Have you checked your anti-freeze?
I keep it in my system year-round... but we don't need but 50% or so in our climate (in the dead of winter).
Thanks.
Will be putting in some Sta-bil in the gas soon.
sqbsprite TR6 Frame cracking around lower control arm mount, have you checked yours? Triumph 3
bugedd Bugeye for sale that I checked out...... Spridgets 12
T Last time you checked your transmission mounts Triumph 5
T Spin-On Oil Filters Anti-Drain Back Valves Austin Healey 0
K TR2/3/3A Problem with the gear lever "anti rattle fix"..... Triumph 10
af3683 TR2/3/3A TR3B Anti-Freeze Change Triumph 23
K For Sale Triumph TR4 & 4A Gearbox anti vibration attachment Triumph Classifieds 0
K TR4/4A The 4A gearbox anti rattle contraption? Triumph 5
T Need an Anti-Tramp Bar? Austin Healey 6
S TR6 Anti Run-On Valve question. Triumph 4
FlyingCat Spitfire Anti-Roll Bar Triumph 6
AngliaGT Avanti II Spotted 0
Bob_Spidell Healey Anti-Theft Device Austin Healey 0
PC Avanti II Spotted 7
steveg Anti-run on solution Austin Healey 10
JimLaney Anti-seize or Thread locker ? Spridgets 2
55modified Rear anti-roll bar. Is it worth installing on a BN1? Austin Healey 22
J Healey BJ8 anti roll bar bushes Austin Healey 2
F Fitting anti-squeal kit to front calipers on BT7? Austin Healey 7
Got_All_4 TR2/3/3A anti rattle pin Triumph 6
D TR4/4A shifter anti rattle pin Triumph 2
L Sway Bar / Anti Roll bar bush replacement 100/6 Austin Healey 7
B Anti-sway bar for a earlier BJ7 Austin Healey 3
bugedd Front anti roll bar Spridgets 11
Steve P. Info: removing anti-theft column lock on later cars Spridgets 0
J Bypassing battery cutoff switch, using is as anti-theft only? Austin Healey 20
tahoe healey disc brake anti squel pads Austin Healey 5
D TR6 Anti run-on valve Triumph 3
R TR4/4A Tr4a new anti sway bar, maybe almost perfect! Triumph 5
S Spitfire Question on anti run on valve 73 spitfire Triumph 5
K TR2/3/3A TR3 Gear Shift Anti Rattle Spring ##%&*rikerfrats Triumph 8
K No luck.. Gear Lever Anti-rattle Spring Install? Triumph 1
Ed_K Installing new anti-sway arm bushings Austin Healey 3
H Anti-Frezze expandtion thru overflow @ Shutdown Austin Healey 35
Darrell_Walker Ratco anti-sway bars and coil-over rear shock Triumph 6
S TR2/3/3A shifter anti rattle spring tr3 Triumph 4
K TR2/3/3A TR3 Gearlever Anti-rattle spring&plunger Install? Triumph 6
I Bugeye anti-rattle plunger questions Spridgets 6
H Anti run on valve MG 6
J Anti corrosion strips - Worth it? Austin Healey 8
ecurie_ecosse T-Series Anti run on switch. MG 11
G Anti-sway bar question Spridgets 1
HAN8L1965 CounterAct electronic anti rust system? Spridgets 22
Got_All_4 TR5/TR250 ADCO Anti sway bar installation on the Tr250 Triumph 4
jerrybny Anti-Rattle Spring and Plunger Triumph 4
roofman Spitfire Anti run on valve ? spitfire 1500 Triumph 3
jerrybny Anti-Rattle Spring Triumph 1
Hairyone Anti-roll bar Spridgets 13
M Teves Anti-Lock Brakes, All Models up to year 1992 Jaguar 4
