TR6 "how to un-lock a boot lid"???
toysrrus
Hi Folks,
i bought a '73 TR6. Overall nice car. Just 1 problem; I can't open the boot lid!!! The key goes in just fine & turns the tumblers but will not release the boot lid!?!? I got a "Locksmith" to look at it & he couldn't make it work!?!? He said there's something missing in the lock mechanism.
How can I open the "Boot Lid" without damaging it?? I don't care about the lock itself.
Thanx in advance,
Russ
Uhhh.... You have to PUSH the lock in to release the lock and open the boot.
Yeah, are you pushing the button in and lifting Russ?
Cheers
Tush
Duh, Yes to pushing & lifting!
Russ, I think this is what they call between a rock and a hard place. I've included a couple of pictures. The latch has to move to the rear to release. It might be that the spring has broke which would keep the latch from coming back. Unless somebody else comes up with a different idea, you might try this. Drill a small hole above the button release angled upward toward the latch. Bend a short hook on a wire such as they use on model planes and see if you can't hook the latch and pull it back. If it works, all you would have to fix is the small hole. IMG_0085.jpgIMG_0086.jpgI should probably add that my lock also quite working, the key just went around but wouldn't lock or unlock the lid. But it would still open by pressing the button. After seeing how rusty the spring was I'm going to replace it before I have the same issue.
Your right Richard.
Yep easyrider. Darn near jumping up & down on the lid while pushing the button in!!
Not a bad idea Terry. I basically knew that I had to get that "Hook" portion pushed back but just had no idea how!?!
I'm out of town & will be back tomorrow. I'll see what your suggestion does Terry.
Any other ideas??
Thx, Russ
PS: I have a "Wanted" ad posted for a "Luggage Rack".
Would someone please post a pic of the "Striker" that's mounted on the "Boot Lid". I'm only "Guessing" that there is a "U" shaped hook that the lock grabs.
What is the "Inside Dimension" between the arms so I may be able to get a "Tool" of somesort in there & push on the lock mechanism.
Your reply would be greatly appreciated as I want to get this Boot Lid open today.
Thanx in advance.
Russ
Hi Folks,
Please dis-regard previous pic request. Found some real good pics online via You Tube.
Thanx again, Russ
Just in case.............
The part attached to the lid isn't U-shaped..it's an "L"
The part on the rear valence looks like this:
Great pics pool boy.
Thanx, Russ
Popeye TR4/4A Trunk [boot] lock removal Triumph 12
M TR4/4A Trunk/Boot lock key code?? Triumph 4
R 3000 Boot Lock nomenclature Austin Healey 4
R Boot lock stuck MG 11
M How to lock the boot.... MG 3
jjbunn Boot/Trunk Lock Mechanism Replacement Triumph 2
D Door Lock Tumbler Austin Healey 4
BierRunner TR6 TR6 Trunk Lock Striker Triumph 3
T TR6 Steering Wheel Lock Triumph 2
A 100/6 BN4 Door Lock Austin Healey 15
RJS TR4/4A Fuel Filters and percolation/ vapor lock Triumph 0
V 1969 Sunbeam Alpine coupe glovebox lock removal Sunbeam (Rootes) 0
ActionJackson Spitfire Steering Column Lock Triumph 3
K Spitfire 1978 Spitfire possible Vapor Lock? Triumph 16
old sub sailor Ignition switch / steering lock replacement in a '78 midget Spridgets 5
Michael Oritt Vapor lock--a foolproof if a bit radical solution... Austin Healey 8
G Glove Box Lock Austin Healey 2
J Steering Box Adjusting Bolt Lock Nut Austin Healey 11
M TR2/3/3A Steering Lock to Lock Measurement Triumph 3
M TR6 Glove box lock. Triumph 4
K TR2/3/3A Steering wheel Lock Nut? Triumph 2
A TR2/3/3A TR3 door handle lock cylinder Triumph 4
red57 Changing Lock Barrels Austin Healey 15
6TTR3A TR6 TR6 Trunk lock set screws Triumph 2
I General TR Ignition lock barrel help Triumph 1
M TR2/3/3A Rocker Shaft Pedestal Lock Washers Triumph 4
P Brakes lock up when rolling forward Austin Healey 4
Got_All_4 TR6 How does this steering lock come off Triumph 9
60BN7 Adjustable Steering Column Won't Lock Austin Healey 9
S Glove Box Lock - BJ8 Austin Healey 3
S TR2/3/3A glove box lock Triumph 27
S TR2/3/3A T handle trunk lock Triumph 14
wangdango BJ8 Glove box lock? Austin Healey 1
T TR2/3/3A vapor lock? Triumph 44
Scotsman TR4/4A Steering Stop Lock on trunnion Triumph 9
vette Vapor Lock, Out of Gas, Hmm, Ahh, Don't know? Austin Healey 32
Steve P. Info: removing anti-theft column lock on later cars Spridgets 0
Got_All_4 Wedge Glove box lock removal Triumph 7
C BJ8 Rebuilt Engine and Carbs - Vapor Lock and Misfires when hot Austin Healey 7
AUSMHLY Going price for BJ8 glovebox lock Austin Healey 6
R Brake Lock Up Austin Healey 17
S TR2/3/3A Spring pans, trunions, and lock washers Triumph 6
C General TR Lock tab vs Loctite Triumph 5
Tinkerman TR2/3/3A Continuity Check on Tranny Lock out switches Triumph 2
Tinkerman TR2/3/3A Tranny lock out switches Triumph 9
CJD TR2/3/3A Lock Help...you out there JP? Triumph 29
Brinkerhoff General MG Installing Moss lock clips on door lock barrels , newer Midget MG 0
longbridgehealey Bugeye lock barrel and combination switch Spridgets 2
T TR6 Brake caliper lock after some driving Triumph 3
J Where To Find BJ8 Key Door Lock ,Trunk & Glove Box Numbers ??? Austin Healey 3
