Hey there Guest! If you enjoy BCF and find our forum a useful resource, if you appreciate not having ads pop up all over the place and you want to ensure we can stay online - Please consider supporting with an "optional" low-cost annual subscription.
Attempting to start the Healey. Turned over a couple of times, then nothing, no lights, no fuel pump, no nothing. New battery and fuses seem ok. Where to start?
Sounds like electrical connections. Start with checking/cleaning battery to solenoid connections (both ends of the main cable from battery to solenoid) and solenoid to starter cable connections. Battery to ground connections thru the cut-off switch (the cut-off switch itself can fail so you can simply bypass it to test). Once you are sure all these main connections are good, use a test light to check for power at the fuse block and then move under the dash to check at the ignition switch and headlight switch. Hopefully you have a wiring diagram and can follow the routes of electricity to trace the problem.
A friendly reminder - be careful what links you click on here. If a link is posted by someone you don't know, or the URL looks fishy, DON'T CLICK. Spammers sometimes post links that lead to sites that can infect your computer, so be mindful what you click.
(Click X in the upper-right to dismiss this notice)
