Help!! HS Carb Part needed
LastDeadLast
Would anyone have one of these that I could buy? It's a float bowl cover for an HS carb. I'm looking for one with the same fuel line configuration.
Thanks in advance!
-s
Tinkerman
No, Joe Curto is on Long Island, Unless he went over to Apple. He did my carb shafts for me. Can't find the link right now but he is on the web. Maybe someone else has the link.
Tinkerman
carl w french
Nope, that's Joe Curto in College Pt, NY (you were right). I have that part I am pretty sure. It's yours for shipping. PM me your address.
Wait a minute.... HS4 or bigger? HS4 parts I have.
LastDeadLast
LastDeadLast
Does this help (Crossing fingers)? I need it configured exactly like the picture below and obviously the same size. Many, many thanks!!!!!
Brosky
Shannon,
I'm checking with a very reliable source.
Actually two, so maybe we can get some help for you here in NE.
Brosky
Shannon,
Carl said that he had one for an HS-4. Is that what you need? If not, what is this part from? An HS-3?
Brosky
How in the world did I type a 3 when I meant an 8 ???
See why I don't work on my own engine after a 12 hour day???
G
Try Gary Martin in South Dakota. He rebuilt my ZS carbs to concours condition. One of the best. Nice guy. 605-391-2422
carl w french
Sorry but negative on my end Shannon. I have a bag of spare SU bowl parts and two that are probably from the other side carb. So, as they say, "close, but no cigar".
Sleipnir
Member
Shannon,
I probably have one somewhere. I beleive all HS series carbs have the same size float bowls (I know all 2 thru 6 do) although they can be either tilted or horizontal. The tang/float level arm for the needle and seat on yours is different. Do you have another one of those? I think that some spridgits had the single feed that's vented just under the inlet. The orientation of the inlet may be different. If you still haven't found one PM me and I'll take a look this afternoon.
Erik
jessebogan
I have one in my hot little hand. (See my post on the Jag list) Send me an address, and I will ship it.
RGK TR5/TR250 SU carb ID help Triumph 6
jlaird MGB V6 carb help MG 14
P Carb Help - Car idle slows and dies after being run for a while Austin Healey 14
D Rough running BT7 3 carb HELP Austin Healey 13
I Spitfire 78 spitfire carb connection help Triumph 8
UmmYeahOk GT6 I Give Up! Help A Millennial Out [Carb/Choke Related] Triumph 28
M TR2/3/3A Need Help With Carb ID On My TR3B Triumph 8
K SU carb Help Spridgets 10
J TR4/4A Making a '65 TR4 Run Awesome. Misfire, Ignition Tune Up, Carb Rebuilds. Help? Triumph 70
E Need SU Carb help Austin Healey 5
bighealeysource Stromberg carb help needed for TR buddy Triumph 8
K Tri-carb help Austin Healey 11
K Tri-carb help please Austin Healey 0
R Carb help, where to find it? Spridgets 4
Spriteman65 Carb help Spridgets 11
7 Carb help needed Triumph 6
I TR6 Carb help please for 69 TR6 Triumph 14
I Help with carb hook up for 948 Bugeye Spridgets 8
M weber carb rebuild HELP! Spridgets 50
P Help with choking weber carb! Spridgets 2
tweety Help me verify what to check with the carb.... Spridgets 0
Morris Help identifying carb set... Spridgets 18
J Seeking tri carb help Austin Healey 16
I TR6 69TR6 carb adjustment help Triumph 5
vping I need some carb help. MG 8
mountainman TR2/3/3A TR3 Carb Rebuild Help Triumph 1
newmexTR3 TR2/3/3A TR3 Carb help - crazy idle Triumph 12
I TR6 69 TR6 carb tuning help Triumph 8
I TR6 69 TR6 Zenith Stromberg carb help Triumph 1
LastDeadLast Help! In need of HS carb parts Jaguar 9
YankeeTR Carb ID help.. Triumph 4
martyc MGB Help: 73 MGB w/ Weber DGV Carb - Popping Downhill? MG 9
WidespreadPanic TR6 TR6 Weber Carb owners- a lil' help please Triumph 9
L Spitfire Help me make a carb choice [Spit 1500] Triumph 18
TR_JOE250 Spitfire Spitfire carb need help/opinions Triumph 6
I TR6 TR6 carb help Triumph 4
drooartz Carb help--idles too high Spridgets 7
R Carb leak help please Triumph 5
PAUL161 SU carb. problem. Help,Help,Help! MG 12
R6MGS Weber Carb Parts...HELP! MG 4
JPSmit Carb removal help Spridgets 5
George Zeck SU Carb Help !! ?? !! Spridgets 3
George Zeck SU Carb Help ...... Spridgets 6
J SU HS6 carb need help Triumph 10
coldplugs T-Series Help! Carb, intake, etc.. Car wont start MG 6
B TR4/4A Some Help with Setting Distributor Triumph 47
N Wanted Help with car identification Other British Classifieds 2
I MGB Help! What is this part for? MG 13
P Please help identify this tourer Spotted 13
angelfj1 TR5/TR250 TR250 Need Help identifying wires (2 - black) feeding starting solenoid Triumph 6
