TR2/3/3A Hypothetical: Big bore TR3/4 engine
Bremer
We know that 89 mm is the largest bore that pistons and liners are readily available for. I read about engines with 92, 92.5 and even 94 mm. I'm looking for some information on what would be involved in such modification.
I found that solid info on this is few and far between. I know the block has to be machined, but what features exactly? Can the bore centers still be on a straight line, or would they have to the offset?
How about cooling efficiency? Liners touching each other? Just a few of the issues that come to mind.
I totally realize that the most practical upgrade is the 89 mm bore kit. The benefits of a bigger bore may not be worth the amount of headache and cost to build the engine. Nevertheless, just wondering...
TR3driver
Great Pumpkin - R.I.P
:iagree:
And he loves to talk!
ISTR him talking about keeping the cylinders in-line; but having to 'siamese' the liners together. Strictly racing stuff, he doesn't recommend more than 89 for the street (although I know some have done it and seem to get away with it).
He also used to have a motto : "Speed costs money, how fast do you want to go?"
TR6oldtimer
The first 25% increase in power is relatively inexpensive, the next 25% can be what you spent up to that point. After that, the $$/hp goes up exponentially. Keep in mind you reach a point the car is not street drivable.
There is only so much you can get out these lumps.
TR3driver
Of course, there's more than one way to skin a cat ...
martx-5
I just saw in the "British Motoring" magazine from Moss Motors that came today, that they have an Eaton blower set-up coming soon for the TRactor motors. :smile: I couldn't find any info on there web site yet.
TR3driver
They were showing a TR4A installation at TRfest, but I didn't get a chance to ask about it. Looked very sanitary, but maybe wouldn't fit a TR3 as it very nearly touched the inner fender on the wider 4A.
nissanite
I love all of the turbo pics & excitement. Considered that myself. Went with 89mm with custom liners. The ones purchased from normal channels proved to be slightly out of round & kept coming in damaged. My engine builder made custom units, way cool.
The issue, I think is with the crank & only 3 main bearings. How much power can it take? Also, think of the harmonic vibrations of the large 4 cylinder engine.
I have a German car with a 3.0 liter 4 cyl. It has 2 balance shafts.
Sure, you can bore away but what will you have when it is done?
MDCanaday
IMHO if you are going to go to this extreme, you must invest in modern forged or machined rods.These are much lighter than stock rods and will reduce the loads on the old 3 main lump.While you are ordering the rods up ,send out the crank for a heat treating.Then lighten and polish it before the final work on the journals,try to stay at 020 under if possible.
The factory never had a harmonic balancer unless you counted the fan and its rubber grommets.But at the end of the day no crankshaft will last forever,you can only give it the best chance by reducing the loads.Custom pistons are not as high dollar as you might think and the 100 grams saved on forged pistols is 3 ounces of weight each journal will not have to fight.The rods can save as much as 210 gr each. A low end with this kind of prep can easily exceed 6000rpm reliably for many years.NOW you can punch it out to what ever you feel confidant with.
MD(mad dog)
Monkeywrench
I can't speak for the big bores, but..
You need a harmonic balancer. We use an ATI unit.
The bottom end can take A LOT of rpms (well over 7000rpm) when set up right, even as wet sump. Granted, you're looking at a lightweight, all forged set up. The thing to watch for on the bottom end is the center main flexing. Run the biggest main cap strap you can fit. You're probably going to have to custom machine something.
I think most people with stock cranks try to limit themselves to 6000 and once in a while they will hit 6500rpm.
JPSmit Hypothetical Question of sorts - wheel bolts Restoration & Tools 12
JPSmit Hypothetical Question - lathes Restoration & Tools 4
JPSmit Hypothetical Question - welders Restoration & Tools 2
JPSmit Hypothetical Question - Hardtop glass availability Spridgets 5
JPSmit Hypothetical welder question Restoration & Tools 24
IanF hypothetical... S1 E-type value... Jaguar 13
hawkwind Hypothetical Crash Test Spridgets 6
H Big Healey Search Austin Healey 0
P TVR Big Valve 4.3 TVR 0
R Big Healey 100 Head Austin Healey 4
dougie Did Big Healey Drivers Go Soft? Austin Healey 8
D ARP big end bolts. Spridgets 7
B How big is the floor pan drain hole? Spridgets 0
AUSMHLY For Sale - 1990 Big Healey, 3000 MK3, HMC Mk4 Austin Healey 2
Lin Big Birthday, today! Austin Healey 12
R Wanted WTB Big Healey Austin Healey Classifieds 3
R Connecting Rod Big End Specification Austin Healey 4
S For Sale Big Barn Cleaning Triumph Classifieds 0
dougie Big Healey Six - Used the Right Way Austin Healey 5
aero3113 For Sale Big Healey Tube Shock Conversion Austin Healey Classifieds 2
dougie 1963 Sebring Big Healey 57 FAC Austin Healey 4
S TR2/3/3A The big brass drain plug on the OD does not thread in easily Triumph 9
B For Sale 1956 Austin Healey 100-4 SCCA big bore race car plus parts lot engine trans etc Austin Healey Classifieds 0
dougie Big Healey 6 Racer For Sale Austin Healey 2
K For Sale TR3 Cockpit Trim ...N/A at The Big 3 Triumph Classifieds 0
AngliaGT Big Healey Spotted 0
coldplugs Big Healey near Portland OR Spotted 3
D Two big Healeys Spotted 1
jfarris For Sale New TR3 Rod Bearings Big End Std Size Triumph Classifieds 0
HealeyRick Bugeye Colored Big Healey Austin Healey 0
Marvin Gruber Big Healey brake booster rebuild Austin Healey 4
dougie Silodrome - Big Healey Buyer's Guide Austin Healey 4
Marvin Gruber Big healey coil springs Austin Healey 7
HealeyRick Last Big Healey? Austin Healey 20
Flash_Harry General MG B-Hive in S.C. - Big thumbs up! MG 2
Marvin Gruber Big Healey ridged hood Austin Healey 13
AngliaGT Red Big Healey Spotted 0
dougie Three Historic and Importnat Big Healeys Come to Market Austin Healey 5
B Twin OH Cam for the BIG Healeys Austin Healey 15
M_Pied_Lourd TR2/3/3A Big Day Today! Triumph 17
AngliaGT Big Rig + Spotted 6
S Preparing for the "Big One" Spridgets 7
maxwedge5281 bumperless big healey photos!! Austin Healey 34
Marvin Gruber Big Healey clutch question Austin Healey 3
T What is needed for a 'big brake' upgrade; how well does it work? Spridgets 14
apbos So Cal Big Healey- can someone examine for me Austin Healey 3
MGTF1250Dave T-Series Big Day in the Shop Yesterday MG 9
John Turney Another Chance to Own a Factory Rally Big Healey Austin Healey 0
Tronch Big Healey heigth increase Austin Healey 1
B A Big Day for the Restoration Austin Healey 9
