Spitfire How do I adjust SU carbs on my Spitfire?
A Uni-Syn, two Colour-Tune spark plug surrogates and a pound of patience! :excitement:
LOL...I was making a bogus post just to do a video on how to start a new topic in a specific forum! I guess i forgot to delete this thread! :rolleye:
:lol:
A pretend SU carburetor question? Then here...the required SU carburetor answer....
β€œAs he stared at her ample bosom, he day dreamed of the dual SU carburetors in his vintage Triumph Spitfire, highly functional yet pleasingly formed, perched prominently on top of the intake manifold, aching for experienced hands, the small knurled caps of the oil dampeners begging to be inspected and adjusted as described in chapter seven of the shop manual." β€” Dan McKay, Fargo, ND
G HD8 Idle Adjust Screw Austin Healey 10
K TR2/3/3A Using a dial gauge to adjust valves when rocker arm surfaces are worn? Triumph 9
K TR2/3/3A Front wheel bearing adjust and end float?? Triumph 10
V 89 XJ6, How to adjust front camber? Jaguar 2
T TR4/4A adjust fuel level Triumph 8
F Frustration trying to adjust handbrake on Austin Healey BT7 Austin Healey 9
gbtr6 TR6 Valve Adjust, What clearance? Triumph 5
bighealeysource Best way to adjust doors Austin Healey 9
BN6_2197 How to adjust the front suspension of a BN6 Austin Healey 52
J TR2/3/3A steering stops , how to adjust Triumph 2
S Clutch self-adjust? Austin Healey 28
S Adjust mixture on a BT7 Austin Healey 9
T SPQR Tappet adjuster, Click Adjust Austin Healey 1
H Stromberg Carb Sync and adjust Triumph 6
B Adjust headlights/ "true" them? MG 7
M How often to check/adjust valves? Triumph 7
M Clikadjust Valve Adjuster Triumph 4
B Triple carb setup too rich? How to adjust? Austin Healey 3
memphis Torque Head Bolts & Adjust Valves Austin Healey 13
W handbrake adjust Austin Healey 2
T looking for valve adjust shortcut. Triumph 33
QuickSilver I Need An Alternator Adjust Bolt MG 0
K SU Mix Adjust Memory Refresh Triumph 7
K TR2/3/3A TR3: carb adjust mixture ie. how many flats... Triumph 12
T Bonnet Latch Adjustment [how to adjust bonnet latch [BJ7] to keep it closed] Austin Healey 14
F Hydraulic clutch adjust Triumph 9
Pythias Click Adjust? Spridgets 6
MTribe how to adjust static timing? Triumph 8
bluemiata90 Wedge TR8 adjust cold start idle and warm temp idle Triumph 3
Luke_Healey How to adjust rich SUs Spridgets 7
C TR6 Proper way to adjust front hubs, TR6? Triumph 13
6 How to Adjust Voltage Regulator Spridgets 0
bluemiata90 Site for using clikadjust Triumph 3
jlaird How to test and adjust a fuel gauge Spridgets 25
K TR2/3/3A TR3A Clutch MC stop bolt and clutch slave adjust Triumph 5
W handbrake adjust Austin Healey 1
H How to Adjust Valves in 100-6? Austin Healey 10
KLUTZ Will this door corner somehow adjust in? MG 11
L KYB Gas-adjust shocks Triumph 1
Ed_K What is the best way to align/adjust the doors ? Austin Healey 8
T TR6 Special tool needed to adjust TR6 rear brakes? Triumph 9
Slider748 TR6 How to adjust idle mixture on TR6 Triumph 10
Patton Gunson Clikadjust - Timesaver or Timewaster Restoration & Tools 8
KVH General Tech Tuning the SU carbs Triumph 18
R SU Carbs - Needle and Seat Austin Healey 7
G HD8 Carbs Removal Austin Healey 33
L For Sale original Bugeye SU H1-1 1/8 Carbs Spridgets Classified 0
Zitch For Sale HD8 carbs and 2" intake Austin Healey Classifieds 9
jfarris For Sale SU H6 Carbs AUC 878 - SOLD Triumph Classifieds 0
Simmo TR6 Weber Carbs and Redline Air Cleaners Triumph 1
