TR2/3/3A Head bolt torque TR3
karls59tr
Bronze
I've just been informed that the torque for the cylinder head bolts is 60-70ft lbs rather than the 105 ft lbs that the manual states. Anyone else heard this?
Did you ask what they had been smoking ?
Well apparently it was from a recent video from England of a TR3 motor rebuild. I'll check the facts again with the guy who told me about the video. A group of Triumph club membere are currently doing a motor rebuild and one of them made the comment about the torque!
Then there is the edition of the Haynes Manual that specifies 45 lbs.
Someone once claimed that those are the same size nuts as were used to mount the deck guns on the Bismarck -- well anyway I've have not heard of a problem with repeated torquing to 105 (with the usual precautions).
Kleykamp TR2/3/3A Head bolt torque??? Triumph 9
Bruce_B Bolt torque sequence on 11 bolt cylinder head 1275 Spridgets 7
K TR2/3/3A Cylinder Head Bolt question.... Triumph 3
D TR2/3/3A cylinder head oil plug bolt size Triumph 6
tomshobby Spitfire head size of damper pulley bolt on 78 Spit? Triumph 2
Got_All_4 TR2/3/3A The bolt on the back of the tr3 head Triumph 4
MY66AH Bolt head size Spridgets 2
HJR TR2/3/3A Crankshaft crank bolt head[108498] Triumph 10
I Bugeye bonnet hinge bolt head busted off - ideas? Spridgets 8
G TR4/4A tr4a head bolt Triumph 2
mgnewbie I can't believe I broke the head bolt! MG 8
Brosky Bolt in rear of head Triumph 14
wkilleffer Seepage/bubbles around #8 head bolt MG 15
D TR4/4A TR4 coolant leak thru head bolt Triumph 7
AUSMHLY Screw or bolt head used for back seat? Austin Healey 20
Z Head bolt fun Triumph 3
PGSberg TR6 Replacing Trans Fill Plug with Hex Head - NPTF or BSPT threads Triumph 6
C MGB Storing a cylinder head MG 5
Carlbanan56 MGB MGB cylinder head MG 11
jfarris TR2/3/3A Control Head Rewire Triumph 4
K TR2/3/3A Pressure testing the radiator to find a head gasket leak? Triumph 7
K TR2/3/3A Photos of new head gasket.... Triumph 3
K TR2/3/3A One more coolant leak cylinder head question..... Triumph 5
K TR2/3/3A Cylinder head liner protrusion specification? Triumph 1
JCL TR4 TR4/4A TR4 Head Seeping Water Through Intake Casting Triumph 13
Michael Oritt Paint Aluminum Head? Austin Healey 3
K TR2/3/3A Odd cylinder head core plug (picture). Triumph 7
K TR2/3/3A Mystery object in my cylinder head water jacket ??? Triumph 14
K TR2/3/3A Cylinder head valve stems and guides.... Triumph 3
K TR2/3/3A Cylinder head anomaly.... Triumph 15
K TR2/3/3A German made head gasket from BPNW Triumph 0
K TR2/3/3A Blown head gasket Blues....probably time for a rebuild? Triumph 14
K TR2/3/3A Cylinder head stud height question? Triumph 4
K TR2/3/3A Memory refresh: non ARP cylinder head studs..... Triumph 2
K TR2/3/3A NEW update on my cylinder head/gasket story........ Triumph 4
K TR2/3/3A Skimming the cylinder head. How do I find the....... Triumph 4
K TR2/3/3A cylinder head washer Triumph 0
K TR2/3/3A The thread pitch of the cylinder head studs? Triumph 10
K TR2/3/3A Getting a cylinder head skimmed for flatness.... Triumph 2
K TR2/3/3A Update on the head gasket repair......something is not right/ Triumph 8
K TR2/3/3A New head gasket is installed.....did a compression check motor cold. Triumph 4
J Spitfire Payen Head Gasket -which way up ? Triumph 6
R TR6 Classic british car mechanic on Hilton Head SC Triumph 0
K TR2/3/3A The steel head stud washers? Triumph 7
K TR2/3/3A Applying the Permatex copper gasket spray to the head gasket? Triumph 6
S Spitfire Cyl head coolant hose fitting Triumph 1
B TR6 Milling the head Triumph 5
sim 948 aluminum head gasket Spridgets 2
K TR2/3/3A Retorquing the Cylinder Head after the initial torquing.? Triumph 23
S TR2/3/3A Rebuilding a cylinder head Triumph 30
