TR2/3/3A Low Port Head Cracks Triumph 36
aeronca65t Post-War Other super low mileage Herald Triumph 2
R low/high temp engine running question Spridgets 23
C TR2/3/3A TR3 Low Port vs High Port Head Triumph 10
NutmegCT TR2/3/3A low idle after a fast run - TR3 Triumph 4
AH67 β€Ž62 BN7 for $69,000? Seemed low to me.. Austin Healey 21
Jer Too Low of idle cause PCV to malfunction ? Spridgets 1
B TR6 Low mile tr6 Triumph 12
D Carburetor Backfire on acceleration at low speed Austin Healey 18
V Low Oil Pressure Triumph 4
H low oil pressure Austin Healey 15
