Is my Generator charging?
AUSMHLY
Hello all,
Last month I had my generator rebuilt. Installed it and all was well. Today I noticed the red plastic charging light in the tachometer stays lit until 1000. I checked the belt and it seemed fine. 1/2" play. I retighten it to make sure. The two wires on the generator were snug. No change with the light staying on till 1000. Before it would only be lit when the ignition was on, car not running. As soon as I started the car, the light would go out.
So, what do I need to check, and how do I do it?
Thanks guys,
Roger
Put a volt meter on the battery terminals and measure the voltage with the engine off, engine running and in your case, above 1000 RPM.
My money is on the voltage regulator needing adjustment or replacing.
healeynut
Roger -
Sometimes with a newly rebuilt generator it overloads the contacts in the Voltage Regulator and warps the contact arms. You may just have to fiddle with the contact gaps in the Voltage Regulator a bit to get it working properly again.
Cutlass
Is there a good "how to" on setting the voltage regulator? I've got the same issue. My regulator has three contacts.
GregW
There are a couple pages on adjustment in the shop manual, starting on page NNN4.
healeynut
the shop manual has some guidelines, but the main thing is to make sure the contact surfaces are filed and usually about ~.02" apart seems to be about right. If it's warped it'll be bigger or less than that for sure.
M TR2/3/3A Generator Warning Light on with the Alternator Charging the Battery Triumph 4
S TR2/3/3A no leaks, but the generator is not charging Triumph 45
O TR2/3/3A TR3 Generator Not Charging Triumph 3
Dave Richards Generator not Charging? Austin Healey 14
B MGA charging voltage for mga generator MG 7
MGTF1250Dave T-Series Lucas Generator MG 1
P Generator to Alternator Swap Austin Healey 2
W Generator or Alternator? Austin Healey 18
T Spitfire MK2 Generator Triumph 3
W Generator and Starter Long Bolts Spridgets 0
DrEntropy MGB Generator to alternator swap MG 1
B Generator Parts Austin Healey 6
P BN4 Generator Woes Austin Healey 7
K TR2/3/3A Can anyone confirm that if you replace the ammeter with a voltmeter ( generator removed and alternator added) that you...... Triumph 5
K TR2/3/3A Red ignition light stays on...car has alternator not generator. Triumph 17
TR3MT TR2/3/3A Generator Output Triumph 18
Dnickels Spitfire Generator fan rubbing/scraping Triumph 3
AUSMHLY Generator to Alternator Swap Austin Healey 20
AUSMHLY Lucas Generator C42 End Caps Austin Healey 3
vette Need BugEye Generator Austin Healey 7
vette Need BugEye Generator Spridgets 4
S For Sale Early Sprite & Midget Speedometer/Tachometer/Generator etc. Spridgets Classified 2
Merlin63Tr4 TR4/4A Alternator or alternator in a generator case? Triumph 4
J Wanted WTB TR 3-4 Generator pedestal Triumph Classifieds 3
S TR2/3/3A Generator Pulley Bolt Removal Triumph 12
O Generator Question Austin Healey 2
TAS525 TR2/3/3A Brand New Generator Low Voltage Triumph 25
K What to do for coil bracket on upgraded generator? Austin Healey 8
R TR2/3/3A generator to alternator Triumph 5
M Difficult Electrical Problem in 59 BE with Generator Spridgets 6
T New Generator Mystery Austin Healey 5
I Bugeye generator/alternator conversion question Spridgets 7
NutmegCT Ozone generator - cigarette smoke smell in car? Restoration & Tools 11
R TR2/3/3A TR-2,3 Generator Pic showing all attachments Triumph 5
doc50 Mash Metropolitan Generator testing Other British Cars 1
S TR2/3/3A generator red light deal Triumph 6
J advice on a 3 brush generator please C45N-3 Other British Cars 0
5 Tach Drive Generator for a Bugeye Spridgets 2
M Jaguar XK Special Equipment Generator Jaguar 1
T C42 BJ8 generator long screw needed Austin Healey 2
Magyar Generator going on the fritz Spridgets 3
Rhodyspit75 Generator pulley diameter Spridgets 2
A Wanted WTB Generator pulley & fan Austin Healey Classifieds 2
Rut Bugeye generator color Spridgets 22
CJD TR2/3/3A Generator and other Odds Triumph 6
G TR4/4A New Generator vs Alternator vs BPNW Alternator/Generator Triumph 13
R TR6 Generator to alternator conversion Triumph 6
2billydavies TR2/3/3A generator doesn't appear to be working Triumph 7
2billydavies TR2/3/3A dead battery, generator, belt Triumph 13
K TR4/4A Generator bench testing..... Triumph 6
