I am installing new two piece (steel inner and nylon outer) inner wishbone bushes. The outside diameter of the nylon parts is such that, when pushed in to the control arm, the inner steel bush is difficult to install and, when installed, will not rotate within the nylon. This would result in the steel bush rotating on the frame mount if installed. I have started reducing the OD of the nylon piece by scraping a razor blade longitudinally against it, shaving very thin slivers with each stroke. This will apparently take approximately forever. Moss tech has not answered my inquiry. Does anyone have any thoughts on speeding this up.
Thanks, Bob
Thanks, Bob
