Healey BJ8 misfire
rogermrm
Any ideas out there - all appreciated: Healey 3000 misfires badly at startup and when warm will run for 15 minutes ok then misfire or sometimes stalls when driving or at idle.
Upgrades to try and correct:- New electronic ignition fitted to old distributor, new/coil/leads/plugs, head completely overhauled, compression good 160 to 170 psi, new fuel tank/pump (Pump clicks away then stops when pressure is up) and filter, carbies have done approx 2000 miles since overhaul, new radiator.
the 'experts' have tuned it and I have tuned it - no difference.
Twin SU HD8 carbs.
Cheers, Roger.
Read more: https://healey.hyperboards.com/action/view_topic/topic_id/4722/post_id/21086#21086#ixzz3lVP3RvPI
Have you tried adjusting the advance/retard.? It has probably nothing to do with carbs so you may have wasted $1,100. Remember - 90% of carburettor 'problems' are electrical.
Hi Roger,
I just thought I would come out of left field and suggest something that can cause similar symptoms but IMO has a low probability of being the cause. Check the white with black stripe ignition grounding wire coming from the cut-off switch in the boot. A loose bouncing wire in the boot, when driving, could randomly short the ignition and cause backfires and/or kill the engine.
Ray(64BJ8P1)
Hi Roger,
Ray(64BJ8P1)
I agree, Ray. A friend troubleshot this problem on another friend's 100M. The car would start, then run gradually worse before quitting. Suggest you disconnect that wire from the distributor.
S Wanted WTB: 3.5 ratio diff/pumkin for '67 BJ8 Healey 3000 Austin Healey Classifieds 0
Cutrog1 For Sale Healey 3000 BJ8.... a restoration saga Austin Healey Classifieds 0
A For Sale 1966 3000 Healey Blue BJ8 Austin Healey Classifieds 3
B Austin-Healey late 3000 BJ8 Electrical Diagram Austin Healey 1
B Austin-Healey early 3000 BJ8 Electrical Diagram Austin Healey 0
J Speedometer Tach Correlation 1965 Austin Healey BJ8 Austin Healey 3
D For Sale 1967 Austin Healey 3000 MKIII BJ8 Austin Healey Classifieds 0
jnew >>> Austin-Healey Parts Lists for BN4-BN6, BN7-BT7, & BJ7-BJ8 Available Online Austin Healey 17
H Tourist Trophy Exhaust on Healey Bj8 Austin Healey 2
J Healey BJ8 anti roll bar bushes Austin Healey 2
T Hardtop for Austin Healey 3000 BJ8 Austin Healey 34
P Distributor and coil BMW in my Austin Healey BJ8 Austin Healey 10
J Healey BJ8 Front Shroud Phase1 / Phase2 ? Austin Healey 7
C Hello - thinking of buying my first Healey [BJ8] Austin Healey 35
S austin healey bj8 gearbox Austin Healey 3
davidb Austin Healey BJ8 dash pad removal Austin Healey 6
davidb Austin healey BJ8 - convertible top alignment Austin Healey 9
specialsports Help Healey BJ8 overdrive just stopped working? Austin Healey 5
R healey bj8 Austin Healey 1
B Healey Bj8 [1964] ignition switch Austin Healey 8
Steve P. Value of Healey BJ8 overdrive? Austin Healey 2
H Big Healey Search Austin Healey 1
Basil Other Austin Healey Enthusiast sites Austin Healey 0
Basil Healey Registry forms changes Austin Healey 0
R For Sale 1960 Healey BN7 Oil Pan For Sale Austin Healey Classifieds 2
S Healey Will Not Start (a.k.a. "Failure to proceed") Austin Healey 3
dougie Jack & Bill Rawles attending The Healey World Challenge Road America September 13-15 Austin Healey 2
Editor_Reid New Edition of "Austin-Healey Quarterly" Available Austin Healey 1
giwplay1 Everything you need to know before purchasing an Austin Healey Austin Healey 15
Editor_Reid Healey 100 Frame Diagram Austin Healey 1
dougie Healey Hardtop on BAT Austin Healey 8
dougie Austin Healey 4000 Austin Healey 3
Patrick67BJ8 Healey Mechanic Needed - El Paso, Texas Area Austin Healey 0
T Healey In An Ice Cube Austin Healey 6
dougie VSCDA Healey World Challenge Road America Austin Healey 0
dougie Healey World Challenge 2024 Road America Racing 1
R Healey 100 Dipstick Stuck Austin Healey 12
L For Sale Austin Healey Parts!!! Austin Healey Classifieds 0
tahoe healey Healey Video Austin Healey 0
W Nash Healey Austin Healey 5
dougie Celebration of Austin Healey Double Event September 2024 Austin Healey 2
E For Sale Austin Healey 100 and 3000 parts Austin Healey Classifieds 1
nevets Letting the Healey go... Austin Healey 4
dougie Healey Racing Road America Fall 2024 Austin Healey 2
R Big Healey 100 Head Austin Healey 4
PAUL161 Photo: What Model of Healey? Austin Healey 7
E Wanted 1963 Healey 300 mark 2 front grille wanted Austin Healey Classifieds 0
Guido36 Webers on a Healey 100 Austin Healey 6
E For Sale Driver quality 1963 Healey 3000 mark 2 Austin Healey Classifieds 1
Editor_Reid Summer Edition of "Austin-Healey Quarterly" Austin Healey 4
